Question about Pioneer DJM-600 Silver Professional DJ Mixer with Auto Beat Cou Home Equalizer
Pioneer djm-600 I purchased a used mixer, and when I plug into the rca's on channels 1 & 4, bothing comes through..no sound, no display.
    Scholar:
  • 86 Answers
Victor is correct. Either the PCB foil pattern connections or soldering joints have to be repaired, or the RCA jacks themselves might need to be replaced entirely if the metal surface has been completely worn away. Both are common problems. You can check the metal surface wear using a jewelry look or magnifying glass/loop, but for internal PCB connections and damage you will have to open the unit and remove the input/output pcb and look underneath to check for any damage. If you're lucky enough to have just bad soldering joints, 'd have all jack soldering connections redone to be on the safe side and save yourself some time, money and aggrevation.
Posted on Dec 04, 2014
    Problem Solver:
  • 4 Answers
The rcas need to be resoldered
Posted on Nov 03, 2007
  • Giulio Moro Jun 06, 2012
    Hello Victor. Is there any place I can source new quad and dual rca jacks for the DJM-500 and DJM-600 mixers? In some cases I can't resolder them as the connection plating is worn and needs to be replaced. Thank you.
When moving the bottom knob on channel 1 and 2 of the pioneer djm 600 mixer there is a slight interference sound coming through the speakers. Channel 3 and 4 are fine
That sounds like you could have some dust built-up on your sliders. Get yourself some dust repellant spray or silicone spray normally found at you nearest computer store. That will definately sort your problem
May 21, 2010 | Pioneer DJM-600 Silver Professional DJ...
Can i connect 2 amps on djm 3000? If yes how?
I currently have 3 amps connected to one mixer. All you need is to check where your amp is currently plugged into the mixer. now get yourself 2x RCA two way splitters at your local music shop (ie. One male to 2 female)split the channels from your mixer input, and an extra amp can be plugged into the spare plugs
Apr 14, 2010 | Pioneer Djm-909 DJ Performance Mixer with...
Djm 500 mixer cf missing and does not turn on does it need the cf to turn on?
no and you can use channel fader of each channel to control the channel without cross fading.
Dec 18, 2009 | Pioneer DJM-600 Silver Professional DJ...
Pioneer DJM-400 mixer turns on, but channels aren't working
could be a few things , what have you tried to trouble shoot the problem ?
My steps would be ;
check all leads (even if you KNOW u pluged them in)
check the gain is set corectly .
check the line phono slectors are set to what ever you have you leads pluged into on the back of the mixer ( there is 4 red and white RCA plugs , 2 for phono,2 for line CDJs shold be using line )
if you are using digital cables to conect your CDJs , on the back on the mixer there is a small switch marked "CD or digital" make sure that is sleceted "digital " . if ur not using digital cables make sure it is on "CD" .
the info iv put here is based on the DJM-800 so your mixer my not have some of these featers as iv never used a 400 . hope this helps dued . check out www.djtutor.com for more tricks and tips . Pratices'N'enjoy !
Dec 28, 2008 | Pioneer DJm 400 Professional DJ Mixer
Pioneer DJM-600 Bad feedback when i turn up the master volume
It's not your ground wire with the issue, but your RCA cables. Try disconnecting both turntables, and connect 1 at a time, and do the same test, this way you can isolate the problem. Once you've isolated the problem, then you'll need to have the RCA cables replaced on your turntable.
You might also want to check the Cartridges as well. Sometimes a bad cartridge or headshell connection will cause this issue. Worst case scenario, its your tonearm, but that should be test last.
Also, on the rear of your mixer, there is a gain volume pot, make sure this is not maxed out. Keep it about 3/4 of they up. Again, this is on the rear of your mixer where you connect everything.
- OPTiC
http://djproaudio.com
http://djprolab.com
Dec 04, 2008 | Pioneer DJM-600 Silver Professional DJ...
New DJM 600 User
Get yourself a manual. It will help you. You can DOWNLOAD A FREE COPY of the PIONEER DJM600 INSTRUCTION MANUAL from HERE.
Now, you have to use the CUE button function on each channel to select what you want to hear when you cue things in the headphones. Last, you control the volume of the master cue in the headphones using the CUE volume of the headphone CUE section.
- OPTiC
DJ Equipment Repair & Service
A DJ Pro Audio Co.
Nov 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
Djm 600
start with connections and try to clean fader with lubricant contact cleaner from radio shack or any electronics store.
Sep 10, 2008 | Pioneer DJM-600 Silver Professional DJ...
Pionner efx 500
send out from mixer---------to pioneer in---------from pioneer out-----to return in mixer.
May 16, 2008 | Pioneer DJM-600 Silver Professional DJ...
338 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
