Question about Garmin GPSMAP 541s
Garmin 541s rear tansducer does not read after plaining out
I have two Garmin 541s units on my G3 center console boat. The rear unit will not read after I plain out. Also the unit shuts itself off. Anyone get a fix on this problem. Wouldn't recommend Garmin on a boat.
    Champion:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 227 Answers
First of all it wont read after you plain out and as far as cutting off connect it straight to the battery see if that fix your problem
Posted on Dec 19, 2013
2 Suggested Answers
dcramer531
  • 1654 Answers
SOURCE: I have an old Marinetek
Unfortunatly that transducer will not work on the new unit. The sonar sensor is not compatible with this transducer and I would doubt it would even match up to the plug in the Garmin. These units are very propriatory and you will have to use the transducer that came with the machine or one that was specifically designed for the sonar unit. The transducer for your newer unit should be able to mount flush on the hull without having to pull your boat out of the water. These newer units have the capability to see through the hull without having to mount them externally.
Posted on Jul 29, 2011
I have a Garmin 2010c on my boat and turns off every 10mins.. what can be the problem?
Bad connection or a fault to the unit.
Do you have it on a separate battery? It is best if they are, or connect direct to the starting battery, not connected via power that you find in the console or on a power bar.
Make sure you are using good quality copper stranded wire of the correct gauge with soldered or properly crimped connectors. I think it is 18 gauge, but your installation instructions will guide you. Also mentions 24 AWG. Manual states;
Wiring
There are two wiring diagrams provided for you convenience. The first is a simple hook-up showing the GPSMAP 2006/2010 (using the 18-
pin wiring harness), the GPS 17 and the alarm circuit. The Alarm does not have to be wired for the unit to function. The second is a complete
wiring diagram showing the GPSMAP 2006/2010 (using the 18-pin wiring harness) interfacing with a variety of different equipment. The extra
5-pin wiring harness that came with the unit is intended for future interfacing features and does not require connection. Refer to the wiring
diagram that will best suite your needs. Make sure that all connections are good. For extra lengths of wire, 24
AWG (unless otherwise noted on
wiring diagram), shielded, twisted-pair wiring is recommended. We advise soldering all connections and sealing the connection with heat shrink
tubing. If you experience difficulty wiring the unit, please contact an installation professional in your area.
Make sure the connections are good on the rear of the unit including plugs to the transducer. You can coat with a little Vaseline which his electrically conductive.
States the unit is susceptible to RFI and should be 3 feet away from a radio antennae.
Finally, make sure the inline fuse and connections to it are good.
If all that seems good, the first thing to do is swap out the transducer for a new one. Still does it? Send the unit for repair.
Does it also do it at rest in the marina, or do you trailer the boat?
I have a Humminbird 998 HD Si.
http://static.garmin.com/pumac/47_2006_2010_GPS17Installation.pdf
Jul 29, 2017 | Garmin GPS
Hi, I just purchased a Garmin Approach G3 in New Zealand. My local course, Rangitikei Golf Club, should be loaded according to the Garmin web site but its not showing on my unit. Tried finding the course...
  • you may have to upgrade map data........how old is this unit?
  • have you loaded current firmware upgrades? more info would be appreciated......meder's tv service
Sep 24, 2013 | Garmin Approach G3 Golf GPS Receiver
What is causing the depth to keep blinking when my boat is on plane.sometimes the screen just shows a horizontal line where the depth should read. garmin541s brand new
First, make sure that the connection is good, clean, and tight on both ends of your transducer. Sometimes turbulance or temperature stratifications in the subsurface water will cause this. Also, check the specifications of your transducer. Some do not perform well while moving at high speed. One test, when on plane, when the problem occurs, slow the boat and see what happens to the readout. Repeat this several times. This should help narrow down what is causing the problem.
Sep 19, 2013 | Garmin GPSMAP 541s
My garmin gpsmap 182c works when I have the consol tilted on my boat but the turns off when I tilt the consol back down
Possible loose socket connection or power wire broken inside power cable. Bend the power cable with your hand while the unit is on and try to reproduce the problem
Jul 02, 2013 | GPS
Garmin 541s transucer, unit problems
Sound like the transducer is catching air.
May 10, 2013 | Garmin GPSMAP 541s
Garmin 440s just purchased can it be mounted on the console at an angle or does it have to be in line with the bow
You can mount it however you want. It shows movement by detecting the direction that its moving in. The only way it will be off is if your boat is going in one direction and the unit is traveling in a different direction.
Feb 14, 2010 | Garmin Gpsmap 440s Dual Frequency Combo
I have a 2002 21 ft sea pro with an unknown fuel
need more info, is it a center console? most sea pro boat 21.5 model the fuel tank is ether under the floor or under the console. both styles will have a manufacturing label on the fuel tank that list capacity. on a boat with the tank under the floor there will be service port holes so you can replace the fuel sender units. locate this service port hole and look for a label on the tank.
Oct 28, 2009 | Boating
Bought a garmin 760 gps on e-bay seller was a pawn shop and unit requires a pin numer to use unit. How do I clear old pin number and install a new one?
Unfortunately, even if you perform master reset on Garmin GPS unit, it does not reset Garmin Lock security feature, which password-protect most Garmin electronic devices to deter theft. If you forget the PIN or password unlock code to unlock the Garmin unit, the best solution is to bring it to Garmin to get unlocked. “Secure Location” does not unlock a locked Garmin unit either as it’s only a temporary fix as when it’s turn on outside the security location, the device is locked again."
So unfortunately, there is only one option: You have to send your nüvi into the Garmin, who can unlock it. Remember original receipt.
Apr 24, 2009 | Garmin Nuvi 760 Handheld GPS Receiver
Unit not working properly
G'day
I had a similar problem of the unit turning off when the engine was started.
I simply replaced the battery as the one one boat was only registering about 11 amps. This unit requires amps to be over 12 to maintain the readings. This fixed my problem at least.
If you are not getting a reading on the transducer you may need to make some slight adjustment on the transducer itself. Is it installed correctly? There is a manaul with pictures detailing the exact method of installing the transducer. It is very important you get this right.
Good luck mate
Noel
Dec 02, 2008 | Lowrance LMS-527C DF iGPS GPS Receiver
Navnet 500
I have been doing some research and I haven’t been able to determine if the Garmin has a compatible output for your Furuno. I can not recommend any service center particularly since I have no idea where you are located, but any good marine shop should be able to help you.
The Furuno uses NMEA Inputs for the GPS, and like I said I haven’t been able to determine if that Garmin uses that as an output. I would suggest that you inspect your installation to determine if there are any cableing between the two units. If no wires connect the two that you can be sure that the units are not communicating.
As far as the chartplotter goes you can buy data cards for them, either on-line or from a good marine supply store.
Apr 03, 2008 | Furuno NavNet vx2 1920C GPS Receiver
Garmin GPSMAP 541s Logo
107 people viewed this question
Top Garmin Boating Experts
TO Lady
charles
Are you a Garmin Boating Expert? Answer questions, earn points and help others
