Question about Vacuums
Wadvark 7907 Hi I have a Wadvark vacuum cleaner Prestige edition model 7907, and I need to know how to disassemble it as the power cord is broken where it goes into the wind-up part of the unit. Cheers, Tony
reddevil6
  • 1673 Answers
SOURCE: Hoover Model S3281, disassembly instructions
Alot of these Hoovers has a panel on the top, near the back that has some screws to take out, then that panel comes off. The motor and reel cord are under that cover.
Posted on Jan 22, 2008
  • 160 Answers
SOURCE: replace power cord
http://www.rainvac.com/schE1.pdf
Posted on Jul 17, 2008
SOURCE: replace on/off switch on hoover vacuum
My wife picked one up on the side of the road that someone had tossed. The power switch would not turn off. I took the two bolts out of the top part of the handle, and then removed the screws along the back. This will remove the required panels to access the On/Off switch. Once I found the actual on/off button, I found it to be frozen in the "ON" position. After manipulating it for a few minutes, I got the switch to work. This machine now operates great, and I now have a Hoover :)
Posted on Jan 03, 2009
SOURCE: Electrolux 2000 canister vacuum cleaner
The first two solutions are liars!!! The way to open an Electrolux LE canister vacuum is to use a screwdriver or drift punch and hammer to gently tap the two bumpers on the sides of the vacuum towards the opening end (where the bag goes in). The bumpers will slide off and then the clamshell case will open lengthwise. There is NO maze of vacuum hoses or wires inside. I just repaired my own vacuum and am speaking of experience.
Posted on Mar 31, 2009
SOURCE: hoover s3639 vacuum...cord does not rewind
I had the same problem with my Hoover s3639. The cord rewinder started squeaking, and retracted less and less of the cord each time, until it finally stopped retracting the cord at all. Here is what I did. I hope it will work for you as well. Open the covered tool storage and remove the tools. You should see three screws. Unscrew the screws. Remove the cover. You should see the motor for the vacuum and the cord rewinder. Between the vacuum motor and the white wheel where the cord is, you should see two brass wheels that turn into each other in order to operate the cord rewinder. Spray a small amount WD-40 between the two brass wheels. This should solve your problem.
Posted on May 04, 2009
How to replace el8602a power cord
Electrolux Vacuum Cleaner EL 8602A How to replace the ...
www.manualsonline.com/.../vacuum.../how-to-replace-the-power-cord-o...
Question About Electrolux Vacuum Cleaner EL 8602A. How to replace the ... How toreplace the power cord on Electrolux EL8602A. Asked by gerry nickel on ...
Rewiring the Power Cord for the Electrolux Model G ...
? 4:27
https://www.youtube.com/watch?v=4uqNa7mVBO8
Jan 30, 2012 - Uploaded by Jayson1940D14
Rewiring the Power Cord for the Electrolux Model G ... How tochange the Electrolux 725 Suspension Plate - And Get Access To The Motor ... Brown Vintage ELectrolux Canister Vacuum Cleaner 1401-b - Duration: 0:17.
Electrolux Nimble Upright Vacuum, EL8602A - YouTube
? 3:49
https://www.youtube.com/watch?v=-anwdD4fK-o
Nov 11, 2014 - Uploaded by Michael Callender
Electrolux Nimble Upright Vacuum, EL8602A Best Price ... Dirt Devil UD70095 Power Reach Multi Cyclonic Pet Bagless Upright - Duration: ...
Jan 30, 2016 | Vacuums
Power head cord repair
Hi Kathy,
I don't know what model of Tristar vacuum you have but I have a tutorial in the link below that explain how to replace the cord.
http://www.diyvacuumrepair.com/cansiter-vacuums/how-to-replace-a-cord-on-a-tristar-vacuum-cleaner/
hope that helps.
Jan 15, 2016 | Tristar Vacuums
How do I replace a severed power cord on hoover windtunnel upright bagless model U5280900?
Hi there! We recommend taking your vacuum to a Hoover authorized service center to have your cord repaired. Follow the link to locate the nearest service center to you. Thanks! Service Center Locator
Oct 13, 2014 | Hoover Windtunnel Supreme U5280-900...
How do I replace the power cord on my dirt devil
Not an easy chore since the cord goes directly to the motor terminals with spade connectors on the end of the wire. The job requires the complete disassembly of the vacuum cleaner
Jul 16, 2014 | Dirt Devil Breeze Bagless Upright Vacuum
How do I take about my Dyson DC11 to replace the retractable power cord assembly
While it doesn't require a collection bag, a Dyson-brand vacuum cleaner can still suffer the problems of wear and tear that are prone to any vacuum cleaner--for example, a frayed power cord. If the power cord of your Dyson vacuum cleaner has become frayed, change it immediately to avoid a dangerous electrical mishap. You will need a replacement cord from an electronics service center, along with a few common household tools. You do not need electrical skills to complete the task.
Follow this steps on how to replaced the power cord assembly:
1 Unplug the Dyson vacuum cleaner's power plug from the wall outlet. Press the button on the top front of the plastic collection cover. Lift the cover off the front of the vacuum cleaner and place it aside.
  • 2 Trace the power cord to where it enters the back bottom of the vacuum cleaner. Remove the screws from the panel surrounding the power cord with a Phillips screwdriver. Remove the panel. Aim the beam of a flashlight inside the compartment so that you can see where the wires at the end of the power cord wrap around two screws on the motor assembly. Loosen these screws with a Phillips jeweler's screwdriver.
  • 3 Pull the power cord out of the compartment and dispose of it properly. Strip a 1/2 inch of insulation from the ends of the two wires of the replacement power cord. Run the wires into the compartment along the path of the original power cord--pushing the wires into the grooves inside the compartment.
  • 4 Tie a knot on the cord on the inside of the compartment to prevent the cord from being pulled out.
  • 5 Wrap the exposed end of each wire of the power cord around the loosened screws. Tighten the screws. Replace the panel and reattach the screws. Stand the vacuum cleaner right side up. Place the bottom of the plastic collection cover into the bottom front slot on the vacuum cleaner. Push the cover back on the front of the vacuum cleaner.
  • Jul 13, 2011 | Vacuums
    The cord is all chewed up. How do you replace the cord?
    Vacuum cleaner power cords are just insulated wires. It should be fairly easy and inexpensive to replace. You did not give a brand or model number, but hear is a list of available vacuum cleaner power cords
    Jun 03, 2010 | Bissell 6594 PowerForce Bagless Upright...
    MY RAINBOW VACUUM HAS LOST SUCTION POWER AND i DON'T KNOW WHY
    Your Rainbow E series has lost suction power, because you need a new hepa filter, ot your water basin gasket is messed up, or the center motor gasket is messed up or out of position.
    Make sure your water basin is not cracked or broken, also.
    If you have any more questions let me know. I am a Rainbow seller, and a Rainbow expert also.
    Thank you,
    Ralph
    May 19, 2010 | Rainbow E series Canister Wet/Dry Vacuum
    Replace power cord
    Jul 17, 2008 | Rainbow 75th Anniversary Canister Vacuum
    Miele S2511 Vacuum Cleaner Disassemble Question
    My problem is with the power brush...I checked the belt and cleaned the rotating bar..still very low suction. The canister is still giving me plenty of power...thanks for any help
    Sep 30, 2007 | Miele Vacuums
    Vacuums Logo
    215 people viewed this question
    Top Vacuums Experts
    AskDyson
    AskDyson
    D. Floyd Kolb
    D. Floyd Kolb
    Are you a Vacuum Expert? Answer questions, earn points and help others
