Question about Frigidaire ATF6000ES Front Load Washer
Belt Changed the belt on my front load washer and now it wont stay in place why
  • Official Brand Answer
  • 4,342 Answers
Hello Stephannie - Based on what you are describing, more than likely the belt is not aligned properly on the pulley or on the motor shaft. If possible, try lining the belt up with any pre existing marks or grooves from the original belt. If it proves to be ineffective, I would recommend reaching out to a qualified technician to proceed further with the repair(s) or installation of the belt.
Posted on May 10, 2013
Drive belt came off now wont stay on
If the drive belt came off and wont stay on, either the Drum Bearings are gone, or the large pully is buckled.
Oct 19, 2014 | Hotpoint Ultima WF860 Front Load Washer
Frigidaire washer GLTF2940ES wont spin out
does it spin at all? It does have a belt, so that's the first place to look. If it does spin some, you probably have a bad control panel.
Jan 25, 2011 | Frigidaire GLTF2940ES Front Load Washer
The motor doesnt turn the washtub.
Remove the back and see if the belt is still in place,the drm is inclosed,unplug before removing back
Jul 07, 2010 | Frigidaire GLTF1670A Front Load Washer
The belt on our front load moffit washer wont stay on.boght a new one.same thing. fustrated.
Only explanation is the bearings in your tub are faulty causing a missalignment of the belt. Possibly there might be an issue at the motor side. Inspect carefully for possible problem.
May 21, 2010 | Washing Machines
I need to know how to install the new belt
The following link explains how to install the belt on a Whirlpool Duet front loader:
http://www.fixya.com/support/r3059652-drive_belt_installation_whirlpool_duet
This is an easy process, but it may take some effort to get the belt on the pulley. It is designed for a tight fit in order for the belt to stay in place on the tub pulley with no play in it. There is no tensioner and you do not loosen any motor mounts. Just make sure you hold the belt tightly in place with your hands and turn the entire tub pulley (like a steering wheel) in a clock-wise direction. The belt will stay on after you turn the pulley far enough for it to grip and stay in place.
If you have not purchased a replacement belt yet, the part number for the model you have this listed under is 8181670.
If you have questions, please let me know. I hope this helps you.
Oct 19, 2009 | Whirlpool Duet GHW9150P Front Load Washer
My front load kenmore 417-44072300 wont agitate or spin
you have a belt broken, drain out the water and take the back of machine off and you will find the belt then go to a place that sellls appliance parts andget a new one
Jul 18, 2009 | Kenmore 43042 Front Load Washer
Drum wont turn and belt disconnected. how to rebelt.
you need to remove the front, place new belt around drum and then over pulley.belt should be tight against drum hold drum with out getting cut and let run while holding it to see if the belt is on correctly if not tryt again. once belt stays on then replace front and your done
Jun 22, 2009 | Kenmore HE2 Plus Front Load Washer
Belt amana washer replace mod lw6501w2
I have a similar amana top load washer and just changed the belt. Here are the steps I used to change the belt:
1) Unplug the washer
2) Slide the washer away from the wall about 12"
3) Remove two screws from the bottom of the front panel, slide the front panel down (there are 2 metal tabs that slide into slots on the top of the front panel - observe how they slide into/out of the slots). Set the panel aside.
4) Remove the electrical connector (upper left of motor). Press down on the top of the plastic connector - this will undo the catch hook holding the connection in place). Observe how the belt is routed before proceeding.
5) Remove 4 bolts holding the motor in place. You can remove the motor - even with the water pump and hoses in place - they will flex.
6) Remove the water pump from the motor. There are 3 torx - head screws to remove. Note: You will need a star shaped (torx) head driver (Looks like a screwdriver but with a "star" head on it. The one I used measured just under 3/16 in diameter.
7) carefully remove the water pump. - remove the old belt from main pulley under washer drum and also from the water pump. Insert the new belt - be sure to put the tension pulley on the outside of the belt.
8) Reinstall the water pump to the motor. Reinstall the motor. Route the belt correctly in the water pump body area first - them slide the belt around the left side of the main drum pulley - rotate the pulley counter-clockwise and the pulley will tug the belt onto the pulley. Once in place - check bolts and belt - then reattach the electrical connector (remember to press the plastic lever on top of the plastic connector before sliding it in place). Reattach front panel - slide the top of the panel onto the metal tabs - then attach screws at the bottom.
Feb 23, 2009 | Amana 3.2 cu. ft. Top-Load Washer
Neptune mah4000aww belt wont stay on drive wheel
lost you on chat you closed the window
plz email me
Mar 03, 2008 | Maytag MAH6500 Neptune Front Loading...
Frigidaire ATF6000ES Front Load Washer Logo
35 people viewed this question
Top Frigidaire Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a Frigidaire Washing Machine Expert? Answer questions, earn points and help others
