Question about HP LaserJet Pro 100 color MFP M175nw - multifunction printer / copier / scanner color
Copy/scan: document feeder mispick - HP LaserJet Pro 100 color MFP M175nw - multifunction printer / copier / scanner color
5 Suggested Answers
SOURCE: keeps asking to load original in document feeder
This has a happy ending. But first, the obligatory narrative:
The HP site has advice on how to deal with a document feeder that doesn't detect your document. It doesn't talk about the opposite problem, which is what molecular is describing. I had the identical problem yesterday. I'd place the original on the glass and it kept demanding that I put the original in the feeder. So I got into a chat session with the HP technician. Her advice, (based on the possibility that a power surge had created the problem) unplug from everything, restart, and retry. The problem persisted. I told her so. She broke the connection. Nice.
So here is how I fixed it. Using the Setup button>Tools>3. Restore factory defaults, I returned the device to its factory settings. I put the original on the glass and it made the copy without a problem.
Here is a pure speculation. There are at least two ways to enter settings related to two-sided copying. I had used one to enter the settings (two-sided original to two-sided copy, as it happens) and later tried to use another button to change those settings. I noticed the 2-sided settings did not change. I believe the feeder is the default for two-sided copying. So when the system failed to clear the settings, it failed to clear the default. Once I returned all settings to the factory originals, the problem disappeared.
Posted on Mar 14, 2008
SOURCE: paper in document feeder
there is no paper in document feeder
Posted on Dec 01, 2008
SOURCE: No Paper in Document Feeder
I just upgrated my Vista system as recomanded, and after that I am not able to scan documents, getting the messGE " NO PAPER IN THE DOCUMENT FEEDER " on my all in one laiser jet 3050
Posted on Jul 14, 2010
jafari_ha951
SOURCE: Problem with copy/scan from Feeder
clean that small glass on printer if problem still continue open all machine and try blow it blower machine!
Posted on May 19, 2012
Document feeder mispick.reload
Clean rollers in the ADF (automatic document feeder) with methylated alcohol for quick fix or replace the roller assembly
PN: 5851-2559 and seperation pad PN: Q2665-60125
Dec 24, 2013 | HP LaserJet 3055 All-In-One Printer
3055 glass
There is no need to change the mode. When the document is loaded on the document feeder, the screen displays "DOCUMENT LOADED" and shall copy or scan this document. To copy or scan from glass, DO NOT LOAD ANY DOCUMENT IN THE FEEDER. The printer will automatically copy / scan from glass.
May 10, 2013 | HP LaserJet 3055 All-In-One Printer
I have a Epson cx11 and get a black vertical line down the middle of scans and copies
Check your flat bed and Document feeder scanning glass need to be clean, if any dot or dust in scanning glass of document feeder it will appear a line, check this points first
1- Check printouts from computer or FAX if it is clean problem in scanning section
2- Check using Copying a blank paper using only Flatbed if it prints without any line its problem from document feeder Scanning glass
So solution is clean the Document feeder scanning glass using wet cloth, note careful about wet cloth switch off the machine and clean it
Feb 04, 2013 | Epson AcuLaser CX11NF Printer
Our HP Laserjet 2840 gives document feeder malfunction. the On Screen msg reads document mispick.
Check the feeder, it is either loose or broken making the printer to think that you have in a different size or type of document.
Aug 18, 2009 | HP LaserJet 2840 Printer
Not scanning or copying when using the ADF on HP laserjet 3055
Based on the assumption it's mechanically ok, check the cable connection between the document feeder and the base, if damaged or worked look it can cause errors. If it is a sensor error, check for a small bit of paper or even a staple from a prior jam.
Jun 18, 2009 | HP LaserJet 3055 All-In-One Printer
Unable to copy from scanning bed
There is probably a little switch that gets tripped when the document feeder is in correctly. This is preventing you from scanning from the glass.
Jun 02, 2009 | HP Officejet 7310 All-In-One Printer
HP LaserJet Pro 100 color MFP M175nw - multifunction  printer / copier / scanner   color Logo
122 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
