Question about Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch
Instructions TImer does not 'switch' on
  • Aube Technol... Master
  • 5,245 Answers
Check wiring:
http://waterheatertimer.org/Aube-timers.html
Add a comment and describe the timer you have, and include if this is new timer, or timer that stopped working.
Also add if you are connecting for single pole or 3-way.
Be aware that some aube timers are not compatible with CFL, and work with incandescent only, and require minimum load wattage.
Better choice is ST01C timer
http://waterheatertimer.org/ST01C-program.html
Posted on May 08, 2013
Utilitech TM-029 wall timer: I've installed the
Do not run any timer warm... replace with switch, and/or buy another timer.
Copy following link to identify timer and download instructions:
http://waterheatertimer.org/Program-wire-Utilitec-LW60418.html
This timer is rated 15 amp 1875 watts.
Safe maximum is always 80% rating plate: is 12 amp and 1440 watts.
Add up total watts on circuit.
Add a comment and say what you discover.
Jun 29, 2013 | Hardware & Accessories
TRAX single channel hot water 7 day 14 settings programmer instructions missing
1) Thank you for description:
Copy following links to identify possible match for TRAX timer, and download manual:
http://waterheatertimer.org/Intermatic-timers-and-manuals.html#TRAX
http://waterheatertimer.org/GE-timers-and-manuals.html#DIGI
2) Add comment March 2013 and say how closely this information matches your timer. Attach image.
Mar 10, 2013 | Hardware & Accessories
Problem with the terminology and interpreting the circuit
Can you take in-focus photo of wiring diagram shown in timer manual, and attach them to comment?
1) Copy following links:
http://waterheatertimer.org/images/Wire-GM40-timer-600.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html
2) Right now, dec 2012, there is no product manual for this timer.
Thank you for including the terminal markings.
3) I assume jumpers are for changing voltage?
Please add comment and say what your product manual says about J1 J2 J3 J4 jumpers.
4) Load is water heater
Timer is clock that is set and programmmed to turn switches on-off.
NC is normally closed > when timer is OFF, NC and NC2 terminals are ON
NO is normally open > when timer is OFF, NO and NO2 terminals are OFF
When timer turns ON, then the switching reverses, and NO terminals turn ON, and NC terminals turn OFF.
Dec 16, 2012 | Hardware & Accessories
Can I install a utilitech Dusk-to-Dawn light control, #0314355 in a 'horizontal' position, rather than the 'vertical position shown on the packaging? It goes 'on-and off' in a 15 s
Timer is probably wired incorrectly.
Copy following links for correct wiring, and larger instructions.
I have tested this timer, and some problems can also be caused by overlapping and conflicting programs: reset timer and review timer instructions:
http://waterheatertimer.org/How-to-set-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Jul 31, 2012 | Hardware & Accessories
I need programming instructions for my intermatic outdoor lighting timer
Hi Jeanne,
Here's a page with detailed instructions and pictures - that will guide you through programming. I hope this helps & good luck!
Nov 09, 2011 | Intermatic Inc. ST01C Digital In-Wall...
The timer didn't lose ant time off of it and the dryer didn't get warm at all? What is the problem do you think?
Dryer will not run
1. No power--check fuse & power supply
2. Loose wiring--check terminals & wiring
3. Door switch--make certain door closed properly to actuate switch
4. Defective motor---check motor.
5. Defective timer---replace timer
Runs but will not heat
1.loose wiring--check terminals & wiring
2. Defective thermostat--replace thermostat
3.defective centrifugal switch in motor--replace switch (check linkage to motor)
4. Defective timer--replace timer
5. Open heater element---replace heater element
6. Heat switch set to off----set switch for desired heat
Sep 21, 2011 | Kenmore Dryers
I have a First Alert model 610 timer. It is an older model and I need the instructions for it.
I called First Alert @ (800) 323-9005 and they faxed me the instructions for Model LS510 which is the same and got it working. They will mail it too but not email. Choose Fixed or Random mode. Choose how many hours it will stay on after dusk. Turn your lamp off and unplug the lamp. Plug lamp into timer. Put function in Fixed or Random position. Put hours on switch to number of hours you want it remain on after dusk. Plug timer into the wall outlet. Turn the lamp's switch on and Timer's LED light should be on and the lamp should be off. Turn the lamp's switch off then on again TWICE. The second time you turn the lamp's switch on the bulb in the lamp will flach on then off quickly. This indicates that the Timer is controlling the lamp's operation. Leave the lamp switch in the ON position. The timer is now set for automatic. I hope this helps.
Jan 06, 2011 | Vacuums
Need instructions to program Intermatic Model #E140C wall switch timer.
Do you mean Intermatic E104C box-type timer? Intermatic does not make E140C
Manual says "refer to programming instructions on time switch door"
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/et104c%20-%20english.ashx
Manual says timer has 8 events per 24-hour day ... 4 'on' events and 4 'off' events. Normal operations, selectors are set to AUTO and RUN.
Using sketchy info from manual about programming:
Set sliders to MANUAL & TIME/SET
Press EVENT for event 1 ... set hour and minute using HOUR & MIN buttons ... this will be 'on' time
Press EVENT for event 2 ... set hour and minute ... this will be 'off' time
Set all 8 events ... 4 'on' and 4 'off'
Move sliders to AUTO & RUN for timer operation
Sep 15, 2010 | Hardware & Accessories
Aube Technologies Aube 7-Day Programmable 40-500w Light Timer Switch  Logo
103 people viewed this question
Top Aube Technologies Hardware & Accessories Experts
Gene Haynes
Craig Butler
Craig Butler
Are you an Aube Technologies Hardware and Accessory Expert? Answer questions, earn points and help others
