Need Error solution C-c173
When swiched on the machine error code appear
4 Suggested Answers
  • 53 Answers
SOURCE: Error Code : 6-355
06 xxx on Xerox products {I take it it is a Xerox?} refers to Scan or illumination...does the scan carriage under the glass move up and back a short way? Does the lamp come on? That's your starting point
If the lamp fails to light you could get someone to check continuity of the lamp and the overheat thermostat on the carriage (these are usually a push to reset)
Be SURE to unplug from the power, you can still get a bite from the lamp heater even if switched off!
Posted on Aug 24, 2008
SOURCE: Error code E20 in Canon NP 6241 copier
Check this code - does it read E020 ? if so this is usually a result of toner starvation possibly caused by a faulty toner sensor in dev or hopper unit.I have also found the toner hopper supply motor can fail with the same result. In either case it is an engineers job to rectify. Good luck !
Posted on May 19, 2009
  • 1575 Answers
SOURCE: error code sc 302
Hi
This error indicates problems with the laser motor on your printer.
Have it replaced.
Posted on Mar 01, 2012
How do I remove error code c-c173 on konica minolta bihzup 353?
You have a missing firmware file, or a corrupt MFP board, and no I can't send you the firmware
1 Rewrite the firmware.
2 Change PRCB
First turn OFF the main power switch and
replace the current PRCB with a new
One.
(When using a PRCB of another
machine into service, be sure to use a
PRCB installed in the same model.)
Jun 24, 2017 | Konica Minolta Office Equipment & Supplies
When swich on,dE appear
Google it MAKE MODEL error code dE
Mar 21, 2016 | Washing Machines
TROUBLE CODE C173
the error code given does not match any in the C452 diagnostics
if you meant CB173 then the error reports to the fax control pwb and page sizeing error. reseat the fax board/ reset the fax borad to factory and then reprogram to current location ( cleariing any possible programing mistakes previously) set the correct marketing area ( see service manual) it is very rare for a fax board to go down, the problem likely remains with its install/programming/firmware levels.
Jan 16, 2014 | Konica Minolta Bizhub C452 Color Copier...
Error code c173
NVRAM or main board issue has any boards been replaced? has any firmware been attempted is NVRAM board missing???? GET a qualified tech out to look at this you might need OS firmware updated and or NVRAM and or board replaced properly
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Dec 07, 2013 | Konica Minolta Office Equipment & Supplies
Free service manual
error code c-c173 bizhub c652 wat solotion
May 08, 2013 | Konica Minolta Office Equipment & Supplies
LG Intellowasher 7kg WD-14125RD shows DE error
DE is for a door lock error and you will need to replace the lock. Here is the part to order.
Dec 07, 2012 | LG WD-12126RD Front Load Washer / Dryer
Screen appears error with thermistor,what i have to do?
switch hold down 08 while holding 08 down swich on machine wait until test mode starts on the number pad put in 400 and press start input 0 and set switch off wait 30 seconds and swich if error code c440 is back you have to replace thermistors and thermofuse
Mar 06, 2011 | Toshiba e-studio 455 Copier
Error pada mesin cuci lg 6.5 g kode dE disebaban oleh apa?
m.cuci lg toplouding error DE. pada dasarnya pintu atas dilengkapi swich tapi kenapa model ini kok gak.terus gimana cara ngatasi door swich ini. mohon pencerahan
Jan 17, 2011 | LG Washing Machines
Error code t84 ???????? anyone
Hi stuiejohnsto,
As far as I know there is no error code t84. The closest code that has the numbers 84 in error code CC-184.
Anyways, whatever code you may have, it's worth turning the machine off for 10 seconds by the Main ON/OFF swich (inside front door on the left).
With any luck your code should disappear. If not, can you let me know if it gives you a different code to t84
Thanks
Good luck
Tam
Mar 22, 2010 | Konica Minolta Bizhub c203 Copier
I have a Sharp ARM350N with an Error Code L1-00. I just had the copier moved. Is their a reset for this ?
it is scanner out of position, swich off then swich on it should reset it.
Dave Moore
right document solutions
02074664700
May 30, 2008 | Sharp Office Equipment & Supplies
k24674
jasbo
jasbo
