Question about Cisco Cable Modem Dpq3212
How to get ssid for cisco modem dpq3212 - Cisco Cable Modem Dpq3212
How to connect two routers?
Use an unused port on the cisco to connect the second modem. You'll need to use a crossover cable to do this.
May 25, 2015 | Computers & Internet
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
Will not connect to cisco model dpq3212
Hi, Dale, can you describe your problem in detail? I didn't understand what your problem is. But hope this tutorial on Cisco DPQ 3212 can help you: http://www.cisco.com/en/US/prod/collateral/video/ps8611/ps8675/ps8682/7016882_C.pdf
Jun 11, 2013 | Zyxel NBG-4615 300Mbps Wireless-N Gigabit...
I lost the installation CD for my Cisco DPQ3212 router and need a link for the drivers.
Go to http://www.cisco.com/web/consumer/support/modem_DPQ3212.html#~drivers & select the one that best describes the model that you have &/or the operating system (such as Windows XP/Vista, etc.).
Nov 30, 2012 | Cisco Cable Modem Dpq3212
WL330 achter een cisco modem als repeater
dat heb ik ook mee geworsteld. kan alleen als je de beide beveiliging op wep open heb staan,dus geen wpa. dus wep open, een SSId naam,mac adrees invullen van de repeater in bij de modem en andersom,zelfde kanaal hanteren en zelfde wachtwoord . het is echter zo gebeurt als je weet wat je doet.
Nov 28, 2012 | Computers & Internet
SSID for Cisco Valet
SSID is the wireless network name
Feb 20, 2012 | Cisco Valet Wireless Hotspot (M10)
WVC210 CISCO PTZ camera... i can access through ethernet but can't access through wireless. I had tried installing in the sameway specified in the manual.
I had the same problem. Here was my successful solution:
reset the modem
only change the SSID (do not activate the security yet)
reset the camera
install the camera
set the static ip address
set the SSID to match the modem and save settings
unplug the power and the ethernet to the camera
plug in the power to the camera and wait for the lights on the front are illuminated
go back into the camera and set the security settings
go into the modem and set the security settings.
I hope this works.
Jul 07, 2011 | Cisco WVC210 Network Camera
Changed modems from motorola to a cisco for faser internet. Printer will not link up. It can see the modem and pin has been entered. no connection!
Is the printer is connecting wirelessly, the you may need to redefine it on the printer. There are two possibilities :
If there is a key defined, make sure your printer has the correct key (aka passphrase) defined on it.
If there is no key and it is an Open SSID, then you can go for FACTORY DEFUALT settings on the printer if it not an issue and again configure the settings on the printer.
Also a power cycle can help the printer to re-associate with the new CISCO AP.
Mar 12, 2011 | Kodak ESP5250 All-In-One InkJet Printer
I have a Cisco E1000 N Router. Is it possible to have multiple SSIDs? for example, Can I have a network SSID for inside my home for multiple computers/printers and then another SSID for guests?
The SSID (Service set Identifier) is the NAME you give the wireless network (the Name of the router) and you can only have one.. BUT you can have a seperate password (key) for guests to access the router.
Feb 07, 2011 | Cisco Linksys E1000 WirelessN Broadband...
Cisco Cable Modem Dpq3212 Logo
111 people viewed this question
Top Cisco Computers & Internet Experts
Prashant M
Prashant M
brian soufane
Are you a Cisco Computer and Internet Expert? Answer questions, earn points and help others
