Question about Acer Aspire Computers & Internet
Pilote controleur ethernet acer aspire 5250-bz467
I dont have internet
  • 4 Answers
SOURCE: acer aspire 5520 ethernet driver
Go to acer.com downloads, all drivers for the 5520 are there.
Posted on Apr 10, 2009
myrlex
  • 674 Answers
SOURCE: ethernet controller driver for acer aspire 5710Z
Download here
http://support.acer-euro.com/drivers/notebook/as_5710.html
Posted on Jun 19, 2009
  • 50 Answers
SOURCE: acer aspire one kav60 will not connect to internet
check your lan driver if you are using cable.
right click on my computer
select properties
select hardware
then device manager
check network adapters
the device must be enabled or driver is present.
lastly check your cable or use other cable.
Posted on Apr 04, 2010
  • 10406 Answers
SOURCE: ethernet-controller drivers for Acer Aspire 5520-5908 XP
Find a USB memory-stick, and find a computer with Internet access and an available USB port.
Put the memory-stick into the USB slot.
Browse to ACER's web-site, and select your specific model of the Aspire line, and select Windows XP, and select network-controllers, and download the device-drivers, and copy them onto the memory-stick,.
Walk the memory-stick to your Acer, and install the device-driver.
Posted on May 07, 2010
minicruzer
  • 7 Answers
SOURCE: Why can I only connect
You may have a weak signal coming from the wireless router. Most routers will fade with age. If its fairly new, it could be a lemon, or you just need a new one. If your house is made of, say, sheet metal, this will interfere with signal strength. A Wireless "N" router generally provides good speed and signal. You can find these anywhere.
Posted on Jun 13, 2011
Ethernet controller driver
If you currently have internet access on the computer, use http://www.3dpchip.com/3dpchip/3dp/net_down_en.php
or there is a all-in-one that you can download and perhaps put on a flash drive and open it on the driverless computer. It contains tons of drivers and automatically finds the one you need in there.
I have used it before to install drivers to access the internet on a new computer. Of course you will need a computer with internet access, but since you posted here, I assume you do.
Recap:
1. Download
2.Put on flashdrive
3. Drag to desktop
4. Run the file on the Acer Aspire
Although I have used it with great results, I take no repsonsibility, yada yada yada
Aug 29, 2013 | Acer Aspire 5250-BZ873 AMD Dual Core C-50...
Network controler
You will have to open up your network connections
Click start control panel network connections this may vary depending on your operating system look for local area connection if you see a red x or a yellow exclamation or question mark ! ?
you will need to update or install the driver or it could be firewalled.
Make sure your antivirus program is not blocking the internet connection.
If you are trying to connect through a modem/router you it should have come with a disk then
you might have to connect the usb lead to your modem to get a connection then
Click start control panel administration tools computer management device manager scroll to network adapters should see a yellow question ? exclamation mark ! or a red X right click install drivers.
The driver might be on the disc supplied by your ISP internet service provider
or the motherboard disc
You only need to check the BIOS if you cant install the driver
Make sure you Ethernet/internet is enabled in bios restart your computer during the boot up process you will see on your screen a certain key to
press to enter set up (BIOS) press and hold that key to enter bios using arrow keys navigate to integrated peripherals look for SiS On Chip Pci Device press enter scroll to SiS 10/100m press enter make sure its
"Enabled"ima
Click start type cmd press enter you will be in DOS mode
type in ipconfig press enter
you will see all of your internet connection details type in your default gateway adress into your internet search should read something like 10.0.0.138
or you could download one
Full range of acer aspire drivers
http://www.laptop-software.com/acer-software/aceracer-aspire-5250-windows-7-drivers/
Aug 06, 2013 | Acer Aspire 5250-BZ455 -25793
Operating manual for acer aspire 5250-BZ467
Here's a link for an online manuel for your Acer Aspire.
http://www.manualowl.com/p/Acer%20Computers/Aspire-5250/Manual/114478
Nov 16, 2012 | Acer Computers & Internet
Acer aspire 5250 missing webcam
hi.it does sound as if you need to install the drivers for it to work.
try this link might help you out and show you were to get the drivers. How do get my acer crystal eye webcam back
Oct 18, 2017 | Acer Genuine Aspire 5250 5333 5733 5733z...
Can't get on internet. Dont have Ethernet Controller Driver
Im guessing u have an Acer pc, do u know which model is it? we need it to look for the correct driver. Did u formated ur pc at any time? maybe thats why u dont have that program.
Oct 31, 2009 | Acer Aspire X1200 Desktop PC - Athlon X2...
Wireless adapter
Vous avez besoin du lan Marvell yukon conducteur 9.11.11.3 http://support.acer-euro.com/drivers/notebook/as_3680.html
Aug 28, 2008 | Acer Aspire 3680 Laptop
Acer aspire 3680-2633 wireless adapter
hay
soory i do not speak inglish
j'ai un problémé avec mon pc, j'ai désinstaller mon ordinateur qui à été avec vista, mais j'ai perdu tous les périphériques j'ai essayé de télécharger tous les péréphériques.
mais je n'ai pas trouvé le controleur Ethernet
veuillez s'il vous plait m'aider
Aug 27, 2008 | Computers & Internet
Computers & Internet Logo
54 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
