Question about BenQ E2200HD 21 inch LCD Monitor
Flashing screen flashing flickering and now is black
  • 1,684 Answers
This is a very common symptom of a failure of the filter capacitors in the power supply board. The monitor is repairable, you just need to replace the 7 capacitors on the power supply board. Here is information on the board and the capacitors needed to repair it.
http://www.ccl-la.com/catalog/product_info.php?products_id=331
Posted on May 09, 2013
  • 1 more comment
  • Dede May 10, 2013
    Hello again. It was most helful although I should have paid much more attention the info. my monitor 's model is T2200HD.Now that I have it open I was able to see a couple of Capacitors bulged and I intended to replace them. As per your suggestionsI was wondering if I could use the 1000uf 25V to replace the 1000uf 16V ? I was wondering if
  • Jeffrey Yu
    Jeffrey Yu Sep 17, 2013
    Hi Dede, I am wondering if your solution worked? I have the same model and looking for the right capacitor to buy online.
  • lena karlsson Oct 02, 2013
    if u got a monitor 2420 what kit do you need then or wich one fits also for my monitor benq 2420?
LED TV pulsing
How many have 'blinking' issue with Samsung led tv - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJan 26, 2011 - I am trying to get the number of people affected by this nagging blinkingissue with the latest Samsung led tv's. If possible it would be useful to ... Samsung LCD TV Screen flickering (LN55C630K1F)
Jun 11, 2015
Samsung LCD TV Has Flickering Horizontal Lines (Pic Inside ...
Jun 11, 2015
DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung LED with flashing standby light on front
Apr 17, 2014
More results from www.cnet.com
EASY How to Fix Samsung LCD TV Flashing Flickering ...
? 3:43
https://www.youtube.com/watch?v=i-jQZ-TQdgU
Jun 4, 2012 - Uploaded by Tampatec
How to Fix Samsung TV Flickering Blinks Flashing Flat Screen Picture ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical ...
Jan 18, 2016 | LG Televison & Video
HP5066 flickering
Return it to the dumpster. It is a lost cause.
May 03, 2017 | Televison & Video
Black screen Laptop. Flickers once on start. External Monitor works
Look for your computer's monitor settings, then adjust its refresh rate.
To modify a refresh rate on Windows, right-click anywhere on the Windows desktop.
Select "Properties," then choose the "Display Properties" tab on the window that appears.
Click the "Settings" option, then select "Advanced" from the window that appears.
Choose the "Monitor" tab, which lets you access a drop-down menu with the options for refresh settings adjustments. As a basic guide, use a setting of at least 75 hertz.
Confirm the change by clicking "Apply." Reboot the PC to ensure the new settings on the screen take effect.
Check your screen if the blinking problem is resolved. If not, try a higher refresh setting. If there is no change on the flickering of the screen, this means the problem is not caused by the screen's refresh rate. If your computer is not running on a battery or surge protector, shut it down to safely transfer the plug to another outlet Hope this helps.
Jan 15, 2013 | Computers & Internet
The screen is flickering
Call Samsung as on some of their models it is a known issue= on those a jumper needs to be removed from the power supply board, seems the wrong board was installed and is causing flashing on scene changes where brightness goes up and down.
May 27, 2012 | Televison & Video
The screen flashes whenever I move it around it looks like the scrren is off when it turns black.
As you say the the screen flashes whenever you move the laptop the issue might be with the internal connections. However, to isolate the issue with the software or hardware.
Restart the laptop, press F10 to enter into the BIOS screen. Then move the laptop and check if the BIOS screen flickers or not.
If the BIOS screen flickers then we can confirm that it is a hardware issue and your laptop needs to be serviced to fix this issue
Jun 15, 2010 | Computers & Internet
50" Toshiba Plasma screen is flashing with flickering sound
www.tacp.toshiba.com/tacpassets-images/.../42hp66_om_e.pdf
http://www.fixdevice.com/smanuals/file/31149.html
Above, download these Service manuals, it will show you how to troubleshoot, and identify what board to repair change.
May 05, 2010 | Toshiba 50HP66 50 in. Plasma Television
Pinstripe cinema display flickers on momentarily then goes black. Image comes back for a split second while when power light glows steadily then goes away while power light flickers. this is a 22"...
when the screen is black and the power light is steadly lit, shine a flash light at the screen. if you can see something, the inverter board is bad and the back light cannot turn on. if the power light flickers, reseat the power plug and put your ear to the back of the monitor where the power plug is. if you hear a buzzing or any high pitched noises; the power supply is bad. use the macufactures warranty for repairs.
Nov 18, 2009 | Computers & Internet
Philips 30PF9946 D/37
You have sound but no picture. Green power light is on and NOT flashing. You get a screen flash or flicker on power-up or even a minute of screen before going all black. It is your inverter board. Common problem on LCDs (maybe more so on Phillips?). They are easy to replace (unplug-plug) and are available on the net.
Veritas
Feb 24, 2008 | Philips 30PF9946 30 in. HD-Ready Plasma...
Monitor flashing
I have a similar problem with my screen, same one, 15". For a period of two years it would turn black for an instant and resume functioning. Since two weeks it only flashes the picture for an instant and then turns black again. We opened it up to check the wiring but nothing wrong there. We are 99.99% sure that the problem is in the screen itself and has nothing to do with drivers or anything else in the computer.
If you bought it less than 3 years ago and since it is probably a result of faulty construction, it should fall under warranty (by european law).
I am going to take mine to a repairman tomorrow, i will inform you wether the screen can be repaired or not.
Greetings,
Rengenier.
Oct 10, 2007 | LG Flatron L1715S 17" LCD Monitor
BenQ E2200HD 21 inch LCD Monitor Logo
154 people viewed this question
Top BenQ Computers & Internet Experts
JP Services
JP Services
Tony
Tommmix
Level 1 Expert
Are you a BenQ Computer and Internet Expert? Answer questions, earn points and help others
