Question about Transmission & Drivetrain for Dodge Charger Daytona R/T Sedan
Dodge challenger 2009
When I start to accelerate on a hill either Riverse or drive starts making such a leap as if a spark plug failure and when will change from second to third gives a blow. How i can fix that?
  • Eduardo Mangual May 08, 2013
    Is not a Charger is a Challenger 2009 and I did all the tune up and continues with the same
  • Dodge Master
  • 5,815 Answers
Could be wires,plugs,coils.
Posted on May 09, 2013
Testimonial: "I have replace them and still the problem. Is only when is turning from 0mph thru like 5mph on a hill."
  • Eduardo Mangual May 09, 2013
    Only whe the car is making a force.
Window rolled down and stayed down. How do I get it to roll back up?
Windows rolling up and down by themselves and ABS, ESP/BAS, and TC ...
www.challengerforumz.com/.../windows-rolling-up-and-down-by-thems...
Nov 13, 2012 - The top part of the window goes up and down after i shut the cardown. ... To not have this happen until my appt at the dealer, i rolled the window down a crack so it wont go up and down. ... cracking just enough to let wind in, then if i have to fight it for 2 min, before it finally stays up. .... Joined: Aug 23, 2009. Dodge Challenger Electrical Problems and Questions ' Dodge ...
Apr 30, 2015
Auto Window's Down Function
Jun 20, 2013
Car unlocks by itself
Jul 8, 2010
Smart Window Recalibration Issue?
May 20, 2009
More results from www.challengerforumz.com
Cable Failure in Window Regulator/Motor May Cause ...
repairpal.com > Problems > Dodge > Charger
Dodge Charger Cable Failure in Window Regulator/Motor May Cause Power Windowsto Become Inoperative. This is a verified ... 2009 Dodge Charger128,000Visitor ... Thewindow rolls down but wont go up except when driver door is open.
How to instantly lower your car windows with the key remote ...
www.cnet.com > Security
CNETAug 30, 2012 - How to instantly lower your car windows with the key remote ... Dodge (Challenger/Charger/Durango/Grand Caravan/Journey/Ram); Fiat (Bravo) ... that's how the windows rolled down because I know I didn't roll them down is this a ... Honda Accord 2009 V6, American assembly -the feature works perfectly ...
Dodge Challenger Re-Calibration windows trick - YouTube
? 5:00
https://www.youtube.com/watch?v=zRLzN61GaS4
Dec 21, 2015 | 2009 Dodge Charger
Was having a slight hitch when accelerating up hills then the other day my cat got red hot and it would barely run, now i fixed the cat problem but it wont start, any tips?
When the engine really got hot is there a possibility you may have over expanded some parts and now the engine is sort of tight and is not spinning fast enough to start.
Check for spark and fuel delivery but ......................
Nov 25, 2015 | Cars & Trucks
How to replace heater core on 2009 dodge journey
Heater cores can be very challenging and time consuming to access. I suggest you don't even start until you have a good shop manual for that model, a 1/4 inch drive ratchet with short and long extensions and 1 or 2 u joints and lots of patience working in tight areas
Dec 01, 2014 | 2009 Dodge Journey
My 2004 dodge Durango hesitates and bucks when I accelerate or go up a small hill. Can you give me some solution?
Get your codes scanned at an auto store. Have you changed the air filter, spark plugs, spark plug wires, checked your transmission fluid for starters?
Oct 23, 2013 | 2004 Dodge Durango
Misfire under hoy conditions
It seem to happened Only when you turn and go up hill...?
-If so Check plug wire. It might be too lose , broken some where
and spark to metal.
Mai
Apr 02, 2013 | 2009 Chevrolet Silverado 1500
My mitsubishi challenger keeps dying when i go up the hill or downhill. i've changed the fuel pump but the problem is the same. sometimes its difficult to start the engine..
Check the condition and/or operation of the following:
1) Spark plugs, coils and leads.
2) Air filter
3) Fuel filter.
Please report back if no findings.
Nov 13, 2012 | Mitsubishi Cars & Trucks
5sfe lawnmower sound
It sounds like a spark plug blew out of one of the spark plug holes.
Jun 17, 2017 | 1995 Toyota Celica
My 2009 Dodge challenger with 45,000 miles will not shift into reverse properly when first started up, and while still "warming up" will act like it's trying to shift back into park out of drive...
I do not know about your vehicle but it sounds like a possible lack of lubrication in its gearbox or bearing wear. As things warm up metals expand to free themselves, or low lubricant may take its time to "splosh" up to higher positioned shafts and gears in its box after draining down overnight.
I would check this out urgently as friction can make things weld together (look up friction welding) which should not thus destroying a gearbox.
Hope this helps........
Jun 04, 2017 | 2009 Dodge Challenger
Acceleration problems
the usual culpit is a clogged fuel filter, or bad plugs. if it bogs down on hills or highway it is the filter. also make sure air filter is clean.
Apr 23, 2010 | 2003 Dodge Durango
Jerking and Dying while driving(highway)
Start with changing the fuel filter. If that doesn't do it, then change the fuel pump.
Apr 28, 2009 | 1996 Dodge Stratus
Transmission & Drivetrain for Dodge Charger Daytona R/T Sedan Logo
94 people viewed this question
Top Dodge Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Colin Stickland
Colin Stickland
Are you a Dodge Vehicle Part and Accessory Expert? Answer questions, earn points and help others
