Question about Dell Studio 1537 Notebook
CAN I CHANGE MY MOTHERBOARD 2 INCREASE THE PERFORMANCE
    Master:
  • 663 Answers
Motherboard is expensive. It's better to buy a new computer rather than a motherboard.
If you want to increase performance, then upgrade the RAM stick and harddrive.
Posted on May 08, 2013
CAN I CHANGE MY MOTHERBOARD 2 INCREASE THE PERFORMANCE OF MY DELL STUDIO 1450
Very hard and expensive to replace a motherBoard on a laptop.
If you have performance problem try to clean the computer from all malware, using malwarebyteantimalware . the ferr version is excellent.
After disable all program that open when you start your computer. CCleaner has the option to do this and it will also delete unnessessary files ...
If you still have preformance problem you could change the memory chip in your laptop for a bigger one ... but usually the clean-up is enough
May 08, 2013 | Dell Studio 1537 Notebook
Tip
Increase Physical memory of the system. Increasing Physical memory will increase...
Increasing Physical memory will increase the performance of the system.
1. Right click My Computer - Select Properties.
2. In property window Click on Advance tab --- Performance -- Settings.
3. In Performance Options window -----> Virtual Memory option Click Change button.
4. In Virtual memory window --- Select C drive --- Click on custom Size.
5. Change initial size to 2000MB & Maximum size to 4000MB -- Click on Set button.
6. Click OK and close all window. Restart system.
Regards
Achalesh Prem P
Vote for me
on Mar 05, 2010 | Computers & Internet
PIG3IT VI.0
Is this a Mercury motherboard? And is that P 'eye' G3 'eye' T?
Or P L G3 L T?
What is the question?
Ya know Dual Channel memory is overrated, right?
If a motherboard is capable of using Ram Memory in a Dual Channel configuration, it has two Channels.
Motherboard with 4 Ram Memory slots has two slots in one channel, and the other two slots in another channel.
The two ram memory modules ('Stick'), MUST be alike.
Same frequency rate ('Speed')
Same type
Same ram timings
Same chip configuration
Same voltage
This is why it is best to use two ram memory modules that are alike, AND from the same ram memory manufacturer.
When ram memory is used in a dual channel configuration, the two ram memory modules team up on the task.
Kind of like Batman and Robin.
ON paper it looks good. many thought they were getting an increase of up to 30 percent, in ram memory performance.
In reality it is more like 1 to 2 percent.
Tomshardware performed MANY tests, using MANY motherboard/processor/ram memory configurations, and found this out.
So why do gamers use Dual Channel configuration?
Hey, 1 to 2 percent IS an increase, lol!
EVERY little bit helps.
Post back in a Comment.
Regards,
joecoolvette
Dec 22, 2012 | EliteGroup Via P4M266A (P4VMM2 V7.3)...
I need info about what the cpu phase leds on aN msi 990fxagd65 mean
They indicate the number of different power phases that the CPU is currently using. In order to save power the motherboard is able to reduce the voltage to (and performance of) the CPU. In 2 phase mode (2 LEDs) it basically switches between high performance, and low performance. 4 LEDs means that there are two additional intervals in between the high and low power settings. 6 LEDs indicate six total phases, etc.
I believe that there is a greater possibility of system instability as you increase the number of phases that the motherboard switches through.
Oct 22, 2012 | MSI 990fxa-gd65 Motherboard Am3 Amd990fx...
I increased memory from 512 to 768 on Dell desktop with 2.4 celeron but did'nt seem to increase speed.what is the problem? Ray.
That minimal amount of increase is not going to be a very noticeable increase also the processor or a faster RPM hard drive is more for the speed. you can go to the system properties in control panel and then the advanced tab and then the settings tab on performance then to the Advanced Tab then to change tab in virtual memory then to custom size make the initial setting 1.5 times the amount of memory installed in your case 768 x 1.5 = 1152
on the max 3 x the amount of memory again, in you case 768
768 x 3 = 2304
Jul 07, 2010 | Dell Dimension 2400 PC Desktop
Overclocking aopenax4b-533 mobo
In some motherboards, you can increase the multiplier, which will increase your processor speed.(Briefly, Processor Speed = FSB x Multiplier) You can also increase the chipset, memory, and CPU voltage, which will sometimes allow you to have a higher FSB. There are other settings such as PCI Bus and AGP Bus, you generally don't want to touch those, either they might put risk to your PC, or that they won't make much difference in performance. Be careful when you overclock because you can really damage your computer that way.
Mar 08, 2010 | AOpen Computers & Internet
I have elite mother board P4 M800 PRO M2 socket 775...the problem is always hang and to slow..i reformat 3 times but the problem same plz help me i need assistance..
This are things that need to consider in a computer speed performance:
1. Amount of ram memory(If you have only small amount of memory then your computer performance is poor.)
2. Speed of your processor(You should need at least a 1Ghz processor speed or more).
I suggest you increase your ram memory so that your computer will perform faster.
Dec 16, 2009 | EliteGroup P4M800PRO-M Motherboard
Graphics
1) enter bios
2)make changes in shared graphics to 128 mb
3) increase the size of page sys file allocate more ram to page.sys file by going into rt click my computer/properties/ performance/
4 u can change your windows system to 64 bit.
Sep 19, 2009 | Intel D945GCCR Motherboard
Increase graphics card memory
go to your bios setting > chipset feature > onchip AGP.
you can increase your Graphic card from ther if it is on bourd.
Jan 28, 2009 | Asrock P4I45GV R5 Motherboard
Dell Studio 1537 Notebook Logo
54 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
