Sanyo DP42840-00 power issue inverter board problem
I have a Sanyo dp42840-00 that I have went thru the steps of troubleshooting and came to conclusion according to service manual is its bad inverter board. I was wondering if there was way to fix at home? Tv turns on for 3 seconds then back off, I can also click 3 times in row then pull ac out to get it out of lockout mode. Now on the main board when I disconnect the K8L connection the backlight comes back on but off again in 3 seconds. With that connection connected backlight stays off. I checked caps and voltages all seemed ok. Any ideas without replacing entire boards by chance?
    Top Expert:
  • Televison & ... Master
  • 75,571 Answers
If you wish to get some details; visit the site linked here. Pull up older posts.
Posted on Apr 22, 2017
  • 191 Answers
SOURCE: VIZIO LCD 26 INCH model# VW26L HDTV10F NOT TURNING ON
unplug ur backlight inverter plug &power on to see ,if it doesnt on , change ur mainboard
Posted on Nov 10, 2008
SOURCE: RE: Dell W4201C
i have a Dell W4201C ,the picture Dims or picture blinks when channel changes
Posted on Jul 03, 2009
  • 10 Answers
SOURCE: Sony KDL-46s2010 4 red light blinks
I would suspect one or more of the miniature flourescent backlight lamps. One way to confirm this would be to power up the set with a grayscale image at 40 to 60 IRE. If one or more lamps is failing to light, a slightly darker horizontal area in the grayscale will give it away. Unfortunately, Sony will not supply any of the backlight components apart from a new LCD panel. Sorry.
Posted on Sep 01, 2009
  • 157 Answers
SOURCE: TV green lite comes on for 2 seconds--goes back to
you posted the model number in reverse-----32pf double check-only thing i found so far -------replace c601 470/25v
someone else found a bad FET did u check them
do u have a pdf of this one
Posted on Sep 16, 2009
BoiseLCD
  • 63 Answers
SOURCE: I have a NS-LCD37-09 tv. No picture or backlight
Your main board is faulty. I've done several of these but haven't been able to figure out which component is actually bad these yet. I've simply had to replace the board itself, and it fixes it every time. One thing you can do to get your backlights to come on (and so you know I'm not Jive'n you) Is unplug the three wire bundle that spans from power supply to main board. This will usually make the backlights fire up. I even had one that after I left it that way for a minute (with the backlight on) it suddenly started working again! But this was short lived. :-(
One time I even tried recapping the entire main to see it that would fix it. It did not. I think it might be something to do with the small chip labeled SL37HA37. It's a 16 legged bastard near the 3-wire plug I told you to pull. It's that or possibly the bigger IC near it that has a heat sink on it. The ball grid array solder joints may be faulty. Just guesses, if any smart guys out there figure this one out, be sure to tell the rest of us please!
Thanks, Chris Boise LCD www.boiselcd.com
Posted on Apr 23, 2010
My sanyo DP42840 won't come on.my power supply is good.the connection is good.
Main digital board fault. Check and replace it. If you wish to get more details visit the site linked here. http://electronicshelponline.blogspot.com/
Jan 31, 2017 | Sanyo Dp42840a
Model Dp42840. Why is left side of screen black?
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
Oct 23, 2015 | Sanyo Televison & Video
What else should I check on my Sanyo DP42840?
This could be the tuner overheating and sending a signal from the tuner board CPU to the power board to instruct the tuner to turn off. Check that there is adequate ventilation in the TV. Try testing with a fan to see if that changes the behaviour of the loop that you get.
Aug 31, 2014 | Sanyo Televison & Video
Sanyo DP42840 power cycles every 15-30 seconds and the display never gets backlight
Sounds like main board fault. Contact the authorized service center for Samsung. Gopakumar Gopalan Google
Mar 08, 2014 | Sanyo Televison & Video
Sanyo DP42840 with power on issue. I press power button and Green power LED lights for 10 seconds as it goes through its normal start up / warm up procedure. Instead of powering on, the TV powers off...
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Pull up older posts.
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
May 19, 2017 | Televison & Video
Sanyo DP42849 no picture but has sound
Sounds like an inverter problem. On some of these sets, the inverter and the power supply are on the same board. These boards tend to be quite pricey, $100 + range. I've worked on your particular model with the same problem, and it was a bad inverter/power supply board. I would recommend you get a diagnosis to be sure.
Oct 28, 2012 | Sanyo DP42849 42 in. HDTV
Sanyo DP42840 HDTV LCD wont come on.
Check and replace its power supply regulator board. Seek tech support.
Jun 01, 2012 | Sanyo Televison & Video
My sanyo dp42840 flat screen turns off by itself after 5 minutes...what do I do?
The first thing I would check would be the electrolytic capacitors on the power supply board. If any of them are swollen or domed on top rather than flat, they will need to be replaced and that will fix your problem. I fix about 75% of them at the shop by replacing caps on power supply. A tech will probably charge around $100 if it is bad caps. It is a fairly easy job.
Jul 31, 2010 | Sanyo DP42848 LCD TV
Televison & Video Logo
69 people viewed this question
Top Televison & Video Experts
