Question about Samsung LN52a750R1FXZA
Dark Screen When I turn on TV the left side screen is dark and blurry. TV warms up left side screen blurry, has trails. Left side looking at TV. Rest of TV screen seems a little darker. Found the other day when I cleaned the screen it went to normal after a few minutes. This did not last after turning TV off. Any idea's
    Top Expert:
  • Samsung Master
  • 74,185 Answers
It sounds like a back-light problem. Check all the CCFL back-lights.
Posted on May 08, 2013
  • 2509 Answers
SOURCE: I have a samsung 1080 full hd 38" flat screen tv,
I think the backlight is failing, you will need to have it replaced. It is also possible that the backlight inverter (power supply) may be faulty but that usually shows up a fault. I think it unlikely that the screen itself has failed unless it has been subjected to pressure damage.
I hope I have been of help but please do not hesitate to ask if you have any further questions.
I appreciate your vote if you appreciate my reply.
Posted on Mar 01, 2011
eagle338
  • 4889 Answers
SOURCE: I have a Samsung HDTV (LN-T5271F) approx 4 yrs
Do these bands appear even when no input is connected to the tv? It will help us isolate whether its an LCD controller problem or a problem with the video processing circuits
Posted on Feb 20, 2011
  • 1039 Answers
SOURCE: Very slow to turn on and has small light spots all over screen
The first thing to look for are swollen capacitors on the power board.replace them if so.
Posted on Sep 12, 2009
  • 132 Answers
SOURCE: When I turn on the tv, the left side of the screen
It sounds like you have a bad slave inverter board. I've fixed a few of them with the same problem and it's always been this board. With the back off of the tv, it will be the board located all the way to the end where the problem is. It will have several wires going from it to the screen. You will probably have to get the part number off of the board to be able to find one, as I couldn't find one by using that model number.
Posted on Sep 02, 2010
welcomejee
  • 10594 Answers
SOURCE: Samsung 46" TV. Model
This is problem of lcd panel (screen) that is going bad, however, in few tvs, T-Con board was defective that is also part of lcd panel but available separately, t-con board is located on top center of lcd panel at rear side, replace it that might fix tv problem.
Required t-con board is available in ShopJimmy.com for $73 (click the link to view board image and price info) and call local tv repairman to replace it if you are not handy with electronics stuff repair or have no prior experience.
If t-con board replacement does not solve the issue then lcd panel (screen) will be replaced but it would cost you approx new tv price.
Hope these info will help you.
Let me know if you have additional question.
Thanks.
Posted on Nov 21, 2010
My Vizio TV has dark spot top left corner
Hi Brandon,
I am afraid that the dark spot in the screen is not repairable. Manage as long as you can or go for a new tv.
Apr 08, 2015 | VIZIO M701d A3R 70 Inch 1080p Smart
Dark Spot on Lower left screen
1,white spots appeared on screen,means the DMD is broken,you need a new DMD. USD150-200
any questions, feel free to ask me
have a nice day!
Jerry Lampdeng Limited
Feb 03, 2014 | Acer H5360 3D DLP Projector
Sharp LED TV 3 years old stays dark on left side of screen for about 10 minutes after it is turned on. What could be causing this?
It seems to be capacitor{s}. Check the sharp website to see if there is any recall or special warranty on this unit.
Dec 15, 2013 | Sanyo 46" Class LCD 1080p 60Hz HDTV,...
LN-T4971F dark on the right side of screen.
Hey Steve,
Sorry to be the bearer of bad news but you have a bad LCD panel tab. There are videos on youtube that show you how to repair this but they are temporary in nature.
Jun 28, 2013 | Samsung Televison & Video
Half the screen isa dark, left side
Most likely you have a faulty LCD panel tabs. This can be verified sometimes by turning set on and tapping or squeezing the top left side of the TV. The only true fix is to replace the panel. I've been told that Samsung may offer to replace the panel or give you a discount on a new TV. Samsung is know to have LCD panels with premature tab failure. So it may be worth while to contact Samsung and see what they can do for you. There are videos on youtube that show case the problems and show you how to patch the problem. just type in "LCD panel tab" in the youtube search box.
Feb 17, 2013 | Samsung LN46A550 LCD TV
Sony KDL-52WL130 Dark and blurry on left side of screen . Also vertical lines on left side of screen
The TV requires thorough servicing and this might require attention by a qualified service technician.
Jul 12, 2012 | Televison & Video
Dark line down the middle of my flat screen tv
Most LCD and PLASMA sets use two boards (some combine them into one board) that drive the Display Panel (the entire front screen unit) so I would suspect one of yours is bad.
The other unpleasant possible cause is where the left board is connected to the Display Panel (entire front screen unit) you have a problem inside that Display Panel and that is fatal as there is no way to get INSIDE the panel---it can cause both lines and a dark picture on one side of the screen.
May 25, 2012 | Sylvania Televison & Video
Samsung LN52a750R1FXZA Logo
394 people viewed this question
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
