Hotpoint aq9d692u fitting new door seal
gittos73
  • 244 Answers
SOURCE: Door seal
i will tell u step by step 1)open the door undo the clamp that holds the front of the seal on it is around the lip push door seal back so its out of your way into the drum 2)take the lid of look to the front were your seal is fastened onto the outer drum this is held into place with a screw clamp unscrew it and u should be able to ease the door seal of from around the drum reverse these actions to replace the new 1 i have sent these instructions too 3 other people they have found these instructions easy to follow and do
Posted on Aug 15, 2007
TampaNative
  • 778 Answers
SOURCE: FITTING NEW DOOR SEAL ON WHIRLPOOL AWM5125
Usually it will be just be reversing the procedure of removing the old seal. At any rate, the door will need to be disassembled.
Posted on Mar 29, 2008
barkencoa
  • 3463 Answers
SOURCE: Door seal has two holes in it and leaking
Hi.
You need to remove the front console panel and then the front panel to change the door seal.
Pull the dispenser drawer out and remove the screws.
Slide the console panel to the right and support it while you remove the rfont panel.
Change the seal, and reassemble in reverse order.
Good luck.
Posted on Nov 20, 2008
  • 86 Answers
SOURCE: how to replace door seal of Hotpoint WF860 washing machine
Hi, This is a very simple and straight forward job. First turn off the washing machine and remove the plug from the wall and earth the plug on the cabinet of the machine to remove any residule current in the machine. Remove the top of the machine with the screws at the rear of the machine. You can now look in the top? Open the door and take off outer door seal clip ( look and you will see how ) If it is a plastic clip it will have a small cut out in the side for a small screwdriver to be put in a pushed open. It could even be a small spring that is laying in side the small lip of the door seal. You could now attempt the removal of the door seal if you can see the inner clamp to get a long screwdriver onto the screw! If not now remove the soap drawer. Remove screws from around the soap drawer and slide the facia to the right and it should all be off.. Then you can remove the three screws that hold the front on along the top and the same along the bottom edge of the front panel. This then will allow you to take off the front panel and have better access to the door seal. Then once you have replaced the door seal you just need to replace as you took off..
Good luck................
Posted on Dec 28, 2008
FitzOriginal
  • 842 Answers
SOURCE: Hotpoint Door Seal WMA64
I have reproduced the details of my article: http://www.fixya.com/support/t1543617-door_seal
here. I hope this will give you the information you need.
Rule 1: BEFORE YOU START Turn off the mains, unplug at the wall, turn off the water supply.
The gasket is held in place on the drum by a large sprung wire ring with a screw tighten/release. To access this (Depending on the model), you will either have to go in from the top or the bottom of the machine. Usually the top.
Pull the machine out, go to the back and unscrew, usually 2 screws that hold the "Work top surface" top on the machine at the back. There are usually clips at the front of the top, so by lifting the rear clear and either pulling the top back, or giving it a tap forward, depending on the design, the top should now lift off.
You should now be able to look down at the drum and you should clearly see the rubber gasket fitted over the edge of the drum with the clip in place. Locate the screw in tensioner and undo it until it is possible to slip it forward and clear of the drum. You should now be able to simply pull the gasket away from the drum. Most machines rely on the door being closed to hold the gasket in place where it meets the chassis, it should just pull off if the door is open, but while you are lookiing inside, just check anyway. The assembly is simply a reverse of what is described above.
Stuff to consider: You may not be able to see the screw clip from the top, if so, tip the machine back and look from underneath. If you have to do this: Never tip the machine all the way onto its back, you may cause a water leak inside the machine. ALWAYS tip BACKWARDS, so the control panel for the machine is pointing up to avoid water getting to the control panel. I would recommend putting a chair behind the machine as you tip it, so the top back of the machine comes to rest on the seat and the machine is at about 45 degrees. this will give you access to underneath without a leak and make is a lot easier to tip it back on to its feet again afterwards.
Posted on Feb 15, 2009
Hotpoint aq9d692u
This is classic. You need to replace drum bearings.
Only a Certified Technical Engineer should do this work.
Apr 11, 2014 | Hotpoint Washing Machines
I'm trying to find instructions to remove and then fit new door seal on hotpoint WF210, have lloked at tsome online videos but the wf210 doesnt seem to have the outer retaining ring releases as shown on...
I find it easy to remove front casing to fit new door boot seal First remove soap drawer then the 4 screws here next pull off control know of timer next 3 screws on front panel this then now drops down with wiring attached the front of the machine has 3 top and bottom screws remove them along with the door interlock switch 2 screws......detach the band or wire around the door seal the front panel can now be removed.....Seal is in front of you secured by large metal band and screw undo this fit on new seal refit ring and bobs your uncle as they say Good luck....
Apr 21, 2011 | Hotpoint Aquarius WF210 Front Load Washer
Door locked keeps flashing but machine wont start washing
You need to fit a new door interlock switch, pull off part of the door boot seal undo the two screws on the lock unplug the wiring harness /fit new lock....
Feb 24, 2011 | Hotpoint WMA30 Front Load Washer
We have a Hotpoint double oven spec# BD52K and after having the element refitted have notice that the bottom oven door no longer fits flush causing the oven not to seal correctly. is there any way that...
Assuming that the door was not removed for the new element to be fitted, then it sounds to ne as thiugh the oven door hinges are weak.
The only solution is to replace both door hinges,
If the door was removed, then it could possibly be not fitted back correctly.
Jan 28, 2011 | Hotpoint Ovens
Fit a new door on a washing machine
You need to remove the wire clamp that holds the door seal on to the front of the cabinet, then pull seal off.
This will give you access to the door hinge assy, then you can replace the door complete.
Please rate my solution.
Thankyou.
Jan 27, 2010 | Hotpoint Washing Machines
How do I change the door seal on my Hotpoint WMA40 washing machine?
It's a push fit seal. Carefully remove the old one and for help, smear the new seal where it fits the machine and just push it into place securely.
Sep 07, 2009 | Hotpoint WMA40 Front Load Washer
How do i fit the door seal
hi the door seal is held in place by two large clips wjth screw tightening best access is to remove the top row screws on rear panel these also hold the top panel then lift top panel at rear and pull top backwards and clear of front facia then lift top off ok ? now you have access to the door seals clips which secure seal to front panel and the outer drum loosen screws fully this releases clips enough to gently remove seal clean surfaces of seal to drum and front panel then fit new seal as previouse one resecure clips then re assemble covers hope this helps and clear enough ?
Mar 09, 2009 | Hotpoint BWM12 Front Load Washer
Fit new door seal
For most front-loaders:
Plug off the wall mains. Remove the plastic clamp holding the seal to cabinet & peel off the cabinet. Push downwards on the seal close to the tub & the seal will come off - it's just held by a spring on the periphery.
Lubricate the slot which fits over the tub with washing-up fluid. Starting at the top, press the seal so the flange of the tub enters the slot on the seal. Work your way round the using thumbs to force the slot on the tub flange. When slot is on the flange all way round, fit the spring which holds it on. The spring goes into a slot on the outside of the seal. This is quite difficult and you may need another pair of hands. Fit the outside of the seal to the cabinet - this is easy and fit the plastic clamping ring.
Test for leaks before using. Use rinse to test as the water level is higher.
(There is no glue anywhere, only clamps,etc)
Pl rate me nice for the free help!
Jan 20, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Washing Machines Logo
Top Washing Machines Experts
