Question about Zyxel Communications Zyxel NWA3560-N IEEE 802.11n -draft- 300 Mbps Wireless Access Point -
Error 42007 while upgrading firmware
Printer display error99.07.20 upgrade
99.00.07 Upgrade not performed error reading upgrade
Description
A remote firmware upgrade (RFU) was not performed.
Unexpected read error when reading rest of header.
Recommended action
1. Download the RFU file and attempt the upgrade again.
2. If the error persists, replace the hard disk.
99.XX.YY
Description
Firmware installation error
Recommended action
Reload the firmware.
Basically you should try to reflash the firmware. If that doesnt work then you may have bricked your printer and shoudl consider warranty support or replacement. Good luck!
Dec 02, 2015 | HP LaserJet Enterprise 500 Color MFP...
Trying to configure my Linksys WRT120N router, but when I click 'Save Settings' I get an error message (324). What's wrong?
I think you can try upgrading the firmware on your router,
Connect the computer to the router.
Download the latest firmware.
Open the setup page of the router and upgrade the firmware.
After upgrading the firmware, reset the router and reconfigure it manually.
See How to upgrade firmware on Linksys router.
Watch video: Linksys router setup
Mar 27, 2012 | Linksys WRT120N Router
Wrt160n vpn error 800
Error 800: Unable to establish VPN connection
This issue may be caused by a router that has outdated firmware.
Make sure that port 1723 is opened on your router.
For VPN connection , you can try opening port 500, 443-447, 10000-20000 and important port 1723 on your router.
I will suggest you to upgrade firmware on your Linksys router.
After upgrading the firmware, reset the router to factory default and reconfigure it manually.
Open the ports mentioned above and see if that works.
See How to setup Linksys router
Mar 12, 2012 | Cisco Linksys E2000 Advanced WirelessN...
Error code 3508 after installing a new cartridge
As Kodak suggests in these cases - upgrade the firmware for your printer.
  1. Upgrade the firmware for your printer:
    1. Locate and select the firmware download for your printer.
    2. Follow the instructions to install the firmware.
If the error continues, try to contact Kodak
Oct 03, 2011 | Kodak Esp 3250 Allinone Multifunction ( ...
Hp 5550 color laser printer display "downld rfu error over parallel port" how can i get a solution? and what is the cause? thanks
RFU = remote firmware upgrade.
Appears like someone tried to upgrade the firmware.
While the firmware was being downloaded, something interrupted the process. For example somebody tried to use the printer, you had a power problem, your internet went down etc, etc.
You are going to have to try the firmware upgrade again.
If you can't get passed the RFU error, you will probably have to get the formatter replaced.
Aug 19, 2011 | HP LaserJet 5550 Printer
I have code error 6202
To resolve this error:
  1. Disconnect the power adapter from the printer.
  2. Wait 30 seconds to allow the printer to reset.
  3. Connect the power adapter to the printer. Turn the printer on if necessary.
When the printer is ready (no error message), upgrade the firmware for your printer: the firmware for your printer.
Install the firmware from the products site.
If the error continues and you cannot upgrade the firmware, contact the product company.
Hope this help.
If u find this solution please rate me.
Jun 11, 2011 | Office Equipment & Supplies
My mp3 player says initializing
Same here...I hate Phillips right now
Aug 16, 2008 | RCA M4204 MP3 Player
On my rca pm3 player it is stuck on initializing it will not turn off by pressing the turn off button
I have not tried this yet but RCA support sent me this.
I suggest updating the firmware on your player. After upgrading the firmware on your player, you must use the easy rip software. This will avoid problems in the future and keep the unit updated
1. Go to www.audiovox.com
2. Go to FAQ’s in search enter M4204
3. Download firmware upgrade
4. Hold play/pause button for 15 seconds
5. Hold menu button for 10 seconds
6. Attach M4204 via USB cable while holding play/pause button
7. This should start the firmware upgrade
8. Possible an error message of “cant write to disk” will pop up
9. Firmware upgrade will end with error do not close
10. Go to My Computer find the drive that holds the MP3 player
11. Right click scroll down to format, format the player
12. Run firmware upgrade again
Aug 04, 2008 | SanDisk Sansa m230 MP3 Player
Power light flash
check the firmware you are upgrading to is supported for the hardware model yoiu are using.
Jul 25, 2008 | Dell PowerEdge 2450 Server
Firmware Upgrade Failed
Firmware upgrade is a simple but a delicate procedure. Make sure you are loading the correct firmware. You should get your firmware from the website of your router. Installing a THIRD PARTY firmware to your router voids the warranty of your router. Here is a tip for a successful firmware upgrade. BEFORE FIRMWARE UPGRADE(push the reset button of the router for 30 seconds then unplug the power of the router for 10 seconds). Upgrade the firmware. After the upgrade push the reset button again for 30seconds, unplug power for 10 seconds.
Mar 10, 2008 | Linksys Wireless-G Broadband Router
Zyxel Communications Zyxel NWA3560-N IEEE 802.11n -draft- 300 Mbps Wireless Access Point - Logo
179 people viewed this question
Top Zyxel Communications Computers & Internet Experts
David Payne
David Payne
Are you a Zyxel Communications Computer and Internet Expert? Answer questions, earn points and help others
