Question about Maytag MMV1153A Microwave Oven
Antenna I have a Jennair Micro wave model JMC8100ADW This looks similer to MMV1153A. It has an Antenna that you can get to from inside the cavity by opening a cover. I broke the Antenna which was produced by Maytag. Although I bought it in2002 Maytag has stopped manufacturing this part and I can not find one anywhere. So I used super glue to join the non metallic parts and now would like to know how to install it. I can not figure it out by looking at it.
  • saibal Aug 11, 2007
    The part number you provided is not correct. It is 58001197. Its not a dome but a disk. I have installed the Magnetron already. When I opened the inside cover the Antenna came out and broke. Its a disk (item #19 on blowup picturehttp://www.appliancepartspros.com/partse... The part is not available. Please tell me how the disk is installed. Which side is out and which is in. Does it just sit there without being attached to any thing else but two clamping holes on the body? Regards
  • saibal Aug 12, 2007
    Thank you for such clear comments. I forgot to get the 20 amp fuse (Magnetron was on my mind) stores are closed. I will give it the first try tomorrow and then let you know the result. Thanks again.
    I will reccomend you all my friends.
    President:
  • 331 Answers
Saibal, microwave repair is a dangerous endeavor if you have not been schooled on them. The antennae you mentioned is part of a larger component, the magnetron. This is a high voltage device (~5000 VAC) and is extremely delicate. Access to it must be from the inside of the cabinet so the unit must be dis-mounted from the wall and placed on a work area. BEFORE PROCEEDING... READ ALL INFORMATION LOCATED HERE!!! http://www.gallawa.com/microtech/index.html THIS WILL COVER THE DANGERS AND SAFETY PROCEDURES. After the unit is on a suitable work area, remove the outer cabinet and set it aside. Now, slow down and visually verify the location of all components... DO NOT TOUCH ANYTHING UNTIL YOU HAVE LOCATED THE HV CAPACITOR!!! After locating the capacitor, follow the instructions listed above to discharge it. Now the magnetron is safe to remove. Remove the wire harness from the magnetron. You will see the 4 fasteners which retain it, remove them and the magnetron will come out. Carefully and gently install the new magnetron and fasten it securely. Reinstall the wire harness to it and rebuild the unit. After installation, test the unit with a cup of water BEFORE reinstalling it. There is a chance that when the magnetron failed, it destroyed the capacitor and/or the HV Diode. If it heats the water, your OK. If not, you'll need the capacitor and diode. I can't stress enough how important it is to follow ALL safety procedures outlined in the link, above! Job time is approx. 2 hours. OK, parts availability... the part number you need is #58001218. I show one available through 1'st Source in Albuquerque, NM. Ph.# (505) 884-0166. List price= $90.98. The gluing technique will NOT work as a repair. The magnetron vibrates at an extremely high frequency and the dome (antennae) will shatter immediately. Please do not perform this repair this way as injury or more damage may be incurred.
Posted on Aug 11, 2007
  • Tracy Farrell
    Tracy Farrell Aug 11, 2007
    Sorry for the miscommunication. In repair lingo, the part you are referencing is called a stirrer blade. It's job is to shield microwave emissions from certain areas of the cabinet while simultaneously directing energy into specific areas of the cabinet where the emissions "bounce" harmonically and evenly throughout the cavity enhancing cooking temps evenly (ergo, "stirring" the microwaves). The actual antennae is the dome that protrudes from the magnetron and into the cavity... directly behind the stirrer blade.
    OK, now that we're on the same page... you're right. That blade is NLA. Both sides should have the same reflectivity so it should not matter which side faces the magnetron. You should keep it in the same position as in the pictured link above, however.
    One other thing, I've never repaired a blade in this fashion because they are definitely a critical component to the proper disbursement of microwave energy. (GE microwaves had a rash of mis-engineered blades for a few years. These blades caused a "feedback" of energy directed backwards down the wave guide and at the antennae of the magnetron eventually causing a mag tube failure.) With that being said, I don't know if or for how long the glue will hold up. If it holds indefinitely, it may allow microwaves to pass through the seams of your repair causing other problems (uneven cooking, feed back to the mag tube, arcing, sparking, etc...). I simply don't know.
    Good work on the mag tube replacement, though! Looking for a career in appliance repair? :)
Jennair combo micro wall oven 30" replace microwave?
When a microwave is dead, the most common causes are a blown fuse, or a blown thermostat / thermal cutout / TCO on the magnetron or on top of the oven cavity.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Accessing the oven cavity thermostat for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can download Jenn-Air (Whirlpool) owner's manuals and installation instructions here.
Dec 25, 2012 | Jenn-Air JMC8130DD Microwave Oven
Try2910227 serial ywmh2205xvb-0 model arcing on the back corner were the rack sits.Is there a way to repair this seen is the unit was purchaced in June of 2011.
Yes, take the rack out and recycle it. I do not know why these micro-wave company put racks in the micro wave ovens. You get some insulation on the inside the micro flaking off next the rack.
The mega-tron tube is a very high energy transmitter. The energy will come out of the top inside the micro wave oven in a wave guide. Micro wave energy that generation by the tube is high frequency into Gega Hertz. You have a metal tray in side the micro wave acts like a big capacitor it stores energy in form of heat the next you know it look like Marconi is putting on a lighting display.
Leave the wire tie on a loft of bread and put in you micro wave oven to defrost. The next thing you might see is a load bread burning, instant toast. ----The use of micro wave were invented by the British before WWII. The mega tron tube generation very high frequency radio wave and these wave struck an object 100 miles away some of this beam energy would balance back to a receiver-----You have Radar.... I wish you and your family well being and be careful of micro wave ovens it can burn from inside out. GB you...stewbison
Aug 22, 2011 | Microwave Ovens
Not heating
Remove the outer cover (pull the power plug first) and look for a blown fuse. If found, replace the high voltage diode and the 'stirrer' (a fan-like device located within the sheet metal wave-guide near the opening in the cooking cavity where the microwaves come into it). This stirrer has a plastic bearing that frequently arcs over and permanently shorts out the microwaves which blows the fuse. If no blown fuse is found, look for a loose or defective door-interlock micro-switch.
Nov 17, 2009 | Kenmore 61652 Microwave Oven
I'm getting a flash inside the oven and the plastic on the inside roof has a burn mark. I removed the plastic cover over the micro wave generator and it did not spark. is the oven dying? It is a 1983 0ver...
It looks like the metal part inside the oven is exposed to the high frequency rf waves. this may sound strange but try coating the metal part with fresh paint. remember no metal inside the oven will stand the waves created inside the oven the spark u see is the waves hitting the exposed metal part inside the oven
Oct 13, 2009 | Magic Chef MCD1311ST Microwave Oven
Model #MMV5100AAB built 01/2002 no power
Check the back panel for a breaker reset. If none, remove the case cover (pull the plug) and look for any blown fuses. If look ok, then check the interlock switch(es) for function when the door is closed. They are micro-switches and should make a distinct 'click' when operated. If you find a blown fuse, replace the high voltage diode in the magnetron power supply and replace the 'stirrer' (a fan-like device located under the sheet metal wave guide where the microwave energy enters the cooking cavity). It has a plastic bearing that can arc across inside it and short the energy out.
Sep 18, 2009 | Maytag MMV4205 Microwave Oven
Arcing inside and there is now a small hole on the panel side. Is this fixable?
It looks like there's lightning (arcing) inside my microwave When you see arcing inside your microwave, it's because of food or liquid left in the cavity or on the wave-guide cover:
  • If the wave guide has any burn spots, replace it and clean the unit well.
  • If the cavity has any burn spots, spot-sand it smooth and touch it up with microwave interior paint.
Note… If there are any burn holes in the cavity, don't use the unit-seek help from a qualified appliance repair technician.
Thanks for contacting Fixya
Jun 20, 2009 | Microwave Ovens
Micro wave broke
open the door and look on the middle top right inside the microwave is it burned or blackend?You have a faulty magnatron.if it is.
May 19, 2009 | Magic Chef MCD1311ST Microwave Oven
Paint damaged in side microwave oven
1) How is the cavity damaged? Is it just peeling paint, or is it rust? If it's rust then the microwave could be dangerous.
2) The antenna cap usually has a small hole in the centre, but if there are any other holes in it the magnetron itself could be damaged, and holes caused by the magnetrin arcing.
Mar 25, 2009 | Sharp R-820B Convection/Microwave Oven
Sparks, noise and burning smell
If it is burning and arcing at the antenna, it is probably arcing in the wave guide area. Probably will have to replace unit. I have had some success by removing the antenna, sanding and repainting the burnt areas of the cavity and sanding off any burnt marks on the antenna. Need to look at top of mag to see if also arcing there too.
Jun 16, 2017 | Panasonic NN-2555A Microwave Oven
Exhaust fan
the fan may be clean, may be fan bush struck thats why fan running not properly, check the internally inside the microwave oven , you should carefull inside micro wave oven very high voltage .
Aug 05, 2007 | Maytag MMV1153A Microwave Oven
Maytag MMV1153A Microwave Oven Logo
134 people viewed this question
Top Maytag Microwave Ovens Experts
William Miller
William Miller
Steve Allison
Steve Allison
Marvin
Marvin
Are you a Maytag Microwave Oven Expert? Answer questions, earn points and help others
