Question about Dell OptiPlex GX620 PC Desktop
How to install window 7 64 bit my optilex gx620
Please help when i try to install window 7 64 my optilex GX620 error occurd "insert disk no disk" but cd install an other core 2 dua pc window 7 64 install without any error
    New Friend:
    Problem Solver:
  • 12 Answers
If someone need windows key that i suggest you go site www.funkinyes.com to got. 100% genuine it to provide according my experience.
Posted on Mar 02, 2016
  • 542 Answers
Here's a video Dan Shibata suggested as a solution to your problem from YouTube:
Dell Optiplex 330 Running Windows 7 64-bit
Posted on May 08, 2013
scanss2k
  • 166 Answers
SOURCE: reinstall windows xp pro
Ok firstly, you will need to get rid of Vista all together before you can Install XP, Use a partition program to do this, You can find a bunch just by typing partition software into google, Delete the main partition that windows is on, Then create a new partition, then format that partition as a Primary partition, I always use the NTFS format just for stability and it can handle larger files than a 32 Bit partition, when you have done that then you need to get a bootable windows xp and I think you have that if set up is starting but hanging. Just go through the windows setup and you will be done. BE AWARE that you will loose everything thats on the drive by doing this so backup what you want to keep before you start, Always an idea to get the XP drivers for the system as well, The Vista drivers WILL NOT work on an XP system
Hope that helps.
If you run into problems then let me know and I will help you with it
Posted on Aug 22, 2008
  • 166 Answers
SOURCE: Dell Optiplex GX620 PC is failing to power up
You may have a failed motherboard then. Failure of motherboards is usually due to breaking capacitors. A few years ago a capacitor company stole the "recipe" for making capacitors from another company and tried to make their own, unfortunately they did not get the ingredients right and the capacitors started breaking after 2-3 years of use. They sold these capacitors at very cheap prices and a lot of computer companies and power supply makers bought them. This is easy to diagnose. Look for capacitors (caps) (they look like little tiny soda cans) on your motherboard (mobo). They should be perfectly flat on top and not bulged or swelling or leaking anything. Make sure you look at all of them, on DELL's especially look under the cooling fan shroud as well. The dead giveaway is the fact that you are not getting anything after you changed the PSU. There are a few companies that will repair broken capacitor issues. Also if you add a bunch of extra components without upgrading the power supply you can suffer underpowered situations and that can cause internal parts to fail.
To eliminate some other stuff you could remove the memory and disconnect all the power plugs from the drives and then try to start it up. If it does not change the behavior at all (no beeps, no change in flashing lights) then you probably have motherboard issues. Make sure when disconnecting the memory chips (sticks) that you touch the metal on the inside of the case first to discharge static electricity. If it does change the behavior add 1 component or item back at a time to see what you can find out. Post back with what you find. And remember a bad PSU does not mean no power, just not enough to run the computer. Is the PSU that you replaced the same or greater output watts?
Posted on Apr 29, 2009
  • 13 Answers
SOURCE: Hi MY Dell OptiPlex GX620 have a hardware
try the bios settings is your monitor in a grafics card slot
also see if plug and play is enabled only use a keybard and mouse with a ps2 conection not usb
Posted on Nov 24, 2009
  • 113 Answers
SOURCE: Windows 7 drivers for Optiplex GX620
for drivers u visit driversdownload.com, register and then dowload required drivers for ur comp. i doubt ur computer is affected with virus. pls check it also
Posted on Jul 14, 2010
emissionwiz
  • 78289 Answers
SOURCE: Dell Opitplex GX620 - "System
If you pull the side access cover off the computer tower, look inside and you will see a large circuit board, that is the Motherboard, on that board you will see a button sized silver battery, this is the battery backup for the "CMOS", and keeps the time and other memory functions alive. Carefully pry out the old battery and replace it with a new one, any Radio Shack or electroinics supply will have the battery. The battery number is on the battery. Make sure to install the battery exactly as it came out, it has a positive and negative side, write it down.
Posted on Jan 04, 2011
Testimonial: "I thought is might be the internal battery, i just wanted to check it out before cracking it open."
Dell optilex gx520 driver for window 7 ultimate'
https://www.slimwareutilities.com/slimdrivers.php
May 18, 2014 | Dell OptiPlex GX620 PC Desktop
I have a Dell Optiplex GX620 with a 64-bit Intel chip, and 6 GB of RAM, and I can't install any 64 bit versions of Windows on it.
your ram may be bad but not fried so windows cant deyect it also may need to reset your ram aet in advanced setting ,although your system sjhould detect that and adjust so check system in control; panel see if its is matchiing ie .. if u put 4 gb ram it may say 3gb ,if it has 4 gb then yiur settings systems icon control panel double click avanced system settings click on it then click on advaced scroll down to virtual memory it should be for 4 bg. ram would read 4000 MB OR REAL CLOSE TO ADJUST IT,, AL;SO U MUST HAVE 64 BIT OS XP AND REINSTALL OS PLUS PICK 64 BIT DRIVERS FROM MANUFACTER OF PC TO RUN 64 BIT CANT HAVE 1/2 AND 1/2 [32 +64] DONT MESH FOR 64BIT...32 CAN HAVE BOTH NOT 64
Jan 18, 2013 | Dell OptiPlex GX620 PC Desktop
Intergrated sound max not working
may be your computer have no proper sound drive so u must install your sound driver first after we can check the hardware error of your motherboard.. you can download driver from here http://www.getpcmemory.com/drivers/download-dell-optiplex-gx620-desktop-pc-windows-xp-vista-drivers/
Sep 05, 2011 | Dell OptiPlex GX620 PC Desktop
I can't get into windows of my Dell Optiplex GX620. I try but the computer gives the following message: <<Stop C000021a. Fatal System Error. The session manager initialized system process terminated...
You most likely have a hardware issue. Very possibly memory.
You'll need to troubleshoot that by disconnecting everything in the case but the video, CPU, and memory and see if it starts OK.
Then hook up the hard drive and see if you can boot into Windows. If you can't, unplug one of the memory sticks and try it. Then the other memory stick and try.
If you have a Windows startup (installation disk), boot from that and opt for system repair. You will want to get to the command prompt and run chkdsk.
See my tip here:
http://www.fixya.com/support/r4501608-when_windows_xp_start_primary_fix
Jul 29, 2010 | Dell OptiPlex GX620 PC Desktop
Jul 14, 2010 | Dell OptiPlex GX620 PC Desktop
Hi I have an optilex gx620 pc that its sound card is not fuctioning .I do not know its name because the device manager refuses to open .please help me to find a solution to the sound problem.
found driver from this site, try to download and install.
http://support.dell.com/support/downloads/driverslist.aspx?os=WW1&catid=3&dateid=-1&impid=-1&osl=EN&typeid=-1&formatid=-1&servicetag=&SystemID=DIM_P4_4700&hidos=WW1&hidlang=en&TabIndex=&scanSupported=False&scanConsent=False
Apr 13, 2010 | Dell Dimension 4700 PC Desktop
Dell OptiPlex GX620 PC Desktop Logo
140 people viewed this question
Alun Cox
