Question about LG Flatron Computers & Internet
E1941 flatron Screen has very light lightly flickering 'waves' on the screen.
4 Suggested Answers
  • 62 Answers
SOURCE: screen flickers
1. main capacitor 220mf / 420v .
2. drypoints on monitor kit.
3. electrical distabence.
Posted on Nov 26, 2008
  • 16 Answers
SOURCE: my LG 2234 flatron widesccreen
You have a power supply problem - 99% certainty here, as I am using a flatron monitor which had the same problem when I got it. There have been many solutions posted here regarding flat screen monitor power supply repair, which is a problem common to the monitor class, not just the brand (I also use an HP and an Acer which I repaired for the same problem). I refer you to a recent solution posted by FixYa guru budmrtn: http://www.fixya.com/support/t7497516-delayed_startup_lg227wtg_progressed.
His solution provides links to a wealth of photos and knowledge. I have reviewed his documentation and can find no fault in it.
Posted on Jan 06, 2011
budmrtn
  • 11361 Answers
SOURCE: my LG FLATRON L1770HQ screen
Look for bad caps with domed tops in the powersupply/inverter board. See LG and other failed monitors albums.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Apr 12, 2011
My Kyocera hydro wave C6740N started flickering with what seems like static and little lines through my whole screen.the My question is "Is there any solution to fixing my problem? No water damage
My phone malfunctioned a few weeks ago to fix it they had ...
www.fixya.com/.../t26009599-phone_malfunctioned_few_weeks_ago_fi...
2 hours ago - my Kyocera hydro wave C6740N started flickering with what seems like static and little lines through my whole screen.the My question is "Is ...
Kyocera hydro system recovery? ' Android Forums
androidforums.com > ... > Kyocera Hydro > Root - Kyocera Hydro
Jan 2, 2015 - I rooted my hydro and installed beats audio but now my sound does ... of something like this happening... without a working recovery like CWM.Missing: flickering ‎static
Dec 16, 2015 | Kyocera Cell Phones
How to repair flickering picture
First see if the automatic room light level sensor is on. If it is, try turning it off in the setup screens.
Jul 16, 2014 | Proscan PLCD3992A 39 in. LCD HDTV
Toshiba 32AF45 CRT TV Distortion and Flicker During Moments of High Contrast?
Check its main power regulator section circuit. Replace all the electrolytic capacitors there. This is a power supply fault.
Mar 21, 2013 | Toshiba 32AF45 32" TV
Car not starting, battery charged by son's car, still wont' start.
More than likely its your ignition switch going or gone bad. Ok, here's what you do, turn the key to the on position but DO NOT CRANK, let the key stay in this position until the security light stops flashing (takes 5 to 10 minutes) then turn the key off and crank it immediately after. If your car cranks then you will need to replace your ignition switch ($120 to $160). Hope this information helps someone. .
Jan 22, 2013 | 2001 Chevrolet Impala
Flickering screen like bad flouresent bulb
you need to remove the back cover of the tv to gain access the internal part. and then you need to look if their is a loose contact or dry joint connector at the power inverter board for the screen back light. if the connection is good then their is a flickering the back light is need a replacement.
Nov 12, 2012 | Televison & Video
Hi..i am using compaq presario cq 40 and screen is flickering.i had it checked and they told me lcd is the problem but they didnt even bother to check.they just turned it on and they told me that i have to...
When it flickers, can you still see the text when the screen goes dark?
May have to use a bright flashlight set right on the display to see
the text on the screen beside where the light sits.
That will tell you if it's the backlight.
You can also look at a grazing angle into one of the edges to see if the
backlight is flickering when the display does.
When it's cold, does it start with a slight pinkish color? That can be
a sign of backlight going bad.
Anything interesting happen when you flex the cable by moving the screen?
I'm not saying it's impossible, but I've never seen software cause
consistent screen flicker. And if the vga port doesn't flicker, sw is
even less likely the problem.
If you bet the odds, you'd bet on a bad display cable.
Won't hurt to try replugging it.
If that doesn't help, then your monitor may be dying....
Jun 20, 2011 | Computers & Internet
HP Pavilion dv2000 Screen Flicker
Please replace the screen for optimal performance.
Do rate this.
Feb 25, 2009 | HP Pavilion dv6000z Notebook
Computers & Internet Logo
Top LG Computers & Internet Experts
Michael Vincent Cruz
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
