Question about Fuji Xerox® DocuPrint C3055DX Laser Printer
Wrinkled paper Printer hasn't been used for a number of years. Now everytime I print the paper is crinkled
  • Fuji Master
  • 32,281 Answers
The rollers are sticky, clean the rollers with methylated spirits.
Posted on May 08, 2013
How do I stop the paper from crinkling prior to printing in Canon D320
check the whole paper flow. special look out for things in the printer that don't belong there, like a paperclip or screws of paper.
sometimes things fall in a printer and can spot all the fun.
Jan 21, 2015 | Canon Office Equipment & Supplies
Envelope printing error - when printing from the MP tray, envelopes are wrinkled
nothing im afraid mfps crinkle copiers all you can do is try to reduce the wrinkle try putting the flap inside the envelop sorry but other than that's theres not much your can do
May 14, 2014 | Kyocera Office Equipment & Supplies
We have a Laser Jet Pro CM1415. It wrinkles linen envelopes when printing. Is there a quick fix (adjustment etc.)? It prints slick envelopes OK.
that printer is really not designed to print on those envelopes but the wrinkling is usually caused by to much moisture in the envelope or paper stock. When the printer heats the print stock to bond the toner to the paper in the fuser unit the moisture evaporates and causes the paper to wrinkle. Don't know of a fix for it other than use different print stock.
BuddyMc
16 Years HP tech
Aug 10, 2011 | HP Office Equipment & Supplies
My canon Pixma. When it prints, the sheets come out crinkled!
This usually happens when the rollers that feed the paper through the printer are dirty. Because your printer is still rather new, I'd imagine that it is a dust problem rather that ink overflow. what you should do is get a cotton swab and some 99.9% alcohol and clean the rollers. The rollers will look like black cylinders and will be in locations that the paper goes. there are usually 2 just inside of where the paper is, and you find some under the cover where your ink is. Once you have cleaned the rollers, try to print again ans see if it still comes out wrinkled.
Mar 05, 2011 | Canon Pixma MG5220 InkJet Printer
Paper catching
the paper sensor could be bad, try manually selecting the paper type, plain paper etc...
Mar 19, 2009 | HP Photosmart C6180 All-In-One InkJet...
Paper is coming out wrinkled in one spot
Most of the crinkled paper issues I deal with have to do with the fuser roller lining going bad. If this is your issue the crinkle will be a vertical line from the leading edge to the trailing edge. You will need a new fuser.
Jan 30, 2009 | HP LaserJet 2840 All-In-One Printer
Paper crinkles
This is what I've seen with wrinkled pages in these machines.
Usually only happens with letter size paper.
At some point a leaking toner was used in the machine the excess toner works its way toward the fuser and builds up on the guide where the paper enters the fusing assm.
You can try to clean the toner thats built up or replace the fuser.
Hope this helps
Jan 13, 2009 | HP LaserJet 8000n Printer
Printer only prints on the left side and wrinkles up the paper on the left side
Hi there it could be that the fuser or the drum unit has some sticky labels attached to it check these units also check the paper feed path as there may also be some obstruction causing the paper to crease and crinkle.
Hope I could help
Thanks J
Jan 17, 2008 | Ricoh Aficio SP-C210SF Printer
Phaser 7700GX Color Printer prints wrinkled pages!
when this occurs the problem is most of the time with the transport roller, fuser / fixing assembly roller.question is the image still toner only and not fused to the paper.
In these areas there is offen a jammed and not removed piece of paper dislodged in the paper path or jammed in the fuser or the transfer rollers teflon coating has perished inspect the areas carefully and remove any found if the unit still is faulty (fanning of paper the fuser would be the first to be replaced are past there usable life) if so then Post a reply
Sep 10, 2007 | Xerox Phaser 7700 Laser Printer
Fuji Xerox® DocuPrint C3055DX Laser Printer Logo
43 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
