Question about Iwata Eclipse HP-SBS Airbrushing System with the TC-848 Quad Piston Air Compressor
Iwata airbrush gun
Air comes out the noxxle but when the paint cup attached the paint cup bubbles over. What's wrong
  • 4 Answers
Wat kind of paint do ypu use?
Posted on May 08, 2013
Master g22 air paint
Do you have a water separator attached?
Jul 11, 2013 | Crafts & Hobbies
I am using an iwata eclipse cs airbrush with an iwata compressor. the comopressor seems to be working fine when power, but the airbrush is not getting and air. when i push down for air release, nothing...
Air brushes us a Theory called a "venturi" in where air pressure lowers the pressure where the paint is kept and causes it to go out the nozzle. I would try seeing if there is an obstruction in the hoses to the brush and confirm that the compressor is moving air. If none of these things are an issue also while cleaning the parts may give the appearance that the item is clean then try soaking them over night in paint thinner and replacing the O-rings and gaskets.
Apr 27, 2011 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Water coming out airbush from hose
An in-line water separator should be used before the supply line, a good air filter wouldn't hurt either.
Apr 23, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
I cant decide between two airbrushes i am thinking on ordering.I want a large cup gravity feed and right now am debating between the Badger 100LG and the Paasche Talon.Any comments would be great
I am not familiar with either brush, but they are both well known name brands. The Paasche will probably have more readily available parts for it than the Badger in case something breaks or you drop it. I myself use Iwata, BUT the parts are expensive.
It will boil down to which brush comes with what size tip/needle in accordance to what type of media you will be shooting. Thicker paints or stains will require a bigger tip and needle, thinner paints and stains, just the opposite. I hope this helps.
Feb 21, 2010 | Paasche Talon Gravity Feed Airbrush Set
Bubbles in color cup of airbrush
I assume you have adjusted the nozzle... On my unit, there is a SMALL hole in the cap for the cups to let in air above the paint. Also OFTEN the paint must be thinned to use in an airbrush. Since you havent been able to draw water even, thinning is NOT the problem.
The airbrush aspirates the paint by Bernouli's principle, that is where there is higher velocity of a fluid, there is a lower pressure. The nozzle creates that and the adjustment is important. On mine which is a "Wren", I think by Binks there is a conical piece that the paint comes out of with a throttling needle. This has the be unscrewed to open the paint path and adjust it. The air flows at high speed around this cone creating a vacuum.
The headline says "Eclipse" but that is a gravity feed so I suspect that is the old Fixya problem of having incomplete choices to pick from.
Feb 18, 2010 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Blowing paint out trough cup
It is clogged and needs to be disassembled and cleaned with MEK. methyl ethel ketone
Aug 01, 2009 | Air Tools & Compressors
My iwata hpc is pushing air back through the paint cup
Try replacing cup gasket first then clean all inlets and outlets completely, check that all valves operate properally, and all seals and o-rings are in good condition. Clean and lubricate adjustment fluid valve.
Jun 16, 2009 | IWATA -CS Eclipse AIRBRUSH w/COMPRESSOR...
Need a new paasche spray gun for bigger jobs
Anest-Iwata brand spray equipment has the most versatile line of airbrushes on the market. Im sure you will find one to meet your needs. well worth the money, it's all I spray
http://www.airbrush-iwata.com/
http://www.tcpglobal.com/airbrushdepot/iwata.aspx
check it out!!
Apr 07, 2009 | Air Tools & Compressors
Total Novice
I suggest that you go to the Library and look up how to airbrush. The paint goes into the cup. Nozzle adjustments are learned as you go, for desired results. Good luck
Feb 01, 2009 | Badger Basket Starter Spray Gun Hobby Set
Iwata Eclipse HP-SBS Airbrushing System with the TC-848 Quad Piston Air Compressor Logo
94 people viewed this question
Top Iwata Air Tools & Compressors Experts
John Trevino
Joe Garcia
Joe Garcia
Are you an Iwata Air Tool and Compressor Expert? Answer questions, earn points and help others
