Help getting the ssid for my cisco cable mode dpq3212
  • 7,627 Answers
Want to get my Cisco guest password
Open Cisco Connect then click Guest access. The password is displayed under the Password header.
To go to the Guest access option using Cisco Connect, follow the steps below:
Step 1: Select Guest access at the main screen of Cisco Connect
In the Guests access settings window, you can enable or disable the Allow guest access, change and check the password for the guest network, or change the number of Total guests allowed.
NOTE: The Guest network name is the main network's SSID with -guest as a suffix. If you want to change the guest network's name, you will need to change the main network's SSID.
Dec 29, 2014 | Cisco Linksys E1000 WirelessN Broadband...
Tip
Changing Channels on your Routers.
You may try to use different channels on the router to get a better signal. Follow the steps below how to change channels on your router:
1. Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2. Once your browser opens, input http://192.168.1.1 into the "Address bar".
3. You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Cisco Interface (if the setup page has a Cisco Logo)
Go to Wireless Tab
SSID: (e.g. Vic or your name or last name)
Channel: Any from 1-11
Then hit Save Settings.
Regular Linksys Interface (if the setup page has no Cisco Logo)
Under Setup:
Then hit Apply
After doing this you should have a better Wireless signal from your router....
on Jan 03, 2010 | Linksys Wireless-G WRT54G Router
Tip
How to change Wireless Channel on LInksys Routers...
Try to use different channels on a wireless router to get a better signal. Follow the steps below how to change channels on your router:
1.Connect your computer to the router via an Ethernet cable and open your web browser (normally Internet Explorer, which can be found on your desktop or on the Start Menu in Windows XP).
2.Once your browser opens, input http://192.168.1.1 into the "Address bar".
3.You'll be prompted for a User Name and Password. Leave the User Name blank and type in admin as the password.
Go to Wireless Tab
SSID:(e.g. Vic or your name or last name)
Channel:Any from 1-11
Under Setup:
Then hit Apply
Hope this help everyone.
How to enable wireless on compaq laptop
password for wireless is not the same as your windows password. log-in credentials are usually found on the router. try looking at the bottom to find default user name and password
Nov 25, 2017 | HP Compaq 6910p (GU888US) PC Notebook
Will not connect to cisco model dpq3212
Hi, Dale, can you describe your problem in detail? I didn't understand what your problem is. But hope this tutorial on Cisco DPQ 3212 can help you: http://www.cisco.com/en/US/prod/collateral/video/ps8611/ps8675/ps8682/7016882_C.pdf
Jun 11, 2013 | Zyxel NBG-4615 300Mbps Wireless-N Gigabit...
How to config to work wireless
bridge irb
interface Dot11Radio0
no ip address
broadcast-key vlan 1 change 45
encryption vlan 1 mode ciphers tkip
ssid cisco
vlan 1
authentication open
wpa-psk ascii 0 cisco123
authentication key-management wpa
ssid ciscowep
vlan 2
authentication open
ssid ciscowpa
vlan 3
authentication open
Step 5 bridge-group number
Example:
Router(config-subif)# bridge-group 1
Assigns a bridge group to the subinterface.
Note When the bridge-group command is
enabled, the following commands are
automatically enabled, and cannot be
disabled. If you disable these commands
you may experience an interruption in
wireless device communication.
bridge-group 1
subscriber-loop-control
bridge-group 1 spanning-disabled
bridge-group 1
block-unknown-source
May 21, 2013 | Cisco 878 GSHDSL Wireless Router for Small...
I lost the installation CD for my Cisco DPQ3212 router and need a link for the drivers.
Go to http://www.cisco.com/web/consumer/support/modem_DPQ3212.html#~drivers & select the one that best describes the model that you have &/or the operating system (such as Windows XP/Vista, etc.).
Nov 30, 2012 | Cisco Cable Modem Dpq3212
SSID for Cisco Valet
SSID is the wireless network name
Feb 20, 2012 | Cisco Valet Wireless Hotspot (M10)
Configure cisco aironet wifi
if ur using IOS autonomous AP, then u'll need to configure the bvi interface to get an ip address and then enable the interface. once it has an ip, u'll need to configure the ssid, vlan, etc - choices include doing so with the CLI or web page GUI. U'll need to enable the built-in web server then u can access it via the web interface to setup the ssid, any vlans, radius, etc. good luck.
Jan 17, 2008 | Cisco Aironet 1131AG 802.11a, 802.11g/b...
Connecting router into a several computers
if u r going to connect ur pc through wired no need to install any thing>run a cable from pc to the ether net jack on the cisco router and it will start working>u need to use rj-45 cables>
if u r going to use pc's through wire less then u need to login to ur router and change the SSID name as ur wish and enable the ssid broadcast>and change the channel 1 or 11>and save that >and restart the wire less pc's>and in the pc right side down corner u can see wire less i-con>click that and click on view avaliable net works>and search for the SSID that u changed in the router screen and click on connect rate me solved if its help thx
Nov 11, 2007 | Cisco (WS-X3011) Router
Computers & Internet Logo
112 people viewed this question
David Payne
David Payne
