Question about Watches
CP 2104 USB to UART Bridge Controller - Watches
Can I run Nike Triax Elite software in Windows 7. I have a USB driver problem.
I had to take the following steps to get it to work in Windows 7 after running the setup executable under the Comments in the Windows row from http://www.ftdichip.com/Drivers/VCP.htm
  1. Open up Device Manager, right click on the Triax Elite and select Update Driver Software.
  2. Select "Browse my computer for driver software" in the window that pops up.
  3. Click "Let me pick from a list of device drivers on my computer."
  4. Scroll all the way down the list of "common hardware types" to USB controller.
  5. Choose FTDI from the list of manufacturers and choose the "USB Serial Converter"
  6. Confirm that you know what you're doing and want to install this driver.
Windows then finds another Unknown Device which is the serial port. Repeat as above but choose Ports for the common hardware types and then FTDI and "USB Serial Port".
Afterwards, run the latest Nike Triax Elite software (that you can download from http://www.nike.com/timing/extranet/elite_software/ and it should work.
Jan 24, 2010 | Nike Triax Elite Hrm/Sdm Heart Rate...
After replacing a battery in a timex ironman with data link, they tell you to short the ac pad and the vss pad. Were are those points located?
You will find them on the module itself.
So after replacing the battery look on the PCB (printed circuit board) for the letters"AC" and "VSS". Adjacent to these markings there should be little contact points (probably gold or silver looking in colour)
Use a paper clip or similar and bridge (short) these two points simultaneously. Please rate my solution.
Jul 26, 2009 | Timex IRONMAN Triathlon Data Link T53722...
Noisey Explorer 2,
The noise and the vibration is coming from the winding rotor loose axle. There can be two causes for it:
1) the rotor axle, bridge and setting (fixing) spring is getting loose. This will be quite easy repair as all it takes is to tighten all screws and replace or tighten setting spring.
2) rotor axle is worn, so, consequently the bridge and the setting spring as well. In this case the rotor axle must be replaced by the new one and re-bushed into the bridge and the new setting spring must be fitted. This takes quite a lot of work and new parts as well.
Can not tell you about the costs, but Rolex repairs has never been cheap. In the U.K.about a year ago I did the repairs as described in chapter 2 and customer was charged £195.00, parts inclusive, and it was cheap by the Rolex standards.
Do not forget to rate, please.
Mar 07, 2009 | Rolex Explorer II 16570 Wrist Watch
Where can I find the pictures : how to install the movement for Seiko dial 7s26b ? Please help how to install the balance wheel to balance stud bridge?
there is some videos on you tube but is a difficult work!is the same with all the watch calibers!you need special tools microscope and experience.in the end if you put everythihg in correct you have to adjust the hairspring to keep the correct time!enother special and expensive timing tool!
Dec 02, 2008 | Seiko SKA098 Wrist Watch
Rado Diastar
your problem is in setting lever,when the setting lever is jumping the stem cannot get back and lock,you better unscrew the complete barrel drum bridge plate take it out ,and the winding pinion is expose,take the winding gear and the setting lever is expose then arrange the alignment,align the winding pinion to the setting lever,alignment is ok.back bridge plate and screw,,make some winding of the crown,let see rachet wheel can turn transmission wheel of complete barrel drum,if can then checked the stem if already lock.,if lock already the job is done,...email if you some question regarding a watch ;lacarontito@yahoo.com
Jun 17, 2008 | Watches
Watches Logo
637 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
