Question about Samsung S5620 MONTE BLACK QUAD BAND 3G HSDPA WIFI UNLOCKED GSM MOBILE PHONE
Phone white screenMy phone working, but the LCD is blank. Any solution?
MOBILE FELL INTO WATER
its flat of lcd is not working good and u may change ur lcd.but it may be from its IC, that time there is no way to solve. call ur cellphone when its lcd is blank if it is working change the lcd. cheers
Nov 25, 2013 | Samsung SGH-E840 Quad Band GSM 2MP Camera...
Blank and white screen solution
Hi,there are two kinds of white screen in phone,
the first one is because of damage LCD (glass screen) ,
defective display driver (small chips that makes the display works)
and the other one is corrupted software...in damage lcd the phone will detected
by computer because its software is still working...so ,
the problem of your phone am sure is the second one ,
corrupted software....your phone needs to reprogram,and
need to go to the model of the phones care center to fix you problem...
And also flex can make screen go blank and or white.(if it is a flip phone)The flex is a connector that connects the screen to the phone board of the phone.That can also be the cause, when the flex is damaged,it can cause blank and white screen display .
i hope ,i will help you ,thanks for trusting fixya...
Sep 16, 2010 | Cell Phones
Nokia n70 is showing white blank screen
possible the firmwar is damage or sum ics have burn because of a power spike, or brownage while it was on charge, take it to a repair shop to be checked
Oct 08, 2009 | Nokia N70 Cellular Phone
Blank white screen
It seems to be ur lcd stops working..Take this to service center...
Nov 29, 2008 | Samsung J700 Cellular Phone
My screen is blank
Is the screen white or just dark?
Fix Sidekick White LCD Screen
If it dark or no light at all then
replacement of the Sidekick 3 LCD flip screen.
to buy a sidekick 3 lcd screen look here.
http://www.repairmysidekick.org/Sidekick-LCD-Screens/buy-a-t-mobile-sidekick-3-lcd
Look for one that has the torx screwdriver included
Jul 07, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Sidekick screen blank
Call T-mobile if the phone is still under warranty. They may fix it for you.
If not follow this procedure, it usually works.
Jul 05, 2008 | T-Mobile Sidekick ID Cellular Phone
Blank Screen???
Is it white or just black?
If it it is white then this procedure should fix it, Fix Sidekick White LCD Screen
if it is black then a new lcd is in order. They run about 45 dollars and fairly simple to install.
http://www.repairmysidekick.org/SideKick-Repair-Parts/Sidekick-LCD-Screens
May 21, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Black lcd screen
Does the phone still work? can you make calls? If so, yes, a screen replacement will work.
A white screen usually means no signal is being received by the screen. A black screen means the lcd back light probably died.
sidekick LCD screens
Jan 12, 2008 | T-Mobile Sidekick® 3 Cellular Phone
Blank screen
i have the same phone and the problem just lies on the flexcable inside the phone that attached the keypad to screen.
Dec 09, 2007 | Sony Ericsson Z520i Cellular Phone
My sidekick3 screen is blank
If your sidekick ID or Sidekick 3 screen is a blank white, then the lcd flex cable has come loose. It is a little difficult to repair but any one can do it. The worst that will happen if you try to repair yourself is that it will not work and you buy a replacement screen from ebay for 45 dollars.
Here are the detailed instructions. Just reinstall your lcd instead of putting a new one on.
Sidekick 3 LCD Screen Only Replacement
Here is a link to find lcd screen on ebay.
Sidekick 3 LCD Lens
Oct 27, 2007 | T-Mobile Sidekick® 3 Cellular Phone
Samsung S5620 MONTE BLACK QUAD BAND 3G HSDPA WIFI UNLOCKED GSM MOBILE PHONE Logo
Top Samsung Video Cameras Experts
Lawrence Oravetz
abdul rauf
abdul rauf
Are you a Samsung Video Camera Expert? Answer questions, earn points and help others
