Mastering not in working how to check it
  • 32,281 Answers
These WEB sites have troubleshooting flow charts that can help you resolve your problem.
Computer Troubleshooting Flow Chart
https://www.lucidchart.com/community/examples/view/4d49913b-fa3c-4114-ab19-3fd20af9a3bf
http://www.daileyint.com/hmdpc/manual.htm
Posted on May 09, 2013
Rear window doesn't work
If it doesn't work with master switch or door switch, it is very common the the motor is out. When pushing either switch check for any type of noise In. The door. If there is no noise and it doesn't sound like it is binding up the replace the master switch on drive door. It is common that the master switch malfunction can cause system to short. Even though the door switch itself is not working, the door switch has to get its voltage from the master switch, so if the master switch is not working nether will the door switch
Mar 15, 2015 | 2008 Hyundai Santa Fe
No power to power windows
Have you actually checked for power at the driver's master switch?
I don't think there would be a window relay, there is probably a power window circuit breaker in the instrument panel fuse box.
If no windows work, pull the master switch out and check for one hot wire with key on. If none, check for broken wires in driver's door opening. Your ground for the windows will be in that group of wires too. Both must work for windows to operate. If you have power and good ground at the master switch, and no windows work, probably a bad master switch.
Jan 15, 2014 | 1986 Cadillac Eldorado
1998 toyota driver side window switch will not run any windows but lock button still works
"...when master switch remove, NO WINDOWS WORK"
This is correct--your master switch is part of the total circuit for all the windows to operate. Assuming the other windows work on their "relative" switches (passenger switch works passenger window etc.), you can assume this; it is not a relay problem. You only have one relay--a bad one would affect all window switches.
First, check your ground wires! Disconnect, clean (abrasively) and reattach)
Second, use a test light (starting at the master switch terminal) to determine if and why it's not getting voltage.
Jan 01, 2013 | 1998 Toyota Avalon
Lost security code, master code didn't work
To Unlock the Mobile from the Security Lock you can use the Master Reset Code,To get the Master Reset You can reach here http://www.prounlocking.com/unlocking-services/rs8wp6/ ,I unlocked my Nokia 6600 from the Security Lock using the Master Reset Code.......So You can check Master Reset Code For You Mobile there......To Unlock that Mobile from the Security Lock.
Nov 18, 2010 | Cell Phones
2008 corvette 11,200 miles on it clutch won't release
YOUR WARRANTY SHOULD FIX IT. SHOULDNT HAVE TO FIX YOUR SELF.POSSIBLE CAUSE CLUTCH MASTER CYLINDER FLUID LEVEL.IF LOW CHECK MASTER CYLINDER SLAVE CYLINDER LINES FOR LEAKS FIX AND BLEED CLUTCH HYDRALIC SYSTEM.IF CLUTCH MASTER CYLINDER FLUID LEVEL OKAY.THE CLUTCH DRIVEN DISC PRESSURE PLATE NEED ADJUSTMENT.I WOULD LET YOUR FACTORY WARRANTY FIX IT.YOU SHOULDNT HAVE TO PAY ANYTHING.JUST MAKE SURE FLUID IN CLUTCH MASTER CYLINDER NOT LOW WHEN YOU TAKE IT TO DEALERSHIP.IF THEY CHECK IT OUT FIND ANY KIND NEGLECT TO VECHICLE.THEY WILL NOT PAY.THEY WILL FIX BUT YOU WILL PAY OUT OF POCKET EXPENSE.
Oct 14, 2010 | 2008 Chevrolet Corvette
Abs kicks in at low speed and brakes wont work
CHECK BRAKE FLUID LEVEL MAKE SURE MASTER CYLINDER IT HAS CORRECT AMOUNT OF BRAKE FLUID IN IT.IF YES MASTER CYLINDER IS FAULTY OR AIR IN BRAKE SYSTEM.IF YOU CHECK BRAKE FLUID IN MASTER CYLINDER AND ITS LOW .CHECK FOR LEAKS AT BRAKE CALIPERS SEALS AND BRAKE HOSES. CHECK ALL WHEEL CYLINDER SEALS AND BRAKE HOSES AND ALL BRAKE LINES.
Mar 10, 2010 | 1999 Chevrolet Silverado 1500
Can't get front brakes to work
fill master cylinder, slowly close of brake lines to be sure you have pressure from master cylinder, pump brakes to check master, check that calipers were seated in housing properly
Aug 08, 2009 | 1997 Volkswagen Golf
Replace brakes. now they go to the floor. bled air
When you fixed the brakes, did you take the lid off the master cylinder. I just wonder if you spilled out your brake fluid. The only reason the pedal should go to the floor is if the brake fluid is gone or the master cylinder is not working. Check the fuse. Check the brake fluid level. The pedal only goes to the floor if there is no back pressure in the lines between the master cylinder the lines to the brake pistion on the calipers. Please give me a good ratin and keep me informed.
Jul 07, 2009 | 1999 Cadillac DeVille
My clutch wont engage it was working fine one day the next i had almost no resitance on my pedal
Check master for fluid level, check line going to slave unit, check slave unit (any leaks, you have found problem) If master is full, it may be internally bypassing in that case it may not leak but will not put pressure into the line. (fluid goes around piston instead of being pushed) If master is low and no obvious leak found, look under dash where clutch rod goes into the back of the master. you may find fluid there.
Apr 18, 2009 | 2001 Mitsubishi Eclipse
Clutch Problem
Check your Master Cylinder
Jul 15, 2008 | 1984 Pontiac Fiero
Computers & Internet Logo
64 people viewed this question
David Payne
David Payne
