Garmin gps troubleshooting
I get a sreen that says press the button and it keeps moving to different spots on the screen
  • 7,627 Answers
You may want to post to the correct category for a GPS expert, all I can do is post the Garmin Support website: http://www.garmin.com/us/support/
Posted on May 08, 2013
It is working ok but the screen is too bright, without adjust Is it a hardware or software problem? thanks
You should be able to adjust it using Tools - Brightness. If you can't it is more likely a software glitch, as long as all the other touch controls on the screen work.
You can update the software here.
http://www8.garmin.com/support/collection.jsp?product=010-00782-20
You can also do two types of reset.
How to Reset a Garmin 1350 by Kefa Olang, Demand Media Whether you're on a local or national business trip, a Garmin Nuvi 1350 GPS can help you find your way around. However, if the device is not functioning as expected, performing a reset is a troubleshooting step that can solve common problems. A soft reset reboots the GPS's hardware without deleting saved data, but a master reset clears saved data and settings to restore the device to the factory state.
Step 1 Press and hold the "Power" button for a few seconds to reset your Garmin Nuvi 1350 if it's not performing as expected. This soft reset reboots the device's hardware without deleting saved files.
Step 2 Turn off the Garmin Nuvi 1350 if you're still experiencing problems, and then disconnect it from a power outlet, if it's connected to one.
Step 2
Touch and hold the lower-right corner of the screen while powering on the device. Release the power button when the screen turns on, but keep pressing down on the screen. Step 4 Touch "Yes" when the "Do you really want to erase all user data?" message appears on the screen. If the text is in another language other than English, touch the button on the right to confirm your selection.
Step 5 Wait for the GPS to reset automatically, and then follow the on-screen guided prompts to reconfigure it.
Jan 15, 2016 | Garmin nuvi 1350 Car GPS Receiver
Garmin troubleshooting
on the "Where to" screen look for "near" or "searching Near", press on that and you can choose a different search location. otherwise you may have the wrong region installed. use Garmin Express to change coverage regions
Jul 12, 2014 | Garmin nuvi GPS
Zumo550 I use this unit on my motocycle I ride in rain and cold when I press letters on the screen diffrent letters show up also I notice some small inperfection shows under the screen sreen is going...
Have you tried recalibrating the touchscreen?
To calibrate the screen of the Zumo 550, press and hold the power button for about a minute until the screen calibration appears.
Sep 21, 2013 | Garmin zumo 550 GPS Receiver
Mio moov 300 screen alignment problem
Download the user manual online and look for factory resettings. Follow instructions and it should work. On my Garmin, the same thing happened. On Garmin, you turn the unit off, press and hold the top left corner of your screen, and turn the unit on while pressing the top left corner of the screen. You wait for 10 seconds and a black dot appears and requests you touch it. The dot moves around the screen and you keep touching it. Once done, your screen perimeter is identified and all the letters fall in place when you press them. Good luck!
Dec 02, 2012 | SNK Mio Moov 300 GPS Receiver
Troubleshooting garmin nuvi 1300t
Contact me at: dworakowski.lukasz@gmail.com
Oct 24, 2011 | Garmin nuvi 1300 Car GPS Receiver
I bought a Garmin 1450 but Ican't seem to register
  • To register your garmin you connect it to your computer with the mini USB cable
  • Go to www.garmin.com and select your country from the drop-down list
  • Click on the "myGarmin" tab at the top of the screen
  • Click on "Register your garmin product" at the left side of the screen
  • Click on "Automotive" and follow the prompts.
You'll be asked to create a username and password. Keep them safe as you'll need them anytime you want to update your maps.
If you want to set a PIN number on your satnav which it will look for each time you turn it on;
  • Press TOOLS on the bottom right corner of the screen which shows WHERE TO and VIEW MAP
  • Press SETTINGS
  • Press SECURITY
  • Press GARMIN LOCK
It will ask you for a 4 digit pin. Also you'll be given the option to set a secure location. Be sure to do so and use a place that you can get to easily and where you have around 20 feet clear space around you. If you forget the PIN number the only way to remove the pin is to go to this secure location. As the GPS is not 100% accurate when you return to this location the satnav may think you're a few feet out and you may need to move around for it to unlock. This is why you need the space around where you set it.
You can get a user manual from http://static.garmincdn.com/pumac/nuvi_1100_1200_1300_1400_OM.pdf
Jul 14, 2011 | Garmin nuvi 1450 GPS Receiver
My touch screen will not function. It seems to start okay but the touch screen wont work from that point. I have reset. Garmin NUVI
Turn off the device.
Press and hold the upper-left corner of the screen and turn the power on.
Keep holding the screen and release the power button when the screen is on. Keep holding the screen for next 30 secs and u will see a "press button" on the screen.
at that point release the screen from upper-left corner and touch the press black point on the screen to calibarate it.
should be fine after that.
thanks
Jul 29, 2010 | Garmin Nuvi 660 GPS Receiver
Gramin GPS screen not responsive
Hi,the problem you are experiencing with your GPS device can be solved by simply recalibrating the screen.this is how you recalibrate the screen of your device;
1.Touch "display" .
2.Touch the "recalibrate" button,then follow the on-sreen instructions,until you are done.
Thanks and take care
Apr 22, 2010 | Garmin nuvi 750 GPS Receiver
Broken Garmin GPS Nuvi 300 Touch Screen
I know of this site where your screen can be replaced.
http://www.sharc.net/nuvi_LCD_repair.htm
Mar 03, 2008 | Garmin Nuvi 660 GPS Receiver
GARMIN c550 will not turn on
There is an ISSUE with the DEAD ZUMO, however some of the are solved, and some need to be shipped back.
There are a couple of options.
1) remove the battery, keep power button pressed for a few minutes. install battery, try.
2) fully recharge the battery with the wall charger, try
3) With a fully charged battery, press and hold the + button and press the power button(hard reset).
4) hold thumb firmly on top left of touch screen and hold power button till it switches on(hard reset).
5) Try a different battery (fully charged)
6) Ship it to Garmin
Sep 08, 2007 | Garmin zumo 550 GPS Receiver
Computers & Internet Logo
35 people viewed this question
David Payne
David Payne
