Question about GE Profile PDS20MBSWW 30" 19.5 Cu. Ft. Bottom-Freezer Refrigerator w/ ClimateKeeper System, ShelfSav...
What is mild climate - GE Profile PDS20MBSWW 30" 19.5 Cu. Ft. Bottom-Freezer Refrigerator w/ ClimateKeeper System, ShelfSav...
How many btus per sq ft for 1800 sq ft home
typically i like to go with 12,000 btu per 400 sq. ft. unless you have alot of insulation or live in a mild climate with low humidty
Sep 12, 2015 | Carrier Heating & Cooling
How to install heater core
chris go easy there, its a pain and its all labor. if you live in a mild climate bypass it, if not try to youtube it or go on ask.com
Feb 25, 2013 | 1992 Oldsmobile 88
What type of oil does my 2007 xterra use?
use any major brand 10W-30W in hot climates or use 5W-30W in mild climates, use no heavier weight oils
Sep 17, 2010 | 2007 Nissan Xterra Off Road
I was wondering what type if oil to use in my 1999 chrysler concorde lx 3.2L
If in a mild temperate region, 20W-40 will do. If you are in a very cold climate, then the viscosity must be lowered so the oil doesn't thicken up too much when the engine isn't running.
Aug 21, 2010 | 1999 Chrysler Concorde
What oil do you put in golf cabrilet 1994 2L just bought car
That depends on what climate you live in.
I live in southern British Columbia. it's very mild here all year round and the guy who taught me everything I know about vw's swore by 15w40 diesel grade oil. especially castrols' Tection extra
Oct 10, 2009 | 2001 Volkswagen Golf
07 compass oil type
For mild climates or cold climates use any name brand 5W-30W oil, u may also use 10W-30W if u prefer, for longer engine life use synthetic oil of the same weight, any name brand
Apr 10, 2009 | 2007 Jeep Compass Limited
What kind of oil and trans fluid
oil type is 10W-30W for mild climates, 5W-30W for cold climates or hot weather conditions.
The trans fluid type is DEXRON 4 (if still availiable) or better the new DEXRON 6, this fluid is either full synthetic or a blend and provides better trans performance and longer service life, Pennsoil makes a fairly cheap DEXRON 6, it is a blend...
Mar 13, 2009 | 2000 Jeep Cherokee
GE Profile PDS20MBSWW 30" 19.5 Cu. Ft. Bottom-Freezer Refrigerator w/ ClimateKeeper System, ShelfSav... Logo
15 people viewed this question
Top Refrigerators Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
