Question about Pentair PUREX MINIMAX HEATER; THERMOSTAT, 60 CAPILLARY - 072022
My heater will ignite and then turn itself off after a brief period. It will then reignite after a few minutes. It will continue to do this until the desired tempreture is met.
The Propane heater was installed sometime in the late 90's. It is believed that unit is 400,000 BTU. The operation and installation booklet is labeled "MiniMax Plus, MiniMax XL and PowerMax. The first time I used it after about 3 years of non use, it operated OK and reached 105 degrees in about 45 minutes. FYI - The spa contains about 5,000 lbs of water. I am quite handy and could repair myself with some guidance. Is there a repair service available in the Ormond Beach, FL area?
    Visited the website for 60 consecutive days.
  • 121 Answers
Check the water temp reg. or "thermo reg" as it is called.
Posted on May 29, 2017
  • 90 Answers
SOURCE: Heater cycles on and of, pool/spa does not reach desired temp
hello, It sounds like you may not be getting circulation thru the heater. Make sure the valves are open to allow water to pass thru the heating system. Some systems use a bypass on the heater so there is not a lot of wear on the coil system in the heater. If it is not circulating it will get too hot and the safety shut down will occure. If you are getting water circulating thru the heater, then the thermocouple or auto start igniter system is not working correctly. It is trying to start and can't then recycles. If the burners are igniting on the startup and then shutting back down you may have a bad control unit or thermal sensor unit. Since the unit is gas have a professional service it for you. Good Luck, RAC
Posted on Apr 20, 2009
  • 91 Answers
SOURCE: Pentair minimax nt 250,000 btu propane will
The service manual for your heater can be found here:
This should help in determining the problem and steps to resolve.
Posted on Aug 22, 2009
  • 128 Answers
SOURCE: minimax pool heater cuts out at 91 degrees when remotely set for
Check the temp reading on the heater. It is probably set at 91...heater control should be set to 104
Posted on Aug 30, 2009
  • 246 Answers
SOURCE: minimax 400 heater not operational
what is ok on the water pressure? th heater need from 40 to 60 gpm in order to work properly clean the filter and let me know
Posted on Sep 11, 2009
  • 990 Answers
SOURCE: E04 message on MiniMax NT 400 DV..Help!!
Your EO4 message tells you you have a fan problem. So ether your fan is diying wich you would hear or you have a bad presure sensor in your exaust. A new fan is a little pricey but the sensor is reasonable for heater parts. I can't be sure but I believe it ether screws onto or into your exaust and it just plugs on to your control board. If your sensor is going bad their is a reason and this should be addressed. It should be in your by-pass or your gas pressure. But as far as a new heater, not untill you have water coming from the cabnit. It is sometimes easer to sell new than keep up with new, Good luck let me know how you do.
Posted on Dec 03, 2009
We have had major blackouts does my bosch highflow 21e need to be reignited or long should it be until I get hot water
you have to reignite it yourself turn dial to pilot and press down the light with either the internal igniter or a long match when lit then you turn dial to the ON position .
Apr 25, 2015 | Bosch Water Heaters
My ruud achiever 90 works fine it's producing plenty of heat. It's just that it only shuts down for a few seconds before it reignites then starts blowing again. It's almost continuously on.
Most likely:The thermostat is telling it to come on. If it continues to run with the thermostat set to off,the ignition relay is stuck in the on position, when the ignition is on the heat sensor will turn the blower on on matter what.
Dec 12, 2014 | Heating & Cooling
I have a Braeburn 3200 and when the the temperature reaches the desired heat setting. The furnaces heat will shut off, but the fan will continue to run indefinetly. eventually blowing very cold air up
The fan relay is stuck in the on position. When the temperature drops the heater does not ignite because the fan is already running and ignition is locked out after the heat cycle starts an the fan turns on
Nov 16, 2014 | Heating & Cooling
Raypak 403A, burners will not stay lit for more than a few minutes.
i'm thinking after the main valve opens the pressure could be dropping in the pilot tube. this could be due to a dirty, plugged and sometimes spider web inside the pilot tube. rare but does happen, nice warm home for a spider. good luck. if not let me know. could also be weak pilot coil.
Jun 09, 2017 | Pool & Spa
I have a Maytag Model PGR5710BDW gas range. The bake igniter lights up and the gas ignites after 2 minutes or so. Then the flame goes out after a few seconds and then reignites and this cycle repeats ...
Yes it is the igniter its weak and can not stay within normal range to stay on allowing the flame to stay on.
The part number for that igniter is 74007498 it can be purchased at your local appliance parts store on online at
Aug 27, 2011 | Maytag PGR5710 Performa Gas Kitchen Range
I assume this is an LCD or SxRD projection TV... you need a lamp. The lamp's burner is worn from use and when it becomes hot, expansion occurs and the lamp extinguishes. The TV will attempt to reignite the lamp 3 times after it goes out. If successful, it will continue to operate until the burner expanded too far once again. This will repeat over and over. Eventually, the lamp will not come back on. Order a lamp and replace it. Best wishes, I hope this was helpful.
Jul 13, 2010 | Sony Televison & Video
Heater went out will not reignite when thermostate is swithed on
Check gas valve coil, igniter resistance and thermostat continuity
Dec 23, 2009 | Goodman GMS90703BXA Heater
Rheem powervent ignites then goes out, electronic ignition.
Sounds like a bad thermocouple. This part sends a millivolt signal to keep the gas valve open but shuts it off when it cools - or if something goes wrong with the ignighter - to prevent fires. It's easy to replace and not super expensive. See your local Rheem dealer.
Aug 13, 2009 | Water Heaters
Bosch gwh-425ef nat gas on demand heater
sound like pcb board is failing - control board
Nov 09, 2008 | Bosch & Power Vent Water Heater
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
