Question about Rangemaster Elan 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range
Clock and oven inoperative on elan rangemaster 90
Oven clock does not work looked at solutions no reset switch I can see and no cancel button,and ovens do not work grill works and right hand oven fan works and all the gas of course but ignition does not this is a new oven just installed many thanks in advance...ray
  • Anonymous Mar 18, 2014
    the clock has gone off so the fan oven and grill will not come on unsure if there is some sort of fuse in it or it can be bypassed so the clock dont work but the oven does
    fan oven not working as clock wont work
    President:
  • 331 Answers
Your electronic oven control (clock) has failed. This being a new appliance, it will be covered under warranty. Call the dealer and ask for the manufacturers warranty/customer service phone number or ask if the dealer provides warranty service. You will need to provide them with the Model and Serial number to obtain service, so have this ready when you call. After service is complete, please connect your oven to a quality surge suppression/arrestor device. We recommend these... http://catalog.belkin.com/IWCatProductPage.process?Product_Id=124911 , they can be found here... http://www.belkin.com/wheretobuy/show.aspx?pid=&targ=19&ttr=3e86a31d-23dd-4b8d-acbf-2adf1ce9ecc0&cid=1
Posted on Aug 11, 2007
My clock on my Rangemaster Toledo 90 kept switching off last night whilst using it and ovens went off as well turned it back on twice and then the 3rd time it won't come back on. Its dual fuel so the gas...
Power from switchboard > oven circuit cabling > supply terminals of oven > high temp cutout > timer > multifunction switch.
usually the high temp, if so, check the cooling fan is working. Watch out for dodgy crimp connections on the wires (mechanical stripping can nick strands off the wire making a hot spot)
Oct 18, 2013 | Rangemaster Kitchen Ranges
Timer not working - flashing auto permanently so cannot light either of the ovens. Have tried reset but has not worked
Try the 6 push buttons under the clock.
press in the first two buttons from the left simultaneously and then the - and + to adjust the clock. Thats how it works on my Classic 90 but not certain about the 110
Sep 26, 2013 | Rangemaster Proffessional 110 Gas Kitchen...
I AM LOOKING FOR THE SERIAL NUMBER FOR MY RANGEMASTER DUAL FUEL 90..WHERE IS IT??
it,s on the back of your oven on the left hand side looking at it from the back there,s a large silver sticker with different country,s name,s and a small silver sticker just below it with the make and model number on it hope this help for you '
Jan 30, 2013 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
New applaince can't set clock, cannot switch on eletric ovens, electric grill works, gas hobs fine
I'm sure you must have had an answer by now, but just incase anyone else has the same issue. The ovens don't work unless the clock has been set (happens after a power cut). To set the clock you need to hold down the left-hand two buttons (underneath the clock) and at the same time press either the + or - button.
Oct 19, 2009 | Rangemaster Classic 90 (Electric) Kitchen...
I have 0.00 and aoto flashing on and off.
After a power failure most digital clocks have the zero's and auto flashing. These ovens will not work if clock(time of day) is not set. By pressing incorrect buttons, you can complicate things further. Recommend turning off power to oven for a few seconds, then follow manual for resetting clock, which is usually holding down the 2 buttons on the left hand side simultaneously, and holding down these two press the + or - key to advance clock.
May 21, 2009 | Rangemaster Toledo 90 (Dual Fuel) Dual...
Both ovens on my leisure rangemaster 100 will not come on
phone rangemaster they can advise how to change the spark in egnition and supply bit. 08707 895 107
Jan 23, 2009 | Rangemaster 110 (Gas) Kitchen Range
Elan 1100
I had a similar problem with my Rangemaster Toledo 110. The glass cover would move slightly but would stop as if being held by something. I went to the Rangemaster website and the checked the users manual which suggested it was a simple operation of turning anticlockwise. Eventually I got a pair of vice grips and opened them to their widest and clamped them round the glass. The slightest of pressure and the glass moved past the stop point and off!! I've replaced the bulb and put the glass back on only hand tight and in anticipation I've loosened the glass cover in the other oven - just in case!
Dec 16, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Rangemaster Toledo
we had the same problem - a power cut then the clock flashed up 'auto' preventing the oven from working.
After downloading the manual from the rangemaster website we learnt that all you need to do (for the classic dual fuel anyway) is to press in the 2 buttons on the left and set the time using the + or - keys. Dead easy and Christmas dinner is back on!
Sep 02, 2007 | Rangemaster Elan 90 (Dual Fuel) Dual Fuel...
Rangemaster Elan 90 (Dual Fuel) Dual Fuel (Electric and Gas) Kitchen Range Logo
388 people viewed this question
Top Rangemaster Kitchen Ranges Experts
Ismael Rodriguez...
Paul Carew
Archie Ferrarini
Archie Ferrarini
Are you a Rangemaster Kitchen Range Expert? Answer questions, earn points and help others
