Question about Freezers
Help a new homeowner !!
Electrolux freezer not freezing
Is not freezing, then it need to be well refill with gas
Posted on May 08, 2013
Hello,I defrosted my electrolux chest freezer and now problem is power is on but not freezing,alarm light keeps coming and keeps bleeping every 2 minutes and goes off and on
Is the compressor running? if it is running, but there is no cooling, it is time to buy a new freezer.
If the compressor is NOT running, I would suspect the compressor start relay.
How did you defrost it?
Jun 09, 2016 | Electrolux Frigidaire 14.8 cu. ft. Chest...
Freeze's on bottom 12' on top 40'
Hello Paul Rorrer, thanks for your inquiry!
I see that your question is listed under Electrolux freezer. Please help me understand the question you are asking. Is it freezing on the racks? Or is there a frost buildup? I would recommend turning the temperature down to help alleviate some of the cold air building up inside of your freezer.
Additionally if there is a frost buildup I would recommend checking your gasket to see if it is in good condition. You can do that by using a dollar bill. Place a dollar bill between the body of the freezer and close the door. The dollar bill should stay in place and pull out with a small amount of resistance. If the dollar bill falls out when placed between the gasket and cabinet double check to see if the door is being blocked by anything stopping it from closing it. If nothing is stopping the door from closing then replace the gasket. If you could provide me any more information I would be happy to assist you. -Matt
Sep 25, 2014 | Electrolux 21.0 Cu. Ft. Upright Freezer -...
Electrolux freezer will not turn on automatically when termperature warms in compartment, controls don't appear to turn compressor on, any help would be appreciated?
Sounds like your thermostat is bad. You probably have to replace it and the sending unit also. Big job! Look for a manual at : http://www.servicemanuals.net
Apr 28, 2014 | Electrolux Freezers
Electrolux fridge freezer, Motor never turns off. replaced thermostat, still motor keeps running. The back, top half of fridge freezes over but the temperature remains cool?
dear sir/madam
i think this is thermostat setting problem please make sure freezer,s thermostat nobe (nidle) is in correct position .then see thermostat temperature settings . may be thermostat is not controlling to compressor motor that why it,s running continuously.
hope answer the question,
thank you
please vote!
Sep 02, 2010 | Electrolux Freezers
Ice forming on "ceiling" of freezer, on hinge side.
Yes it is and its typically quite easy to do.
First you will need to determine what type of gasket is in the unit. Typically its just a push in style gasket that is held in place by a dart style backing that holds it into place.
A tip to use is to soak the new gasket in screaming hot water for about 5 minutes before installation. The install it right away. The hot water will make the gasket easier to handle and it will slide into place easily. The just leave the door closed for about an hour to allow the new gasket to form up and hold into place.
Good luck
May 19, 2010 | Electrolux 16.8 cu. ft. Upright Freezer...
Its not freezing!! keeping things cool, but not freezing
I would definitely start by checking if the fan is working. Note that the fan is switched off when you open the door, so you need to press the door switch and then check if it is working. If not, that will be the problem.
Apr 15, 2009 | Electrolux 3.53 cu. ft. / 100 liter...
Used freezer won't freeze food
If the compressor is running and it still doesn't cool, it is probably leaking freon. If this is a frostless model there are other minor things that can go wrong. This usually shows up on a freezer that has recently been moved or hasn't been used for a time. This is almost never worth fixing as even if you fix it you can't ever completely trust it again. The food inside is usually worth far more than the freezer and most homeowners insurance doesn't cover it anyway.
Jun 30, 2008 | Freezers
Freezers Logo
52 people viewed this question
Top Freezers Experts
Dennis Boxerman
AJMAL KHAN
John Tripp
John Tripp
Are you a Freezer Expert? Answer questions, earn points and help others
