Question about Westinghouse LD-3235 32in LED 720p Flat Panel HDTV
Westinghouse tv channel access code - Westinghouse LD-3235 32in LED 720p Flat Panel HDTV
2 Suggested Answers
  • 1214 Answers
SOURCE: I need a channel access code for a Westinghouse model VR5535Z
try this...
Contact westinghouse Channel Access Service by:
web: www.westinghousedigital.com/support;
select Channel Access and enter Access info.
Text Message: Text Tuner to 95495
Phone:1-800-701-0680 follow instructions
Posted on Jan 22, 2018
try this...
Jan 22, 2018 | Westinghouse Televison & Video
I cannot change the channel on Westinghouse TV. Model SK-19H2105 - Tried to do the fix mentioned for channel scan - cannot find the channel scan.
Press the “Menu” button on your remote or the side panel to access the On Screen Display
(OSD)
—Use the right/left arrow buttons to scroll across to the “Setup” menu
—Use the up/down arrow keys to select “TV” and “Quick Setup”
• Use the arrow keys to select your “Time Zone”, which allows you to receive
proper HDTV programming information
• Continue with arrow keys to select your signal source “Air/Cable/IRC/HRC”
—If you use a rooftop or indoor antenna, select “Air”
—If you use a cable service, select “Cable,” “IRC” or “HRC” (depending on the frequency
used by your cable service)
—Press the left arrow key to start scanning for channel
Aug 16, 2016 | Westinghouse Televison & Video
LD-2240 problem while trying to set up monitor all I get is no signal to any menu
Search Results
    Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240
    www.amazon.com/...1080p...LD2240/.../B007ATHRJ...
    Amazon.com, Inc.
    Rating: 2.9 - ‎21 reviews
    Amazon.com: Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240: Electronics. ...When I set it up I was disappointed with the sound but not surprised, it is a cheap TV... Apparently this is not an unusual problem for Westinghouse. ... Oh well, I tried. ...VideoSecu Articulating Arm TV LCD Monitor Wall Mount, Full Motion Tilt ...
    Amazon.com, Inc.Westinghouse 22" LED 1080p 60Hz HDTV ' LD2240 ... When I first hooked it up to my cable connection, through the coax connector (TV ... When using as a computer screenthere's an auto adjust and full manual control .... have endured compromised sound and picture, but I've never had this problem. .... Oh well, I tried.
Jan 11, 2016 | Westinghouse 22" Class LED 1080p 60Hz HDTV...
Needing the channel access code for a westinghouse tv model DW39F1Y1 serial number 7532V33500473
I need Code the Channel Access, WestingHouse Tv
Modelo: DW39F1Y1
N?mero De Serie: 7531V34300250
Jan 04, 2014 | Televison & Video
I had cable took off and now i want just basic tv the regular channels abc, nbc, cbs and fox but when i try to scan the channels its asking me for a 5 digits access code for the westinghouse
you can go online and get the code. for some reason you have to go to westinghouse website and put in your model serial number abd it will give you a code allowing your tv to pick up local tv channels i dont know the reasong behind this
Dec 18, 2012 | Westinghouse " 40"" Class - LCD - 1080p -...
Lost remote for vr-2218. Trying to do auto channel scan--says to hit ENTER, but without remote, can't do ENTER. I have FIOS, but Verizon remote won't program TV. Any idea what code may be?
Codes listed in my manual for White Westinghouse are 0169 or 0003 or 0014 or 0043. Are yousure though there isn't a flip down panel somewhere which gives you the option to access "enter"
Oct 07, 2012 | Westinghouse LTV-27W2 27 in. HD-Ready LCD...
Westinghouse - 60" Class / 1080p / 120Hz / LCD
There is a method called a Power Scan this method allows you to search for all possible codes. Try this until you reach a code that carries all of the functions desired. If the TV mode button starts flashing rapidly during this process you have exhausted all possible codes.
Power Scan
1.) Hold down the clear "TV" button on the remote for four seconds, then press 500 pound ( #)
2.) Hold down the clear "TV" button on the remote for four seconds, press the big power button once.
3.) Press the channel up button once per second until the TV turns off then press pound (#).
Daniel Busa
DISH Network
Customer Service
Apr 17, 2011 | Westinghouse 16093 Remote Control
I have a Philips CL043 universal remote. I can't find th tv code for a Westinghouse lcd tv.. can you help?
You can find codes for the remote here: http://www.urc.philips.com/ . Then look up the CL043 and click on the remote code finder. This is also called the SRU3004WM by Philips.
A Westinghouse TV should responds to one of the following codes: 0915, 0013, 1216, 0300 if the TV was released 6 months before the remote was programmed or earlier. (Whte Westinghouse codes are different.)
If those codes do not work, there is a manual code search option. With the TV on, press and hold Setup on the remote until the red indicator stays lit. Then press and release quickly the TV button on the remote (the LED will blink once). Then press the Channel Up button until the TV responds (up to 300 times). If you overshoot, press Channel Down to go back to the previous code. Press and release the Mute button to set the code. Check if the remote performs all the needed functions. If it doesn't, repeat the above steps to find another code.
I hope this helps.
(if the remote is older than the TV, you may need a newer universal remote.)
Jan 08, 2011 | Philips 5-Device Universal Learning Remote...
Westinghouse LD-3235 32in LED 720p Flat Panel HDTV Logo
161 people viewed this question
Top Westinghouse Televison & Video Experts
Jaime Hernandez
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
