Hello Al, my name is Cheri Torres and I work with DISH Network Internet Response Team. I came across your post and wanted to see if I could help. Connecting your LG TV to your DISH Network receiver should be fairly easy, depending on the connections you are using. If you are using an HDMI cable you will need to connect one side of it to your LG TV and the other end into your DISH receiver, as long as you have an HD receiver. If you do not have an HD receiver you are probably going to want to use composite cables(red, white and yellow). If you are using either of these cables you are going to have to set your TV to an input in order to receive the DISH picture. You can select an input by finding a button on the TV remote or the TV itself that is listed as input, source, AUX, mode or video. You will need to cycle through each one until you find the DISH picture on one of them. Once you have the picture you will need to press SAT on your DISH remote and everything should be working fine from there. I hope this information is useful and if you have further questions feel free to ask!
The monitor needs to be repaired. The cost of the repair maybe too high. I suggest you get a quote first or gjust et a new LCD monitor.
Do not try to fix it yourself because there are high voltages inside these CRT monitors unless you understand display electronics and the dangers etc.
then it must be the problem with your display.
check the VGA cable. see if the power cable of moniter is connected or not. if possible check it by using another moniter.
Sir, I hve read all above statement which shown as above. but in my case monitor take time to ON and display the screen, its take at least 45 minutes to start up and display the window screen. So please to send me solution about my Query. Thank's
