Question about Hardware & Accessories
How do I programme a Proteam electronic garden water timer
Timer will not switch on
SOURCE: Need instructions for Aube by Honeywell 7-day
pdf is at
www.smarthome.com/4256W/Aube-7-Day-40-500W-Timer-White-TI032-3W/p.aspx
Posted on Feb 19, 2010
aquaman987
  • 927 Answers
SOURCE: I have a Malibu ML88T timer on the garden lights.
Is the timer wheel rotating - keeping time?
If so, are there pins for the wheel?
The other option is to purchase a photo sensor and let your lights stay on from dusk til dawn. The benefit of this arrangement is that as dusk changes across the seasons and daylight savings time, you don't have to keep adjusting on/off times.
Posted on Dec 01, 2010
SOURCE: set timer for the 7-day outdoor timer i.e. 5:00 pm
Outdoor timers
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers.aspx
HB88RC timer
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/digital%20timers/hb88rc.aspx
HB88RC Manual:
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb88rc%20-%20english.ashx
Timer takes AA battery installed from back
Instructions say: Set timer to AUTO using MODE button. This will let programs run.
To override current program, press MODE once for ON-or-OFF override.
Press MODE again to enter RDM or random mode. RDM shows on display.
Press MODE third time for AUTO. Usually, AUTO will show on display.
Posted on Dec 05, 2010
SOURCE: A FRIEND GAVE ME A
Some Gardena manuals appear on following link, and additional manuals are posted as found:
http://waterheatertimer.org/How-to-program-Gardena-C1060.html#manuals
Also Google search "Gardena C1030 .pdf" or "Gardena C-1030 .pdf"
Be sure and add .pdf to search parameter to help isolate manuals from other internet posts
Gardena for some reason does not have manuals easily available as of today's date.
Add a comment for more free help
Also take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
Posted on Apr 14, 2011
SOURCE: Leviton Programmable Timer 6124H-W installation problem
I Have a decora 24 hour lcd programmable timer switch 6124, when i set the timer it doesn't go on, but it goes one a 5:00 am. when there is nothing programed?
Apparently i need to set the time first and then program timer?
Can you please help. Thanks so much.
Posted on Jul 09, 2011
Does the Defiant Daylight Adjusting Indoor Digital Timer also uses a battery?
No battery.
This single-pole or 3-way, programmable or dawn-dusk timer is same as GE 15312 sun smart timer, and requires a neutral wire to power the electronics.
GE renamed all their wall timers, or sold their timer business to Defiant in year 2013-4.
http://waterheatertimer.org/Programmable.html#15132
http://waterheatertimer.org/How-to-wire-GE-15312-timer.html
If you want a timer with same capabilities, that uses a battery, and does not require neutral wire, then choose Intermatic ST01 or Ei600 timer
http://waterheatertimer.org/Programmable.html#st01
Gene
Water Heater Timers Save Money
Dec 05, 2014 | Hardware & Accessories
EJ351 is programmed to work. In the on position the light it controls is on properly. in the automatic off position the light is on at approximately half intensity. When the manual control is in the o
This timer is rated for incandescent light bulb only.
With 40 watt minimum.
With 100' maximum distance between bulb and timer.
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#ej351
EJ351 is not rated for CFL bulbs (or motors etc).
CFL bulbs are considered inductive loads (same as motors), while incandescent bulb is resistive load (same as a heating element).
Both types of loads use electricity differently.
Programmable wall timers are not ordinary on-off switch... unless you use the override switch.
... instead timers control electricity with electronic circuit board.
So when the manufacturer designs the electronics inside the timer, the design must anticipate how the electricity is used by the load.
Older designs like EJ351, and some modern timers, are not rated for CFL.
... however most newer timer designs are rated for both resistive and inductive loads.
Always read the specification sheet for load rating before installing programmable timer.
Nov 01, 2014 | Intermatic Programmable 24 Wall Switch...
Need user manual for THC15A weekly programmable timer
Copy following link to identify timer and download possible manual:
http://waterheatertimer.org/Woods-timers-and-manuals.html#Din-rail
Add a comment and describe timer buttons.
Apr 22, 2013 | Sourcing Map THC15A Digital LCD Power...
How do I programme the tap timer?
Copy following link.
http://www.popeproducts.com.au/products/garden-watering-products/tap-timers-amp-auto-control-systems/tap-timers
Tap timers show on page.
Click timer image that looks like your timer
Another page opens, than just below the timer image is link to pdf instruction manual.
Oct 29, 2012 | Hardware & Accessories
After 7 years working properly, the event button has stopped working. There is no way to start the load in manual, or to change the program... What can I do?
You posted under EH40 Intermatic programmable timer.
EH40 Manual:
http://waterheatertimer.org/pdf/eh40-manual.pdf
1) EH40 uses size A battery. Replace battery.
http://waterheatertimer.org/How-to-wire-EH40-hot-water-heater-timer.html#Battery
2) Reset the timer: Press and hold reset button for several seconds
3) Contact Intermatic because they are aware of specific problems with specific timers
http://www.intermatic.com/customer%20service.aspx
4) Other folk have reported EH40 and EH10 last about 3 years.
EH40 has 1 year limited warranty.
I test timers: 7 years is reasonable run for inexpensive electronic time switch.
5) For longer lasting timer, consider Next Generation: battery is replaced every 8 years
http://www.intermatic.com/products/timers/electronic%20time%20switches/next%20generation%20time%20switches.aspx
Add a comment for more free help.
Feb 28, 2011 | Intermatic EH40 - Electronic Water Heater...
Looking for a timer to turn a 120volt 2amp water pump on for 1min 2 times aday that will last for more than 3 years please help
1) You need 120V timer to control 2 amp water pump.
V x A = watts so 120V x 2amp = 240 watt
754 watts per HP divided by 240W = 1/3 HP horsepower.
2) To get 1 minute time periods, you need electronic timer.
Most electronic timers have minimum 1 minute set time.
Same schedule each day, you can use 356-day, 7-day or 24-hour electronic timer.
3) To have electronic timer last longer than 3 years you need a clean circuit and expensive timer.
Use circuit analyzer to check circuit. Hire electrician to check circuit and replace pump if necessary to make sure timer will last as long as possible.
4) Intermatic ET70115C should last for many years. Battery is replaced every 8 years.
ET70115C $379
http://www.1000bulbs.com/product/3391/ELEC-ET70115C.html
5) You posted under EH10 water heater timer, which is inexpensive water heater timer rated for 1HP. You can't expect inexpensive timer to last as long when using a motor, although 1/3 HP is lightweight motor.
6) You can buy five EH10's for same price as one ET70115C.
7) List of ordinary electronic timers, each with slightly different features
Intermatic EH10 $73
http://www.amazon.com/Intermatic-EH10-Electronic-Heater-Indoor/dp/B000GHIPOA
Intermatic ET1105C $96
http://www.amazon.com/Intermatic-ET1105C-Hour-Electronic-Switch/dp/B002X1FYWI
Intermatic ET101 $101
http://www.westsidewholesale.com/24-hour-programmable-electronic-timer.html
Tork EW100B $177
http://www.1000bulbs.com/product/8434/TORK-EW101B.html
Sylvania SA300 $72
http://www.amazon.com/Sylvania-SA300-120-Volt-Single-Pole-Industrial/dp/B000KKNEO4
8) See wiring diagrams and manuals for some of the timers listed above:
http://waterheatertimer.org/Boxtype.html
Also take advantage of fixya phone service.
For a price, expert speaks with you over phone while you work on water heater or any do-it-yourself project.
Jan 31, 2011 | Intermatic 7 Day Electronic Timer Eh10...
Apr 20, 2009 | Leviton 6124H 24 Hour LCD Programmable...
Hardware & Accessories Logo
Top Hardware & Accessories Experts
Gene Haynes
Hippy_dd
Are you a Hardware and Accessory Expert? Answer questions, earn points and help others
