Question about Lenovo ThinkPad T410 Notebook
Lid to my lenovo does not close tightly
I can shut the lid, but it does not catch and close firmly. Why?
  • Lenovo Master
  • 32,281 Answers
The catch maybe broken.
Posted on May 08, 2013
I dropped paper towel behind the drum in the top load washing machine. Do I need to worry?
Maybe not.
Unplug the power from the wall.
Take a putty knife blade and bright light, find the catches at the front of the machine at the gap just between the top and bottom an inch or so in from both sides. Slip the putty knife in at the catch and apply pressure to the highest part of the catch while gently lifting the lid on the side until it releases. Do the same to the other front catch until it releases. Now hang on to the hinged door lid while opening the whole lid towards the rear and fish out the lost item. Gently close the whole lid and while it is resting on the catches, give the lid a final press down to latch the lid closed on the latches. Plug the machine back in and feel the accomplishment of a DYI'er!
I would rather you recover the errant object than risk harm from it getting into the motor. If it is too far to reach, use a yard stick with masking tape attached to snare the paper towel with the sticky side of the tape extending off the end of the stick.
May 21, 2016 | Maytag Washing Machines
Cooks essential #99770 2 art Pressure cooker lid when manual closed is not exactly even
The valves on the lid are "floating" valves, that means they will not sit firmly on the lid. However, food and gunk can get stuck in these valves. Remove it, soak it in hot soapy water, clean the inside with a toothpick and also clean the pipe on the lid that holds the weight. Your pressure cooker should be as good as new!
Sep 20, 2015 | Home
Trunk lid will not close. motor is not catching. Motor is not functioning.
If the latch on the deck lid does not catch your problem is the latch catch. If it closes and does not pull down you will need a pull down switch,
Aug 10, 2009 | 1999 Cadillac DeVille
2000 Lexus ES300 trunk lid does not fit right on 2001 Lexus ES300
Hi, try loosening the catch on the trunk lid but do not remove it and the lock mechanism, close the trunk lid but not fully, then pull the backseats down and climb into the trunk. Adjust the lock and latch until they meet up and lock together ( This will take some time and patience is essential). Fasten the Catch and Lock back up. Then retry opening and closing, if it still doesnt fit just do the same again, just needs a bit of adjustment.
hope this helps. jonno
Apr 21, 2009 | 2001 Lexus ES 300
2005 audi a8 trunk + upgrades for ipod integration
I had exact same problem, but what I found out was a three step solution to the problem.
1) The trunk lock above the trunk lid tself - sometimes looses coiling retention for the lock to work properly, which in effect does not properly lock wrap around the pull down electronic unit located in the body of the car/trunk that catches and pull the trunk lid down SOLUTION: check and make sure lock is works properly. you cab check by opening trunk and locking it with remote key, then pry the lock with a screw driver to see if it unlocks or stays locked
2) The motor catching unit in the body of the car/trunk that catches the lid and draws it down can be off balance (sitting too low to catch the lock (upper trunk lid with lock) to pull it down and stay locked. Have a mechanic - Audi preferrably, check the positon and allignment to adjust it, so it can catch trunk lid and lock to stay locked. HOPE THIS HELPS!
Dec 02, 2008 | 2005 Audi A8
Trunk and hood manual latch won't work
That is not the problem the problem is your convertable roof is not closing properly to test this let someone press down on the roof lid and then try to open the trunk, To fix this let the roof lid open and let the roof come up until the back part stands up to let the roof lid close so that the roof hold is exposed look on the right hand side of the car (if your standing at the back) under the roof lid catch there is a small plastic buttun that the roof lid catch needs to pres down on, this tells the car that the roof lid is seucre and it is now safe to let open the trunk, All you have to do is set the tension on the cable for that roof lid catch and the problem is sorted.
Beamerguy
Sep 03, 2008 | 1997 BMW 328
Fisher and paykel dishwasher
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin.
If a flood condition is detected, both draws will activate the drain motors and flash F1.
Remove the bottom drawer by pulling the lock pins on each lower side corner. Slide down and remove front cover. Release the drawer slide clips and remove drawer then dry the catch basin.
There are three possible scenarios for this error code;
1. Defective lid motor(s)...Each drawer has two lid motors, attached to the cabinet on either side of the drawer, that pull the lid tight to the drawer when the cycle is started. (this was very common on early models)
2. Something too tall was placed in the drawer preventing the lid from closing completely.
3. (only seen this once) the drain hose developed a crack causing water to leak only when draining.
Jul 03, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
WASHER FILLS BUT THEN WON'T START. WILL LIFT THE LIFT AND CLOSE SEVERAL TIMES AND THEN WILL START. NOW DOESN'T START AT ALL. IS THIS THE SWITCH ON THE DOOR, SHOWING IT ISN'T CLOSED SO IT WON'T START?
must be a whirpool or kenmore shut lid try pressing down on left rear corner be sure lid hinge screws are tight then raise lid on left corner under top out of sight you will feel small lever push toward back of washer slightly and then try again also if lid center has popped down push up slightly in center till lid pops back up sen it happen once where washer would not spin
Jun 17, 2008 | Washing Machines
Washer will not agitate. After starting the washer the water will begin to fill but when it's time for the agitator to begin it shuts the whole machine off.
If the lid lifts up from the front, tighten the hinge screws on both sides of the lid. If the screws are tight open and close the lid..listen for a click.. no click..lid switch is bad.
Jun 12, 2008 | Kenmore Washing Machines
Fisher and paykel dd-603ss
F1 is a flood code meaning excessive amounts of water have collected on the bottom catch basin. If a flood condition is detected, both draws will activate the drain motors and flash F1. Remove the bottom drawer and dry the catch basin.
There are three possible scenarios; 1. Defective lid motor(s)...Each drawer has two lid motors that pull the lid tight to the drawer when the cycle is started. (this was very common on early models) 2. Something too tall was placed in the drawer preventing the lid from closing completely. OR 3. (only seen this once) the drain hose developed a crack causing water to leak only when draining. Hope this helps....
Jun 06, 2008 | Fisher and Paykel 23 in. DD-603SS Built-in...
Lenovo ThinkPad T410 Notebook Logo
170 people viewed this question
Top Lenovo Computers & Internet Experts
Michael Vincent Cruz
Are you a Lenovo Computer and Internet Expert? Answer questions, earn points and help others
