Question about Maytag Model MER4351AAB
Where is the model number on my Range?
The use and care range (model unknown and can not locate it) is Precision Touch Control 700 Electric Smoothtop. Thanks
  • 5,911 Answers
As you are facing the range, there should be a metal plate (held on by one screw) on the left hand side behind the console. Model and serial number should be located here. On some models the information will be along one side of the oven door opening, or bottom drawer. Hope this helps you.
Posted on Aug 11, 2007
SOURCE:
Maytag precision touch control 800 electric slide-in smoothtop is not baking evenly cookies at front of oven done quicker than at the back
It sounds like the seal round door may be in need of renewing. .or the doors are not closing properly..
Jul 15, 2018 | Maytag Kitchen Ranges
Problem with Precision Touch Control 500 Electirc Smoothtop
i think some wires may have burnt due to high voltage or overloading
Dec 20, 2007 | Maytag MER5765RAS Stainless Steel Electric...
I have a Maytag Electric Smoothtop Double Oven Range Precision Touch 850 Series. Model: MER6875BAF. The cooktop is broken and I cannot find a replacement part. Any suggestioins.
I deal in appliance parts new and used. It can be tough when you are in need of a discontinued part. Best advice is to check eBay every so often. There are lots of people including myself that sell new, used, and refurbished appliance parts there. You might get lucky. I checked for you today and didn't find it. The part number is 5706X616-81 for the cooktop. Try google searching the part number and eBay searching it. You might find someone who has one somewhere.
Feb 01, 2015 | Maytag Kitchen Ranges
I can't find my model # on my Maytag Coil Electric Coil Precision Touch Control 500 - can anyone help me please?
Maytag sometimes put the model number on a plate that flips up on the back of the control panel.
Sep 25, 2014 | Maytag Kitchen Ranges
Maytag precision touch control 500 electric smoothtop
The heating coils in the oven need to be inspected very carefully where they plug in to the oven wall. You will need to remove the back covers and check the insulators and wiring harnesses. Over time the insulation can break down and oxidize the metal connections. You can use a voltmeter or test light to verify that the coils are getting voltage from the thermostat/switch. replacing parts is cheaper than buying new if you can find the parts.
Oct 04, 2017 | Cooktops
Need a new element for the large front burner on my Maytag Precision Control 500 smoothtop stove
That is the 2700W element. I have it available for $157.35 plus shipping.
Email me at buffalonymann@yahoo.com if you would like to purchase this part
Oct 17, 2009 | Maytag MER5775Q Electric Kitchen Range
One burner will not turn on - This is a Maytag Precision Touch control 500 electric smoothtop
hi there,
on this case try to clean the gas burner for any dust and corrosion inside. also check and test the ignititer of the stove/
let me know.
Jun 02, 2009 | Maytag MER5770 Electric Kitchen Range
Kitchen range cleaning
Use Glass cook top cleaner by Weiman. For stubborn burnt on food use a scraper or razor blade and hold it at and angle almost parallel with the top of the stove top and scrape off gunk.
Apr 03, 2008 | Kitchen Ranges
Maytag smoothtop kitchen range
The only way to find out for sure is to check the voltage to the element.
Most of the ranges have 2 or 3 screws under the front of the top. Remove them and the top will tilt up. Be careful, there is voltage on some of the wires.
Turn the switch on and check for voltage across the element terminals. If you have 240V, then the switch is ok and you probably need an element.
If you can post the complete model number from the tag on the back of the console, I may be able to give a little better directions.
Thanks/Mike
Nov 30, 2007 | Maytag MER5775Q Electric Kitchen Range
Maytag Model MER4351AAB Logo
362 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
