Question about NEC DSX Systems NEC-780020 DTR-1-1 BLACK Single Line Phon Phone
How do I take the NEC phone system off night mode
One of my phones stopped ringing on my nec dtu 16d phone
Ringing is assigned in system programming, very little chance it was changed by mistake. If Do-Not-Disturb was turned on, that could make a phone stop ringing. If it's just one line on a phone, maybe the system got put in night mode by mistake and night programming isn't identical to day ring. If you have direct access to the phone line check it for dial tone. Often virtual lines are used and you can't check for direct dial tone. On very rare occasion the ringer stops working, which can't be fixed.
Jul 11, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
How do i turn off the Night Mode
From one of the 2 main reception phones, press Feature 80 Feature , on a ProII, an Elite, and an IPK. For the other systems that use this phone you're best off finding the phone that has a night button assigned.
Jul 02, 2014 | NEC Electra Elite DTU 16D-2 Corded Phone
I think the ringer is off on my NEC Dterm 80 phone. when a call comes in, I hear it ring at my bosses desk but not mine and my line is the main line. How do I turn the ringer back on. Thank you
Ringing is assigned in system programming, so if your phone doesn't ring you can't change that unless you have person on site who works on the system at that level. Some places use the night mode feature to make certain phones ring in day mode, and others to ring in night mode. Not very likely but sometimes the mode gets switched at places who don't realize they have another mode, suddenly only 2 phones ring instead of ...5. Feature,80,Feature, is the code to switch back and forth on a Pro II, an Elite, and an IPK system. This would be done at the reception phone. These phones also work on several other systems so don't know if this works for you. Or maybe you set Do Not Disturb, which would keep your ringer off.
Oct 04, 2013 | NEC Dterm DTP 32D-1 Corded Phone
How do change the outgoing "Night Mode" message in the Voice Mail System on NEC Electra Elite DTU 32D-1?
If you are using an Active Voice product (typical w/ NEC) you need to change the hours of operation on the voice mail system. "Night Mode" only changes the ringing characteristics of the phone system and where calls ring, not the greetings that play on the voice mail. The voice mail plays a particular greeting (Day/Night/Holiday) based on the time of day specified in the schedule. The system administrator for the voice mail would have to make this change.
Jan 24, 2012 | NEC Electra Elite 32D-1 Corded Phone
How to switch between day and night mode?
from the operators phone hit feature key dial 80.it should toggle between day and night.
Feb 09, 2009 | NEC Electra Elite DTU 16D-2 Corded Phone
NEC Dterm80
if you are connected to a key system like a electra elite try dialing feature 80 feature at the main console.
Jul 22, 2008 | NEC Dterm DTP 16D-1 Corded Phone
Trying to change night ringer voicemail
Ok. You will have to find someone who has access to system manager, or has system manager rights for their mailbox.
They will then be able to select System Manager Options, then Change the Greetings. It will tell you which mode you are in, and ask you if you want to change to Holiday Mode. The responses are 1 for YES and 2 for NO. Say no to Holiday Mode, and then it will go thru Day Mode and then Night Mode, playing each one first then asking if you want to change it.
If you must call in a service order with your phone system vendor, make sure he/she not only assigns someone's box with manager access, but also creates a back-door box with manager access. This way you won't be messing with the original Manager Box. It gets expensive having NEC decipher the Manager's password if it gets changed and no one remembers it.
May 07, 2008 | NEC DTU 8D-2 Corded Phone
Additional User Stations not Ringing
You would need to determine which NEC phone system you have and obtain a programming manual for the phone system. Your phone could be used on different NEC phone systems that program differently. Phones only have user guides that explain how to use the features.
You can set up your system with Night Ring and have different ringing rules when the system is put in night ring mode. It sounds like this is what you are looking for.
Nov 20, 2007 | NEC Electra Elite DTU 16D-2 Corded Phone
Voice mail on/off
Try hitting feature 80 feature. It should work from any phone on your system.
Oct 29, 2007 | NEC Electra Elite 32D-1 Corded Phone
NEC Dterm 80
NEC Dterm 80 phone, 1 ext. is blinking and we can't get it to turn off. It shows a busy signal when you try to call it.
Help it is the owners phone!!!
Sep 29, 2007 | NEC Dterm DTP 16D-1 Corded Phone
NEC DSX Systems NEC-780020 DTR-1-1 BLACK Single Line Phon Phone Logo
450 people viewed this question
Top NEC Lands Phones Experts
Craig Butler
Craig Butler
Oloyede Monsuru
ray gallant
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
