Question about Lands Phones
Grundig Problems Change time
  • Trevor Scott May 08, 2013
    Found the solution. In settings found factory reset to default settings. Did that and resolved the time problem
    This was for Grundig hdmi hard disk TV recorder
How do you change the input without the tv remote?
I don't have a grundig tv, but most tvs have the buttons to change input / channel /volume ect. hidden, normally at the back along one edge, but some times along the bottom. My LG has them on the right hand side when looking from the front. Hope this helps.
Oct 28, 2015 | Grundig GU22DVDPX 22 in. LCD TV
Grundig how to
Never set remotes beside each other and leave the room. You never know what they might do when you not looking.
Actually, unfortunately if both remotes are using the same frequency for some options there is not a whole lot you can do to change the remotes themselves.
What you can do: block (lay something in front of) the stereos remote sensor location. Or turn the stereo it's self 90 degrees. This pretty much makes using the stereo's remote a pain, but you'll change the TV more often.
Jun 13, 2014 | Televison & Video
Grundig lcd tv standby stuck
Inverters use square wave voltage, which tends to stifle digital circuits. Leaving something stuck, or not working. Sure, the inverter will work for awhile, but then the rigid square wave eventually causes problems.
Feb 02, 2014 | Polaroid Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
Tv won't stay on
Hello ! this problem can come about if the video card has faults ie processor lickage or an i tem is burnt , processor over heating .
I recomend u change the video card
good luck
Sep 08, 2009 | Televison & Video
Grundig GU22DVD - Manual Instruction & cancel PIN Code
Please i have this Grundig lcd tv,model number GU22DVD,how to enter service mode to change sound standard PAL I toPAL BG,help me.
May 14, 2009 | Grundig GU19WDT 19 in. LCD TV
Grundig yacht boy 400 radio does not work with mains operations
I had the same problem. Examined the wire from the transformer,and found a break. Repair of the wire solved the problem. WLD
Mar 01, 2009 | Grundig YB 400PE AM/FM/SW Radio
Lands Phones Logo
13 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
