Question about Sharp AR-M450N Copier
Error code sc 36-05 - Sharp AR-M450N Copier
  • 57 Answers
SP5832-1 is reformat all! I hate this code! Might need a new hard drive and definately re flash the firmware. A bad drum will cause it if the surface is worn through to the aluminum substrate, but i know you said you replaced it. after that: Controller, NV ram, I hate this code!
Posted on Jun 04, 2013
I got error sc 554 for ricoh mp1600
Ricoh Copier Error Code SC 554 problem Reseting SC 554 error code on Ricoh copier
Press CLEAR MODE(yellow) key,
Press 1 , 0 , 7
Press and hold down CLEAR/STOP (red) key for more 5 sec.
Press in the SP Mode( on the touch pane)
Go to sp5810 and reset SC code
Open the front door turn OFF the power main switch, and turn it ON
Ricoh Error Code SC 554
Heating roller overheat (hardware error)
The heating roller thermistor detects 240°C or more.
Defective PSU
Defective IOB
Defective BCU
Defective fusing control system
1. Replace the PSU.
2. Replace the IOB.
3. Replace the BCU.
Oct 17, 2016 | Ricoh Office Equipment & Supplies
Pro c900. What does error code sc544 mean?
SC 544
Heating roller thermopile (center) error 3 The thermopile detected a temperature over 260?C. • TRIAC short, AC drive board defective • Defective IOB 2 • Defective BCU sc_note_1.gif
Related SC code: SC 553, SC563 1. Do SP5810 to cancel the SC fusing code. 2. Replace the AC drive board. 3. Replace the IOB 2. 4. Replace the BCU.
GO TO SERVICE MODE AND SP5810 to Clear - Check temp inputs - SP5803 150, 151, 152
Mar 13, 2016 | Ricoh Office Equipment & Supplies
Code erreure sc 300 aficio mp 6000
SC 300 Charge corona error - charge corona power pack defective
SC 300 Charge corona error - charge corona receptical defective
SC 300 Charge corona error - charge corona unit defective
SC 300 Charge corona error - replace corona unit and enblock as set
SC 300 Charge corona error - replace Transfer Belt
Replace charge wire and grid or charge assy B2472010 -Carl
Jan 17, 2012 | Ricoh Aficio 120 Copier
Ricoh 6513 Error Code Sc.387 Error Code Sc.457 Error Code Sc.350
1. Set SP3-125-003 to a value of
2 to enable Job End & Non-use
3 Self Check Mode.
fore more hrlp visit https://cbrtechsolutions.net
Jan 21, 2011 | Ricoh 6513 Copier
Error code sc211
This error code SC 211 not exist.Exist SC 2-11 is the communication problem.For reset the SC codes following the procedure:enter in the service mode (press total clear key-1-0-7-Clear keyhold down more 3 sec.Enter SP 5-810 SC code reset and select `1`.Then hold down the original type key and the OK key at the same time.This does not require the main switch to be turned OFF and ON.
Aug 12, 2009 | Ricoh Aficio 2015 Copier
I am getting an error code SC 534 on my Ricoh Aficio MP 6000.
The best I can find is that this is related to a malfunctioning cooling fan, I cannot find that specific code for your model, but all other 534 codes from that manufacturer are related to cooling fans
B010/B188 SC 534 Right fusing pressure motor HP error 1 - HP sensor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - IOB defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - Motor defective
B010/B188 SC 534 Right fusing pressure motor HP error 1 - motor drive bound
B132/B200 SC 534 Duplex exhaust fan error - Paper exit fan motor M28 defective, indexed as 146, electrical component layout.
B132/B200 SC 534 Duplex exhaust fan error - check and or replace fusing exhaust fan / paper blocking fan
B132/B200 SC 534 Duplex exhaust fan error - replace duplex fan motors M29 or M30
B222/B224/G878 SC 534 2nd duct fan error - replace fan motor
B230/B237 SC 534 Fusing exit sensor fan error, BICU defective
B230/B237 SC 534 Fusing exit sensor fan error, Fan defective
D014/D015 SC 534 Duplex unit fan error - Fuser exhaust fan blocked or has paper in it.
D014/D015 SC 534 Duplex unit fan error - Duplex Unit fan obstructed
D014/D015 SC 534 Duplex unit fan error - Fan harness disconnected or damaged
D014/D015 SC 534 Duplex unit fan error - Fuser unit connector has paper obstruction
D014/D015 SC 534 Duplex unit fan error - Replace duplex fan
D023/D025 SC 534 Second duct fan error - replace the 2nd duct motor
D023/D025 SC 534 Second duct fan error - replace the IOB
D027/D029 SC 534 Second duct fan error - check connections and harness to fan
D027/D029 SC 534 Second duct fan error - replace fan motor
D037/D038/D041 SC 534 Fusing rear fan error: Check or replace harness
D037/D038/D041 SC 534 Fusing rear fan error: Replace BCU board
D037/D038/D041 SC 534 Fusing rear fan error: Replace fusing rear fan
D037/D038/D041 SC 534 Fusing rear fan error: Replace the DRB
Jun 13, 2009 | Office Equipment & Supplies
Ricoh 1232c copier error code sc 517
The error is about the fusing unit for to reset the code you must enter into the service menu and reset the SC code 517
For to enter the service menu you should do the follow steps :
1.Enter the service menu by pressing the follow keys in order: yellow key[clear modes] then press "107" number one after other and then press and hold the red key [clear/stop]
2.Hold it down until service mode do not appear if not appear after 10 seconds try again.
After you will be in service mode press the follow numbers :5810 and then will apear on the screen "SC reset" set the value from "0" to "1".
Then turn off and after 5 seconds turn it on the machine.
Please replay if this do not help and write the SC code good because i cannot find the code SC517
Oct 29, 2008 | Office Equipment & Supplies
Error code sc 541
I have infotec machine when I powered machine a error code genereted sc 541 what is the solution?
Sep 21, 2008 | Ricoh Aficio 2018D All-In-One Laser...
Error code sc 101.... sc 350
SC101 Scan Lamp Error
SC350 ID sensor pattern test error
Your scanner should be checked by a technician to determine what is causing the error. There isn't any calibration or troubleshooting that can be done unless you have scanner parts.
Aug 21, 2008 | Office Equipment & Supplies
Sharp AR-M450N Copier Logo
35 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
k24674
CheckitRight
CheckitRight
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
