Question about Baby Gear
Logico s hp car seat has its straps stuck. I loosened them all the way to get baby in and now I can't pull them tight
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 158 Answers
Check under the seat and check to see if the strap is binding against another part of the seat.
Make certain the correct path for the harness is being used.
-- Marc
Posted on Jun 05, 2013
sgregg
  • 133 Answers
SOURCE: Shoulder restraint adjustment
theres a way in the back of the carset to unhook your straps and feed them thru the higher level. just look inside the back of the carseat.
Posted on Jul 31, 2007
SOURCE: I need to put the cover back on the baby's car seat and can't remember how! Help!
You've probably already figured this one out - but for any of you having trouble getting everything back together, might i suggest www.djgusa.com
YOu can search for the manual ONLINE to YOUR particular model number (right on the side of the car seat) - I have a car seat from a friend, so i didn't have a manual to consult - until NOW!
Posted on Jan 07, 2008
SOURCE: Graco nautilus 3 in 1 car seat need help with strap installation
Yeah its a bit tricky. ON the fron of the car seat there is a strap that goes intot he seat and has a button to lossen it. Press it down to lossen that strap then flip seat over and on the bottom you will find other end of the same strap and it has a brass t-fitting. Take it and pull it up the back side of seat and the shoulder straps fit into the brass fitting then tighten by pulling strap in front of chair.
HAve fun ;)
Posted on Jun 25, 2009
SOURCE: Maxi Cosi Tobi straps locked
hi i had the same problem so i took it back to toys r us where i got it from, they rang manufacture and were advised that they r going to recall them as it is a fault. hope this helps
Posted on Sep 19, 2009
  • 50 Answers
SOURCE: i need to put the shlder/lap strap back in
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
Posted on Jan 24, 2010
How to untwist the lower connector strap?
The only thing I can suggest is to rub some Vaseline on it and use two needle nose pliers to pull it free.
Oct 04, 2014 | Britax Baby Gear
Is there an adaptor for the logico s hp to fit to uppababy vista?
Hi
You should contact the manufacturers of the pushchair chassis to see if they produce / sell adaptors suitable for the carseat you wish to use. If there are adaptors, they will be made by the pushchair manufacturers.
Dec 04, 2013 | UPPAbaby Uppa Baby Vista Car Seat Adapter...
The straps on my maxi cosi tobi car seat wont adjust they are really tight and i cant slacking it where do you adjust the straps about?
hi
you have to pull the buckle towards you if they are still jammed check where the bottom buckle join the seat body to see if there is anything stuck in there if not i would recommend taking it back to the shop and get a replacement,
i had to do this just 4 weeks after buying mine the straps got jammed and i nearly broke little ones arms trying to get him out!
Oct 11, 2010 | Baby Gear
Maxi-cosi tobi strap tensioner not working. able to tighten straps when child is in seat but when buckle is pressed to release straps and get child out, unable to loosen straps tensioner will not let go.
Hi, Make sure that when you go to loosen the shoulder straps that the **** strap is pulled toward you, otherwise you cannot make the shoulder straps loosen, this is a safety feature. Hope this helps.
Jul 28, 2010 | Maxi-Cosi Baby Gear
Trying to change the strap size (shoulders) in the infant car seat that comes with the stroller.
Push in the buttom betweenthe front of his seat. While doing this pull the straps and they should loosen up :)
Oct 09, 2009 | Graco Baby Gear
Alpha Omega Elite
I haven't seen a video for it, but I'll try to explain it clearly. To install it with the LATCH system, locate the anchors in your car - U shaped metal anchors in the seat, where the back meets the bench part. See your car's owner's manual - many cars don't have LATCH in the middle of the back seat, so you'll have to install it in a side seat or use the seatbelt to install, instead. Recline the carseat all the way - there is a handle under the harness adjuster on the front of the seat. Pull the handle while pushing back on the top of the seat. Tuck the top tether strap under and hook it under the base or the seat - it's only used when forward facing and is dangerous if left flapping. Pull the seat cover off of the front corners of the seat. Thread the black latch belt through the rear facing belt path (the holes on the bottom front of the seat - there should be a sticker identifying the path), making sure that it does not twist and is behind, not over or in front of, the **** strap, but in front of the the slots that the bottom of the harness straps go through. Replace the seat cover. Put the carseat where you want it in the car. Look to see that the level lines on the shoulder belt positioning guide are level with the ground. Double check that the top tether is secured underneath the seat. Fasten one latch hook to the anchor in your seat, going from above the anchor, so that the clip part of the hook is on the bottom and the solid side is on top. Repeat on the other side. Kneel in the car seat to push it firmly into the seat while pulling the strap tight through the adjuster. The seat is installed tight enough when you can grab it at the belt path and can not move it more than 1 inch side to side. It is normal to be able to pull the top of the seat towards your car's seat back some. To install it with a seatbelt - (Please note - you can only install with the LATCH system OR the seatbelt - doing both together increases the stress and force on the seat and can damage it!) Recline the seat and secure the top tether as above. Place the seat in the car and make sure that the level lines are level with the ground, as above. Thread the seat belt through the rear facing belt path (again, the holes on the bottom front of the seat...look for the sticker). Thread it under the seat pad. Like above, it should go between the bottom slots for the harness and the **** strap. Buckle the seat belt. Kneel in the seat, pull the seat belt all the way out from it's feeder, and feed it back in, pulling it as tight as you can. Check for tightness as above. While your child is rear-facing, the harness should be in a slot that is even with or below his shoulders. Pull it snug - when it's tight enough, you shouldn't be able to pinch up any slack lengthwise at the shoulders or hips and it should lay in a straight line without any sagging. Make sure the chest clip is even with the baby's armpits, not over the neck or the belly. Good luck!
Nov 22, 2008 | Cosco Alpha Omega Elite 5-Point 22-155
HARNESS FOR FRONT FACING EVENFLO TITAN CHILD RESTRAINT
there is another thread on this.
Basically, locate the ends of the straps on either side of the seat. You can remove the plastic end thingy and take the strap out. Then re-thread the strap. Remember to thread it through the thin grey strap (which adjusts the tension of the main shoulder straps) as well as the little metal guide at the back of the chair.
Your problem may also be that the length-adjuster (thinner grey strap) is too tight. You can loosen it by pressing on the button located just in front of the main buckle and pulling on the shoulder straps. This is also how you tighten the shoulder straps - by pulling on the thinner grey strap.
Generally, the shoulder straps should come out around the childs shoulder level. Higher is ok. Lower is bad because it doesn't secure him in.
Oct 29, 2008 | Baby Gear
The straps are too tight on my child
Ok. First don't panic, I did the same thing with mine! lol. In the front of the seat where your childs legs hang, there is a velco flap. Lift it up and you'll see a metal button(but it doesn't look like a button). Push it in and at the same time pull one of the shoulder straps. This will loosen the strap. Then adjust accordingly. If you remove the back plastic piece you will see all the straps underneath if you want to eventually replace them. You can also adjust the height from the back if needed. Good Luck!
Oct 08, 2008 | Eddie Bauer 3-In-1 with Latch
Rear facing latch problem
I had trouble getting mine tight too and my sister said what she did was kneel in the seat and then pull up on the strap. I tried that and it worked! I think it pushes the seat down more so that you have more strap to pull.
Sep 16, 2008 | Eddie Bauer 3-In-1 with Latch
Baby Gear Logo
41 people viewed this question
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
