Question about HP ProCurve Switch 2510G-24 24-Port Gigabit (J9279A#ABA)
Ip address 24x10 - HP ProCurve Switch 2510G-24 24-Port Gigabit (J9279A#ABA)
2626 default ip procurve
HP 2626 do not have a default IP address, you have to set the IP address on an enterprise class business switch. You can find the manual for your switch at http://www.hp.com
Dec 23, 2013 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
What is the default ip address for the procurve 2124
Procurve switches do not have a default IP address. you must put an IP address on the switch. You can find a manual for your switch at http://www.hp.com
Nov 18, 2013 | HP ProCurve 2124 (J4868A#ABA) 24x10/100...
My D-Link DES-1024D can't assign ip addresses to client computer automatically anymore. how will i resolve it?
You switch does not provide DHCP services (assigning of IP Addresses). That is done by either your router or a server on your network.
Mar 23, 2011 | D-Link DES 1024D (DES-1024D) 24x10/100...
What is the default ip address for dlink 3226?
The Switch's factory default IP address is 10.90.90.90
with a subnet mask of 255.0.0.0 and a default gateway of 0.0.0.0.
Often set up by rs232 connection
See
ftp://files.dlink.com.au/products/DES-3226S/QuickInstallGuide/Generic_QIG_for_Managed_Switches_v1.03.pdf
and
http://support.dlink.com.au/Default.asp
Apr 20, 2010 | D-Link DES 3226 (DES-3226) 24x10/100 Mbps...
I need to config a hp procurve 2610 with a data and voice vlan to work with my mitel.
hostname "Switch1"
qos dscp-map 101110 priority 6
snmp-server community "public" Unrestricted
vlan 1
name "Data_Vlan"
untagged 1-28
ip address 192.9.180.19 255.255.255.0
exit
vlan 2
name "Voice_Vlan"
ip address 10.9.180.5 255.255.255.0
qos dscp 101110
tagged 1-28
voice
exit
Program the port that the PBX is in as a untagged port on Vlan 2
Nov 30, 2009 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Can not telnet to my intel 510t switch because I do not have the ip address for it , how do I enter it to configure it.
With the Intel Device View wizard, you don't need to know the IP address. Manual at:
http://dl.owneriq.net/a/a5b2f147-ee86-4f08-b080-337e0ea7a1b3.pdf
Software at:
http://www.intel-driver.com/Intel-drivers/driver_119.html
Oct 25, 2009 | Intel Express 510T (es510tn) 24x10/100...
How to assign IP address to HP procurve1800 switch?
The 1800 series do not have CLI so you should connect directly to any RJ-45 port.
I quote from the installation guide:
"In the factory default configuration, the default IP (Internet Protocol) address of the switch is 192.168.2.10 and the subnet mask is 255.255.255.0"
So set your PC IP address in the same subnet and access it through your web browser. If it has not the default configuration, interconnect the switch ports 1 and 2 and reboot it.
Hope this helps,
take care
AFO
Dec 31, 2008 | HP ProCurve 2626 (J4900B) 24x10/100 Mbps...
Switch IP
Hi, the ports themselves don't have an IP address. The switch has one IP address for online configuration. this model does switching only and doesn't use DHCP to issue addresses
Feb 20, 2008 | Cisco Catalyst 2950 24x10/100 Mbps...
Network
Follow these steps
example
int serial0
ip address 192.168.1.1 255.255.255.252 ( give 1.2 to other end)
ip address 192.168.2.1 255.255.255.252 secondary ( give 2.2. to other end)
ip load-sharing per-packet
ip route destination network destination mask 192.168.1.2
ip route destination network destination mask 192.168.2.2
GOOD LUCK
Jan 07, 2008 | Cisco Catalyst 2950 24x10/100 Mbps...
HP ProCurve Switch 2510G-24 24-Port Gigabit (J9279A#ABA) Logo
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
