SAMSUNG LA32C450E1 LCD TV
MY TV SWITCHES ON NORMALLY VERTICAL LINESAPPEAR ON THE LEFT SIDE AFTER TWOMINUTES THEN THE LINES INCREASE TO THE RIGHT SIDE,THEN PICTURE FREEZES DOUBLE IMAGES APPEAR AND THEN BLACK MASKING OF THE SCREEN WHILE IN THE BACKGROUND THROUGH A SMALL SLIT AT THE BOTTOM ONE CAN SEE THE CHANNEL BEING RECEIVED.IF I SWICH OFF AND SWITCH ON THE TV STARTS TO WORK NORMALLY AND THE PROBLEM STARTS ONCE AGAIN
zjut
  • 106 Answers
SOURCE: dark vertical line(s) on Lcd tv
Most likely it's the LCD panel failure. You can replace the panel if you can find a spare part. But the new panel may cost you as much as to buy a new tv. Hope that will help you.
Posted on Jan 27, 2008
  • 9 Answers
SOURCE: No picture
try chicking the horizontal section or vedio section...
Posted on Jan 29, 2008
SOURCE: Samsung LE40R51B no picture but turns on
i have the same problem i was told by a repairman that samsungs are known for bad psu. and that its expensive to repair
Posted on Feb 05, 2008
SOURCE: samsung 26inche lcd tv has a blue thin line acrross the left side
call the repair guy, he will be able to diagnose, prbably a bord problem.
Posted on Dec 23, 2008
SOURCE: Vertical line on LCD TV Panel
No solution here.
I have the same issue... A vertical magenta line, about 2 pixels wide, appeared about 1" from the left side of my 52" LNT5265FX/XXA. Of course, this appeared after the 1 year warranty... For me it started showing up about 22 months from purchase date. It goes away when the TV warms up after about 30 minutes or so. Sucks that such an expensive product has developed this issue w/in 2 years.
Posted on Feb 17, 2010
How do I fix my Samsung LN52A580 TV as the right half of the screen is totally black (even thought I get sound and picture on the left hand of the screen)?
Samsung HL-R6178W DLP TV half of screen goes black [Solved] - HDTV ...
www.tomsguide.com/forum/54431-4-samsung-r6178w-half-screen-black
Aug 28, 2013 - 36 posts - ‎24 authors
Samsung HL-R6178W DLP HDTV I just bought this tv used as is. Every once in a while, the right side of the screen goes black on all inputs. I have read ... As for the 1000 dollar price tag, that's totally bonkers. I found a web site ...Missing: ln52a580
HLR6768W - Right half of screen goes black - Forums - CNET
www.cnet.com > Forums > Samsung
CNETI have a 4 year old 67" Samsung DLP which has worked pretty well other than having... Over the past 6 months it's developed a new behavior where the right half of the screen goes completely black and stays that way until I power cycle the tv.Missing: ln52a580
Samsung LN52A580 Vertical Line Problems - YouTube
? 0:32
https://www.youtube.com/watch?v=eejE6O340EY
Aug 22, 2011 - Uploaded by Jonathan Polis
Samsung LN52A580 Vertical Line Problems ... This feature is not available right now. ... LED LCD TV FIX, How To For Samsung Double Image, Black Vertical Lines, ... Sanyo LCD with DistortedHalf Picture Lines Waves Distortion Distorted ... Samsung DLP Green screen / lines Repair HLR XX67 Series ...
lcd/led tv one side dark video screen display problem fix ...
? 2:28
https://www.youtube.com/watch?v=dYHPKxijz1A
Jan 21, 2016 | Samsung LN52A580 52 in. HD-Ready LCD TV
I HAVE A SAMSUNG 50 INCH TV, THAT JUST STARTED HAVING A VERTICAL LINE ON LEFT SIDE OF SCREEN. WHAT'S THE CAUSE AND HOW DO YOU FIX IT ????
samsung lcd tv: vertical color lines *PLEASE HELP* - Forums - CNET
CNETJun 11, 2015 - samsung lcd tv: vertical color lines *PLEASE HELP*. by justinwu86 / March 31, .... In reply to: Vertical colored line on left side of screen. yeah the pannel has ... Red/Blue vertical lines on display
Jun 11, 2015
Vertical Lines help samsung led lcd tv
Oct 4, 2014
Thick vertical line in Samsung 52' TV
Jul 5, 2013
Thin vertical line on Samsung LCD TV
Feb 10, 2010
More results from www.cnet.com
Jan 03, 2016 | Samsung Televison & Video
Black and white vertical lines on left sided of screen. Black and white vertical lines vary in width. Left of vertical lines is wrapped video from right side. This is happening on all inputs. I have very...
If its under warranty take it back immediately!!! If not you will need to have the set diagnosed to pinpoint the problem. You could be looking at a faulty t-con/panel connection (easy fix) or a bad t-con board(inexpensive) or a LCD panel(very expensive) failure !
Oct 08, 2013 | Samsung UN60C6300 60 in LCD TV
Vertical lines
you could have a faulty LCD/t-con ribbon connection, or a failing LCD panel. I would suggest you try and reseat the ribbon cables to the panel and t-con, if you are comfortable doing this!
Apr 27, 2013 | Samsung LN52A550 LCD TV
Vertical blue lines on left side of tv
the line is normally down to a sreen failure sounds expensive
Sep 20, 2010 | Samsung LN32A330 32 in. LCD TV
Two vertical 1'' white lines on right side of Lcd panel
If the lines are parmanent, Then suspected part is LCD Panel.
Dec 27, 2009 | Samsung 226BW Monitor
Red vertical line down right side of the screen
hi
I think your TV have a trouble inside lcd panel
the controller board contains driver IC. Deffective driver IC can cause of line display.
Three reasons why one vertical line accross screen can happen in LCD;
1.The missing signal from the controller IC to
LCD driver.
2. LCD driver IC itself defective
3. Dry contact in the tape carrier package.
Use masking or electrical tape to mark it where the line was located. press it if the line back to normal but when release your hand came back i think it was intermittent. Open the LCD panel
Use robber
Place the rubber on the top of TCP
Gently close back the top casing
Good luck...
Aug 21, 2009 | Mitsubishi LT-46144 46 in. LCD HDTV
Had this same issue on right side of 52" about 1 inch from side but had 3 vertical lines that disappeared after 40 minutes. Have Samsung LNT5265FX/XXA and about 16 months old. LCD Panel itself had to be replaced to fix it, fortunately had extended service plan
Oct 17, 2008 | LG 42LC2D 42 in. LCD HDTV
Samsung LE32R7 Vertical lines problem
Plug the TV into a wall socket by itself, have seen this when TV was plugged into a power strip.
Dec 13, 2007 | Samsung LE32R41BD 32 in. HD-Ready LCD...
Got a blue vertical line on me plasma
I had the same problem, a vertical blue line from top to bottom on my samsung TV.
Try this download this http://www.jscreenfix.com/video.php i burned it to a dvd and it fixed it within a minute.
Nov 07, 2007 | Samsung HPN5039 50 in. Plasma HDTV
Televison & Video Logo
53 people viewed this question
Top Televison & Video Experts
Electro Med Services...
