Question about Konica Minolta MAGICOLOR 7300EN LASERPR COL 20PPM 128MB ETH USB REFURBISHED Printer
My printer only prints black
Last week my printer (KM Magicolor 7300) stopped printing colors. It only prints black now. During a print job the colors started to fade, and now it's only prints the black parts in the job. What can I do to fix this?
  • Konica Minolta Master
  • 32,281 Answers
INK PROBLEM
Inkjet printers need to be used frequently to prevent ink drying out and blocking the print head nozzles.
If the print head cleaning maintenance routine does not clear the blockages, then print head needs replacing, but it may be expensive.
It may be more cost effective to buy a later model and better printer than replace the print head.
Posted on May 08, 2013
Testimonial: "Magicolor is a Laserprinter, not an inkjet."
SOURCE: Magicolor 2400W print fades on right side of page
Have you tried cleaning the leans at the bottom of the printer? Open the cover, pull out the drum. Under it is a long, narrow piece of glass. If it gets dusty or toner accumulates on it, it will cause streaks in the printing. If this is dirty, take a clean, soft cloth and very gently wipe it off.
Posted on Jun 01, 2008
pldtech
  • 4 Answers
SOURCE: Magicolor 2400W - Printing Problem
check the green levers at the top of the fuser unit that have envelope icons on them.  They reduce pressure on the fuser assembly for thick stock.  It is possible that one side is up the other down, causing uneven pressure across a page.
Posted on Jul 12, 2008
osiriscompu
  • 16 Answers
SOURCE: Konica Minolta magicolor 2430DL
Open the top cover. Remove the drum (part with long green handle). Below the drum you will see a strip of glass about 4-5 inches long. Take a cloth and wipe across the glass.
This will normally clear up any white lines in your print.
Posted on Jul 19, 2008
  • 4 Answers
SOURCE: Magicolor 2300DL: prints low on first page, OK subsequent pages
I spoke to QMS about this since it happened to me. It is the registration roller in the transport unit going bad. Basically the clutch is slipping and they are seeing a lot of it on this model. The first page will slip because the clutch is sticking. , delaying the paper pickup . i also have the accordion problem which is where you are headed. this is where the clutch does not disengage when it is suppose to , causing the paper to fold.
The only solution to this is a new transport unit. It is the entire section in the back.. Looks like a bit of work to rip it out but straight forward.
Transport unit
8314131-0360-04
800-972-6705 - $87
I am going to call and order one next week, I’ll let you know how it works out.
Posted on Jun 20, 2009
SOURCE: Error light flashed when trying to print with Magicolor 2400W
Start the Konica Minolta Status application and check the error, you should get more info there.
Reset your Toners and Imaging units for Bizhub and CF series.
http://www.chipreset.eu
Posted on Sep 03, 2009
When printing color the paper jams. This does not happen when printing black. How do I stop it from jamming when printing color.
Is that true for both print and copy job ?
Where does the jam happen ?
I am thinking if it is at the paper pickup roller area just as the job starts to print and not midway while printing, check the paper quality; dirty pickup roller; clean cork pad and try job from another tray
Sep 21, 2016 | Konica Minolta magicolor 1680MF -...
Magicolor 330 prints blotchy color
replace all three image units.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Sep 24, 2012 | Minolta Magicolor 3300 Color Printer
My magicolor 2550 won't print in color
PLEASE CHECK ON PRINTER PROPETE AND CHECK MARK BLACK
Apr 13, 2012 | Konica Minolta magicolor 2550 Laser...
Hi! I am getting a "replace toner yellow" error message. The orange lightning bolt error light is on too. Do I need to replace the yellow toner to print in black and white or is there a different error...
Specifically on the Magicolor 5430DL you can print when a cartridge is empty, but this is disabled by default. To enable printing even with a toner cartridge empty.Press the Menu Button, then press the right button until the ENGINE menu appears and press the select button.Next press the right button until TONER appears and press SelectOnce in the Toner Menu the first option should be "EMPTY" if not press the right button until you see "EMPTY" and press Select.There are two options, the default is "STOP" pressing the right button once should change from STOP to CONTINUE.While the display reads "CONTINUE" press Select.You should see the message "CONTINUE is selected"You can now print even when one or more cartridges are empty. However, the lack of the cartridge's color will be noticed in any print jobs calling for that color... (Obviously)
Jun 13, 2010 | Konica Minolta magicolor 5430 DL Laser...
My new Magicolor 1600w Printer hasthe toner light
Probably. Most color images have some black in them as well.
Aug 09, 2009 | Office Equipment & Supplies
Minolta magicolor 7300 message "print unit
Print head is passed its life which is the LASER get a new one.
Aug 05, 2008 | Minolta Office Equipment & Supplies
Only black!
The printer require print head repalcement.
Apr 18, 2008 | Canon BubbleJet i550 InkJet Printer
No longer prints in color
check that the cartridges is installed correctly, print demo page prom printer. if its B/W choose quality in menu and color mode there you can switch B/W and color printing
Dec 16, 2007 | Konica Minolta magicolor 5430 DL Laser...
48 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
