Question about Navman Trackfish 6600 GPS Receiver
My Trackfish 6600 sonar function stopped showing the depth, all other functions OK, any ideas??
Not showing depth numerals.
How do I get water depths displayed on my C70
You haven't said if you have a DSM fitted ( sonar unit and tranducer) the C70 is only a multifunction display unit MFDU you then put a card in for navigation, a radar aerial/ scanner or a sonar unit for depth and fish finding .
if you have a sonar unit and it's working then
press Presentation
press Depth Digit and select on / off
press OK or cancel to return to the default display
hope this helps
Aug 28, 2014 | Raymarine C70 Multifunction Navigation...
How do i find water depth
Water depth should show automatically on your sonar page.
if it does not then either you have selected "stop sonar" under your sonar options or you have opted to turn off the depth displayou so the numbers don't show up.
if you areally viewing your GPS or split screen sonar/GPS page, sometimes the depth display is not visible on these pages unless you specifically instruct the unit to display it.
Lowrance HDS 5 Gen2 Fishfinder GPS Chartplotter
Here is a link to Lowrance where you can download a pic version of the operators manual.
Go to page 11 "overlay data" this will give you a step by step of how to add data or readouts to different screens.
Aug 27, 2014 | Lowrance HDS 5 Fishfinder GPS Chart...
Sonar not Working
Transducer not parallel to bottom - kicked up. Manually set depth to see if the auto depth is the problem.
Aug 12, 2017 | Lowrance Elite-4x DSI Sonar with...
No bottom structure and depth flashes
your system is not locking to bottom ( bottom lock) go into menu scroll down to functions click it see if bottom lock is high lighted if not turn it on by clicking on it if it is on ..you need a new transducer
Sep 22, 2013 | Lowrance X515c Df 5" Screen Color 50/200...
Trackfish 6600 will not receive satalite and
moisture and oxidation, neither work well with any electronic devices . many can never be repaired to work due to this .
Sep 14, 2017 | Navman Trackfish 6600 GPS Receiver
My fishfinder will not continue to read shallow depths as well as in shallow depths when drifting and occasionally running across the water. My unit is a lowrance 522c color gps/fishfinder.
Hello. Your observation is spot on and it is actually a characteristic that is always true when using sonar. Yes, your Lowrance uses the same sonar as a nuclear powered submarine does. The two factors you focus on, water depth and boat speed are perhaps, the two biggest factors when it comes to the quality of the fishfinder. The boat's engine should be in gear at an idle or just above. Experiment with your boat to find the best throttle location for good arches. Usually, a slow trolling speed works best. The depth of the fish can determine if the fish will arch on the screen. If the fish is in shallow water, the fish is not in the cone angle very long, making it difficult to show an arch. Typically, the deeper the fish, the easier it is to show an arch.
If you would like a complete tutorial on Lowrance sonar, go to this link. Enjoy. http://www.lowrance.com/Support/Tips-and-Tutorials/Sonar-Tutorial/
Nov 20, 2009 | Sport & Outdoor - Others
When we zoom in we dont see depth i certain areas; but only grey colour. What are we doing wrong?
The image on my fish finder has a ghost like worm going across the screen. It doesn't read structure at all but will give you the depth. The arrow is pointing forward and I was told to point it in. I would think it would at least still have a picture when the boat is stopped. Any advice?
Jul 07, 2009 | Navman Trackfish 6600 GPS Receiver
No gps fix NavMan trackfish 6500
my navman trackfish 6600 gps is aquireing and will not give a gps fix ,I have also had the screen ghosting when I enlarge the area with no detail, the unit is 4 years old .
May 09, 2009 | Navman Trackfish 6600 GPS Receiver
I need a manual for Navman trackfish 6600
I need a manual for a Navman Trackfish 6600. Can i download it or where can i purchase it from?-
Dec 30, 2008 | Northstar Explorer 660...
Navman Trackfish 6600 GPS Receiver Logo
21 people viewed this question
Top Navman GPS Experts
Neil Gossage
Level 1 Expert
Are you a Navman GPS Expert? Answer questions, earn points and help others
