Question about Car Audio & Video
JZY-817-G car stereo
My screen just turned white. please help me fix it
Im trying to hook my stereo in a ord focus 2005 but to many wires any solution please to get conected
Check this wiring for 2005 Ford Focus Car Stereo Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Yellow/Green
Car Radio Accessory Switched 12v+ Wire: Orange/Black
Car Radio Ground Wire: Black/Green
Car Radio Illumination Wire: Orange/Black
Car Stereo Dimmer Wire: N/A
Car Stereo Antenna Trigger Wire: N/A
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: N/A
Car Audio Front Speakers Size: N/A
Car Audio Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): White/Black
Left Front Speaker Negative Wire (-): Gray/Black
Right Front Speaker Positive Wire (+): White/Red
Right Front Speaker Negative Wire (-): Gray/Red
Car Audio Rear Speakers Size: N/A
Car Audio Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): White/Green
Left Rear Speaker Negative Wire (-): Gray/White
Right Rear Speaker Positive Wire (+): White
Right Rear Speaker Negative Wire (-): Gray
Hope help with this; keep us updated.
Feb 07, 2011 | BOSS AUDIO SYSTEMS BV7320 Car Video Player
I please need a kenwood kvt 516 wiring diagram to hook up my stereo i dont know what each color is. like left fron speaker etc. please help
battery yellow
accessory red
ground black
power antenna blue
amp turn blue/white
illumination orange
dimmer orange/white
RF + gray
RF - gray/black
LF + white
LF - white/black
RR + violet
RR - violet/black
LR + green
LR - green/black
Sep 27, 2010 | Kenwood Car Audio & Video
What are the speakers wire colors on a pioneer car stereo?
fr left + white
fr left - white/black
fr right + grey
fr right - grey/black
rear left + green
rear left - green/black
rear right + purple
rear right - purple/black
hope this helps thumbs up pls
Aug 11, 2010 | Pioneer AVIC-D2 In-dash Car Audio Stereo...
Same problem 4cyl running on 2.Engine rocking
check the oil and see if it milky? sounds like a head gasket. you can call me. 817 522 5002
Jul 20, 2010 | 2000 GMC Sonoma Extended Cab
I need the wire color codes for a 2008 ford focus, for the stereo! please help me!
OK HERE IS THE WIRING COLORS I SHOW, I WILL CAUTION U THAT THIS RADIO IS PART OF THE COMPUTER CONTROL SYSTEM OF THE DASH LIGHTING AND U CAN'T JUST PLUG ANY RADIO IN, CONTACT A CAR STEREO SHOP FOR COMPATABLE MODELS
2008 Ford Focus Car Stereo Wiring Diagram
Car Radio Battery Constant 12v+ Wire: White/Red
Car Radio Accessory Switched 12v+ Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for accessory turn on.)
Car Radio Ground Wire: Black/Blue
Car Radio Illumination Wire: Gray/Orange & Violet/Orange (This vehicle uses the can data network for illumination and dimmer controls.)
Car Stereo Antenna Trigger Wire: Black
Car Stereo Amp Trigger Wire: Violet/Red
Left Front Speaker Negative Wire (-): White/Brown
Right Front Speaker Positive Wire (+): White/Violet
Right Front Speaker Negative Wire (-): White/Orange
Left Rear Speaker Negative Wire (-): Brown/Yellow
Right Rear Speaker Positive Wire (+): Brown/White
Right Rear Speaker Negative Wire (-): Brown/Blue
Apr 28, 2010 | Car Audio & Video
Aux location on head unit of pioneer deh-p7500mp
there should be two aoxzilurey wires on the back you stereo red and white! plug in your male wire to the female on the back of your stereo
Feb 23, 2010 | Pioneer DEH-P7500MP CD Player
I am trying to install a new stereo in a 94 rodeo but my wire harness is cut off
here are the wire colors and what each does.
1994 Isuzu Rodeo Car Audio Wiring Guide
Car Radio Battery Constant 12v+ Wire: Red/White
Car Radio Accessory Switched 12v+ Wire: Brown/White
Car Radio Illumination Wire: Red/Green
Car Stereo Dimmer Wire: Red/Yellow
Car Audio Front Speakers Size: 4′
Car Audio Front Speakers Location: Dash
Left Front Speaker Positive Wire (+): Blue/Yellow
Left Front Speaker Negative Wire (-): Yellow
Right Front Speaker Positive Wire (+): Green/White
Right Front Speaker Negative Wire (-): Gray/White
Car Audio Rear Speakers Size: 4′
Car Audio Rear Speakers Location: Side Panels
Left Rear Speaker Negative Wire (-): Red/White
Right Rear Speaker Positive Wire (+): Orange
Right Rear Speaker Negative Wire (-): Black/Orange
Nov 22, 2009 | 1993 Isuzu Rodeo
Need to hook up stereo in 91 accord but its just open stereo wire
Below is the wiring setup for your car:
1990-93 Honda Accord Stereo Wiring
Constant 12V+ White/Yellow Switched 12V+ Yellow/Red Ground Black Illumination Red/Black Dimmer n/a Antenna Trigger Yellow/White Antenna Left Rear Front Speakers 6 1/2" Doors Left Front (+) Blue/Green Left Front (-) Gray/Black Right Front (+) Red/Green Right Front (-) Brown/Black Rear Speakers 6 1/2" Rear Deck Left Rear (+) Blue/Yellow Left Rear (-) Gray/White Right Rear (+) Red/Yellow Right Rear (-) Brown/White Best of luck,
Greg
Aug 01, 2009 | 1991 Honda Accord
How to replace Speedometer Sensor on 2000 Buick LeSabre
1. disconnect the PCM connecter C1
2. connect a signal generator I/P test J 33431-B to PCM connector C1, terminal 55.
3. Connect J 33431-B ground to terminal to a good chassis ground
4. set the signal generator I?P test J 33431-B to 54 mph.
5. turn the ignition siwtch to RUN.
Yes it reads 54 then
1. inspect CKT 817 (dark green/white) for the following
a. a short to ground
b. a short to voltage
c. an op
If no problem --> check IP wiring for connection, if ok then Replace IP cluster.
If yes problem, repair CKT 817 wiring
If NO 54
1. inspect for poor connection at C1, 55
2. if OK, then go check engine controls
Jul 27, 2008 | Buick LeSabre Cars & Trucks
Car Audio & Video Logo
77 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
