Question about Konica Minolta Magicolor 2530 DL Laser Printer
Drum cartridge not attached - Konica Minolta Magicolor 2530 DL Laser Printer
2 Suggested Answers
scvm
  • 11 Answers
SOURCE: It says Drum Cartridge not attached, but the drum
not a solution, but I'm working on a 2430dl with exactly the same problem.
Posted on Jul 21, 2010
How to replace copier drum Cleaning Blade UCLEZ0069FCZZ
Improper installation may damage the copier. Before disassembly, be sure to disconnect the power cord for safety. 1) Remove the drum cover. (4 Lock Tabs.)
2) Remove the drum fixing plate and the photo conductor drum.
•Dispose the drum fixing plate which was removed.
3) Check the cleaning blade and the red felt for damage.
•If there is damage, go to step 5
•If there is no damage, go to step 12
4) Remove the main charger. (Cleaning the screen grid and the sawteeth.)
5) Remove the cleaning blade.
•Dispose the cleaning blade which was removed.
6) Clean the cleaning section and the waste toner pipe to remove waste toner completely with a vacuum cleaner.
7) Remove the felt and duplex tape completely.
•Be careful not to scratch or bend the sub blade.
8) Attach the cleaning blade.
•Securely insert the plate section of the cleaning blade into the unit and fix it with a screw.
•Do not touch the cleaning blade rubber with your hand.
•When attaching the cleaning blade, press the cleaning blade in the arrow direction and attach.
9) Attach the felt.
•Attach the mocket with slightly pressing section A of the cleaning blade.
•Do not touch the tip of the cleaning blade.
•Do not put the mocket under the cleaning blade.
•Do not put the mocket on the sub blade.
•Do not press the sub blade with the mocket.
10) Attach the main charger.
•Securely set the MC holder on the projection of the process frame.
•Securely insert two projections of the MC holder into the groove in the process frame.
•When attaching the MC holder assembly, be careful not to make contact with the cleaning blade.
11) attach the drum fixing plate and the photoconductor drum. Apply grease to the inside of the photoconductor drum. (Diagram 2)
•Attach the drum from (b). (Prevention against the sub blade edge breakage)
•Attach the drum so that its position with the sub blade shown
12) Attach the detection gear.
•The detection gear is not installed to the drum cartridge package with the main body. Add a new one.
13) Attach the drum cover.
•After attaching the drum cover, do no make a copy
•When attaching the drum cover, engage the detection gear 20T rib with the 30T gear rib, and attach the drum to the process frame.)
14) Important.
•Insure proper drum rotation by rotating the drum counter-clockwise (as viewed from the front)
•If the drum does not rotate with reasonable effort the drum blade may need to be re-positioned or lubricated with a small amount of toner.
Dec 16, 2010 | Sharp Office Equipment & Supplies
Drum maintenance
i;m not sure what your question is, but if your getting a drum error, it could be one of 2 things.
1. you need to clean the wires on the drum, there is a purple tab that slides back and forth that cleans wires.
2. you need to replace the drum. take the toner cartridge out of the unit, separate it from the drum, replace the drum, re-attach toner cartridge to the drum, and re-insert the toner back into the printer.
thanks
Jun 06, 2010 | Brother MFC-7420 Laser Printer
The drum unit has been replaced but the drum warning message is still flashing. How do I reset? Have tried user RAM clear but that did nothing.
That should have reset itself. A couple of things. You may have received a bad cartridge and need to report it as DOA, from wherever you purchased it.
Also, sometimes if you replace the drum when it says : Drum unit low or reorder Drum, and you replace it before it tells you to replace the drum, it will not reset.
There is a fuse that blows quickly and resets the counter. That may not have been attached right and not the machine did not detect a new cartridge.
Feb 18, 2010 | Xerox WorkCentre Pro 635 Laser Printer
It says Drum Cartridge not attached, but the drum cartridge is, in fact, attached.
Oct 13, 2009 | Konica Minolta magicolor 2430 DL Laser...
I have a message that says "Change PC Drum". What is that?
This is telling you to replace the "DRUM" of the printer. This is different from the "TONER". Normally, the drum is attached to the toner cartridge. Check your printer documentation. You may be able to purchase a drum/toner kit. Drums last longer than Toner cartridges so you will replace the Toner cartridge more often than the Drum.
Jul 28, 2009 | Minolta bizhub 200 All-In-One Printer
"Change drum soon mean" in my 7820n?
drum and cartridge are two different things. The cartridge is attached to the drum. They do need to either be cleaned with rubbing alcohol and cotton swab. You can try to clean out the connections. But many o require replacement.
Jul 02, 2009 | Brother Office Equipment & Supplies
Grey streaking on printed pages
Laser printers are charged using a drum which produces an electrostatic image. The drum could be unable to hold all of the 600v charge or be be scratched if the streaks are always in the same position the the drum is not holding the charge for the toner to attach to and therefore the drum is faulty and beeds to be replaced
May 20, 2009 | Brother HL-2040 Laser Printer
Reseting drum cartridge on xerox 3535
Yes I m drincopy from Kosovo i reseting oall drum for xerox
Valdrinjashari81@hotmail.com
Nov 25, 2008 | Xerox DocuColor 3535 Copier
How to remove drum unit from kyocera fs 1920
Installing the Toner and Drum Cartridges
bullet.gif Installing the Toner Cartridge
bullet.gif Installing the Drum Cartridge
caution.gif CAUTION: Before performing any of the following procedures, read and follow the safety instructions in your Owner's Manual. Installing the Toner Cartridge Install or replace the toner cartridge while the printer is on (if the power is not on, the cartridge carrier will not rotate).
  1. After confirming the Insert Yellow Toner (Y)message, open the front door.
  1. Hold the tape on the protective cover and pull it forward to remove the cover from each cartridge slot.
note.gif NOTE: You need to remove the protective cover only the first time that you install the toner. note.gif NOTE: Dispose of the protective cover after you remove it. note.gif NOTE: The protective cover is attached to each toner cartridge mount. mag_cover_5.gif
  1. Make sure the color of the toner cartridge matches the slot on the toner cartridge carrier. The order is Y, M, C, K. Gently shake the cartridge to distribute the toner evenly.
  1. Lift the tab up 90 degrees and pull the toner seal straight off, keeping it parallel with the toner cartridge.
  1. To insert the toner cartridges, align the arrows on the cartridge with the corresponding arrows on the printer. Guide the cartridge in until it snaps into place and then push down the handhold to lock the cartridge in place.
  1. Close the front door.
note.gif NOTE: Make sure the toner cartridge is installed correctly. Otherwise, the front door cannot close firmly. close_front_cover.gif
  1. The toner cartridge carrier rotates to the next empty slot. When the color of the newly inserted cartridge appears on the display, followed by the Insert message, insert the next toner cartridge.
  2. Repeat steps 1 through 7 when inserting the remaining cartridges.
  1. When the Insert Drum or Insert Drum Cart message appears, open the front door, then lift and push back the top cover.
  1. Remove the protective sheet from the drum cartridge.
  1. To insert the drum cartridge, push up the lever on the right side of the printer. With the lever in the upright position, hold the drum cartridge by the handle, align the arrows on the drum cartridge with the corresponding arrows on the printer and guide the cartridge in until it snaps into place.
  1. Pull down the lever on the right to lock the drum cartridge in place.
  1. Close the top cover, then the front door.
note.gif NOTE: After installing the drum cartridge, the printer makes an adjustment for about one to two minutes. Do not turn off the printer during this time.
Aug 04, 2008 | Office Equipment & Supplies
Konica Minolta Magicolor 2530 DL Laser Printer Logo
27 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
