Question about Epson Stylus Pro 7000 InkJet Printer
Reset printhead counters
0001FFFF
0x02 motor drive fatal errorCR
check (manually) if the printhead moves correctly left/right without any friction. then check if on the right there isn't paper jammed
Sep 15, 2015 | Epson Stylus Photo R290 Ultra...
Tip
The Ink absorber is for waste ink when the printer cleans the printheads. All...
This error is common in all the newer variants of canon printers.. Canon charges 50-80$ to fix it! But it can be fixed by following the steps below:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with o
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
on May 01, 2008 | Canon PIXMA iP90 Mobile Printer
I would like to unlock my printer from the service required mode
Assuming you are referring to an R300 then you can use the keys on the printer itself to reset the waste ink counter and get out of the "service required" mode.
1. Press and hold 'stop' 'maintenance' and 'power' buttons for about 10 seconds, a message will come on the screen saying counter is reset and to turn off.
2. Turn your printer off and then back on - job done.
IMPORTANT
When resetting the counters you should really replace the waste ink pad or fit some form of external waste ink tank, like a Printer Potty, as the pads will eventually oversaturate and start leaking waste ink out of the printer or backing up ink into the printhead causing clogging.
Dec 08, 2012 | Epson Stylus Photo R300 InkJet Printer
Dcp 145c machine error
ill email you the reset procedure for the m/c and pruge but just doing a reset will not cure this problem you need to replace purge unit and do a counter reset on your purge unit, (used to clean the printhead) thats why it says unable to clean,
In Case You Still Having Problem Then Follow Us For On :
Brother Printer Support
Jun 28, 2012 | Brother Ink for Dcp145c Lc-980
Hi, The orange light in my canon ip1600 printer is blinking 5 times and green light once alternatively. Please give me a solution to fix it. What is the reason behind this problem? Thanks.
Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
1. Start with printer OFF
2. Hold down RESUME and then hold down POWER
3. Release RESUME
4. press RESUME twice, then release POWER
5. let green light blink until printhead has finished moving.
6. Select functions below with RESUME, execute with POWER
0 presses - green light - Test Print (exit service for i960)
1 press - orange light - EEPROM info print
2 presses - green light - EEPROM initialise
3 presses - orange light - reset waste ink counter.
Jun 25, 2011 | Office Equipment & Supplies
All the lights have just started flashing on my 1520 suddenly i have tried diconnecting it and then back on still the same
s printer has internal reservoir spomges for unused ink that purges from printhead each time printer parks its printhead. At some point they become saturated, something like 65k copies. The printer counter needs reset and sponges need replacement. Download the service manual (probably free) from Epson factory support site.
Apr 11, 2011 | Epson Stylus 1520 InkJet Color Printer
I hava a i850 -- when I turn it on and it goes thru its set up then the amber light comes on blinks 7 times stops then blinks again 7 times -- cannot stop it -- also when I open it the print head stays in...
Hello.
From Canon:
3. Release RESUME
Hope this helps.
Dec 27, 2009 | Office Equipment & Supplies
Orange light is flashing 7 times, but printer ,is locked. Ink tanks do not centre when lid is opened.
3. Release RESUME
hope this helps
Sep 08, 2009 | Canon PIXMA iP4200 InkJet Photo Printer
Canon i950 won't print
try this Probably your waste ink counter. Should be cleaned or replaced before resetting but usually you can get away with resetting once.
3. Release RESUME
one by one
Jan 25, 2009 | Canon i9900 InkJet Photo Printer
Epson Stylus Pro 7000 InkJet Printer Logo
32 people viewed this question
Top Epson Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
