Question about Honeywell Vision Pro 8000 Touchscreen Thermostat
Honeywell troubleshooting The thermostat is set on off, when I touch the screen to turn it on to Ac/Heat, nothing happens
Therinnaiguy
  • 1420 Answers
SOURCE: Honeywell digital thermostat won't turn off ac.
The Honeywell CT87 thermostat is a normal round thermostat, not digital and may have a sub-base installed with it that has a two switches on it. One is for Fan (Auto or On)and the other is for Heat, Cool and Off. Make sure the Fan switch is in the Auto position and the other switch is in either the Cool or Off mode. If you continue to get cooling, you have a short in the thermostat wire or a stuck relay in th indoor or outdoor unit. To test this, while the unit is running; remove the round outer ring on the thermostat by pulling it straight off towards you. You will find 3 slotted head screws that hold the thermostat to the sub-base. These screws are located at the 3 o'clock, 7 o'clock and 9 o'clock positions. Turn these screws counterclockwise with a small head screwdriver. They are held in place so should not fall and get lost. With the front of the thermostat removed from the base, the air conditioner should stop running. If the unit continues to run, you will need to have your A/C system inspected by a technician. If in fact your thermostat is digital, look to see how it is mounted to its sub-base and remove it. If the system stops, you may have a bad thermostat or the Fan switch is in the On position. Hopefully this will help.
Posted on Sep 12, 2007
  • 518 Answers
SOURCE: honeywell rth230b won't shut off heat
Sounds like a relay sticking. Possibly in the thermostat or possibly the furnace relay at the furnace. The next time it happens, unplug the thermostat from the wall. If the furnace still runs then it's the furnace relay.
Hope that helps...
Geno
Posted on Mar 07, 2008
SOURCE: My Honeywell thermostat T874R is
The above was posted by fixr1st
Posted on May 29, 2008
22yooper
  • 828 Answers
SOURCE: We have a Honeywell Chromotherm
I almost think you have no power source to the thermostat as if the power is off to the air handler unit (furnace), or the 24 volt transformer is bad. Could well be that the error codes are being powered by the battery.
Posted on Jul 24, 2008
koolbreezes
  • 540 Answers
SOURCE: digital thermostat not working
Can you saY, Batteries!
Posted on Sep 15, 2008
Honeywell Thermostat RTH6350 makes heat run in AC mode after AC runs
Well, if it wasn't doing that before then you more than likely know its in your wiring. Cools down then heats back up sounds like the auto change over is on, and the heat setting is higher than the cool setting?
Mar 02, 2017 | Heating & Cooling
I recently installed the Honeywell ct87n thermostat.....the AC worked fine all summer, but has been off now for 6 weeks. When I turned in on to heat / automatic...nothing happens...neither the AC or Heat...
Check for a fuse in your AC/Heating system either on the control board or in-line on a wire. Make sure the wires are correct to the thermostat.
Oct 05, 2010 | Heating & Cooling
New thermostat..have heat but not A/C help....
What are you setting the thermostat to when you turn on the AC , if you turn on the AC and the house is warm you will need to turn the AC down to a lower setting before the the AC will start up.
Mar 14, 2010 | Honeywell Electronic Programmable...
The transformer on my central AC/heater (luxaire model # A236A344T LH) keeps going out. There are 4 settings on the wall. Cool, off, heat and EM. Heat. The setting switches to EM. Heat each time the...
You might have some thermostat wires that are touching meaning the insulation has been broke off and getting a direct short. Check the wiring going to the outside unit and replace any wire that is in bad shape. let me know okay. Ken
Dec 11, 2009 | Honeywell Programmable Thermostat Heater
Honeywell 5-2 Programmable Thermostat wont turn on
I'm assuming the screen is not blank, and that you can select heat/cool and nothing happens. If it's battery operated then there probably is an issue beyond the t-stat. Technicians normally remove the G or Y wire from the thermostat, then jumper or touch the G or Y wire to the wire that's connected to the R terminal. If the indoor or outdoor unit engages, then the t-stat is/may be the issue. Lots of help out there for testing/bypassing a thermostat. If you're t-stat is battery operated, there is probably an issue that's at the inside unit, like a low voltage short that opened the low voltage fuse, or many other reasons that would cause this scenario. I'm not sure if this will help you, bit you may need a technician if it's not the t-stat.
Nov 24, 2017 | Honeywell Programmable Thermostat Heater
Replacing Round Honewell Mercury Thermostat
try to get one that is made for oil heat, the installation is easy only two wires, and the instructions make it easy.
Oct 23, 2008 | Honeywell Electronic Programmable...
Cold air will not turn on
check your wireing make sure that you dont have the red wire touching the white
Jun 02, 2007 | Honeywell CT87B ROUND HEATING&COOLING...
Honeywell Vision Pro 8000 Touchscreen Thermostat Logo
41 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
