Question about Sony Handycam DCR-HC54E Mini DV
Sony DCR-HC54 Tape Loading Problem
My Sony Handycam DCR-HC54 Mini DV couldn't load the tape. What will be the problem? Help!
Maanita
  • 1142 Answers
SOURCE: Mini DV Tapes Won't Play
Please give the model and the make
Posted on Apr 16, 2008
bestdarngood
  • 3037 Answers
SOURCE: tape is stuck
First take out the battery. Then start unscrewing the outside panels to take it apart. Basically any screw you find, take off. The easiest way not to loose them is by sticking them into the side of a box. After you get the camera panels off, you should be able to carefully get inside and dislodge anything that may be in the way. Once you are able to dislodge the cord or whatever is causing this problem. Try inserting the battery and ejecting the tape. Let me know if you are having any trouble with this or have any other questions and I would be glad to help.
Good luck
Posted on May 20, 2008
  • 23 Answers
SOURCE: connect Sony Handycam DCR-PC5 Mini DV Digital Camcorder to my Laptop
try to install the cd software of your sony handycam into your laptop..
hope it will help thanks...
Posted on May 27, 2008
SOURCE: cassette tape will not load
meow
Posted on Jun 12, 2008
  • 6 Answers
there is a small motor at the lower right corner ( if you face the tape side of the camcorder). check if the motor reponds to a 5v voltage. if not, that is the problem
Posted on Sep 06, 2008
My tape gets ejected after loading it in the compartment and makes a clicking noise and a constant flashing of an alarm bell on screen
There is a problem with the tape running in the machine. Check how tightly wound the tape might be
Please rate my help++++Thanks for using FIXYA
Feb 07, 2010 | Sony Handycam DCR-HC30 Mini DV Digital...
I have a Sony handycam DRC-HC26. After placing the DV tape the tape refuse to load into the tape compartment and as such the tape door cannot be closed. Please advise.
The mechanical of tape loading compartment is misaligned and it needs readjustment which is a bit technical issue. Please contact any expert for mechanical adjustment of tape loading path assembly.
This will solve your problem.
Thanks.
Nov 24, 2009 | Sony Handycam DCR-HC21 Mini DV Digital...
I have a sony handycam dcr-hc26 that wont close the type door can you please help me ??
I have a sony handycam DCR-HC26. After loading in the DV cassette tape and the tape cannot get loaded in and therefore I can't close the tape door. Please help.
Thanks
Nov 22, 2009 | Sony DCR-HC26 Mini DV Digital Camcorder
The tape door won't shut. Help please!
Drum is not responding or not getting up in speed loading the circuiot down jumping into protection mode.
Aug 03, 2009 | Sony Handycam DCR-HC30 Mini DV Digital...
Problem loading tape
the tape may be the wrong sort for you particular camera or there could be falty wiring in the display box i suggest that you get a specialist to help this isn't really my cup of tea.
Jun 27, 2008 | Sony Handycam DCR-PC100 Mini DV Digital...
Cassette tape will not load
I am sorry, No simple solution available for this problem. Your camera required new DV Mechanism.
Apr 07, 2008 | Sony Handycam DCR-HC32 Mini DV Digital...
Sony DCR TRV38
Good Day, you need to supply 4.5V DC regulated to the loading motor, however you should disconnect the connector from main board to loading motor, in order not to damage the driver IC. If your technically inclined, and you have the equipment, do it, if your not sure, just refer it to the nearest svc ctr. thanks
Sep 04, 2007 | Sony Handycam DCR-TRV38 Mini DV Digital...
Trouble working sony dcr-trv6 mini dv digital camcorder
( c : cassette : 30 capstan fg ) ; your capstan motor is stalling - try ( other brand ) new tapes and gently ! swaying camera from side while loading - if loads , your tape mechanism is dirty or is going out of alignment ; - - if the camera will not unload tape ? the capstan motor may be failing ( connector is loose , corroded ) or - it is jammed and it needs . . . disassembly . . . to complete checking .
Aug 06, 2007 | Sony Handycam DCR-TRV6 Mini DV Digital...
Sony Handycam DCR-HC54E Mini DV Logo
Top Sony Electronics - Others Experts
Sandy Moore
Sandy Moore
 Grubhead
Grubhead
Are you a Sony Electronics - Other Expert? Answer questions, earn points and help others
