Question about Gatco Charlotte,Glass Shelf,Chrome
I need to know what is the distance between the fixing bolts to the wall due I already have the perforations holes done on the wall...others dimensions fit very well
    New Friend:
    Problem Solver:
  • 7 Answers
The peroration holes should be the holes for the bolts. If you followed the instructions, the two perforation holes are nothing more than a pilot hole for the bolts or screws.
If you are not sure of this answer, just measure the perforation holes (write down the distance, being sure to measure between center to center of the holes). Do the same on the unit itself. I bet they are exactly the same.***WARNING*** IF YOU ARE AFIXING ON A TILED WALL YOU MUST USE A CERTAIN DRILL BIT.***
Posted on May 10, 2013
Fixing half of a door chain to a metal frame.
Two options. Look into a "toggle" or any type of wall anchor in the hardware department of any decent home improvement store and you should that works great. A toggle will go into the hole and expand open once it gets out in the open on the other side.
Feb 02, 2015 | Miscellaneous
Hi, I am replacing a rounded BTW toilet seat and the measurements are: between holes=150mm, width=370mm, length=430mm. I bought a Ceso Rue Softclose from B&Q as per this description http://w
I believe the European standard for distance between fixing holes is 155mm +/- 10 mm. I am not familiar with the actual products you are using, but often these holes are slightly oversize. Your seat may fit depending on this, as well as on the actual diameter of the fixing bolts. You have two options - try it or not. If you don't try it I assume you'll return it. If you do try it and it doesn't fit, you'll return it. You might as well try it, because if it fits, you're done! Good luck.
Dec 01, 2014 | Home
The shelf uses two attachment bolts to fix it to the wall, so I need to know whats is the measure between this bolts in order to clarify whether this device matches the space I have available on my ba
This depends on which model you have, but here are two solutions for you.
1. Your model should have come with instructions. Read the instructions to the point where they tell you the distance between the screws. As far as if your bathroom wall will be long enough measure it. If the space is wider than your model, you are GTG.
2. If you have a tape measure, just measure between the screws making sure you are in the center of each hole. That will be the width you will put the holes in your bathroom wall.
***WARNING*** IF YOU ARE WANTING TO PLACE ON A TILE WALL, YOU MUST HAVE A CERTAIN TYPE OF DRILL BIT.***
May 10, 2013 | Gatco Charlotte,Glass Shelf,Chrome
Nissan suny fb14 bolt holding engine mounting on left side broke and damaged hole.Thread and mounting on chasis damaged and needs replacement. please suggest what needs to be done. also need to know part...
That mount should be simple to order call the parts store. Fixing the broken bolts and hole is another whole problem. Without seeing what your talking about I can only guess. If the bolt hole is in an open flat part not the engine block. You can drill it and put a new nut on the other side of the plate. If however it's a hole in a part like the engine or frame where you can't put a nut on the other side of the part. You will need to reap the hole or cut new threads. Some holes you may not be able to reach and pulling the engine is or may be the only chance to fix the issue. Remove the part that needs to Be replace and clean up what you can. You may have to lift or jack the engine up to remove the mount. And sounds like you will need help if not have. Shop do the work for you.
Dec 29, 2017 | Nissan Pulsar Cars & Trucks
Is plasterboard (with battens behind) strong enough to install a Roca Kalahari wall-hung sink against or do I have to reinforce it using tiles or a bracket?
Ok. Big answer. Where the sink is going to be mounted there needs to be inside the wall structural support mounted between the wall studs. This could be a 2X6 or 2X8 nailed from one wall stud to the next at the height the sink will be mounted. Then once you have repaired the sheet rock you can measure the distance the mounting holes in the back of your sink are and drill these holes smaller than the mounting bolts/screws for your sink. Screw the screw portion into the wall using the nuts on the bolt side and a wrench. Remove the nuts and the slide sink into place where the bolts/screws fit into the mounting holes in the sink back. Install washers and nuts and tighten to wall.
Sep 01, 2010 | Roca Pacific Semi-Recessed Basin - Black
I have a wall mount installed already but dont know how to attach the TV - model LA32R71B to it, should I have some bolts or nuts as there are 4 bolt holes in the back of the TV but I dont know the thread...
The wall mounting kit should come with all kind of screws to attach the mounting barckets to the back of the TV. Most TV uses metric M5 or M6 screws for the mounting holes on the back of TV, you should be able to get them at HD or LOWE for about 35 cents each.
My kits come with a bunch of Metric screws. Do you have the instruction sheet of the mounting kit?
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
Aug 08, 2010 | Samsung Televison & Video
Which rear muffler would be louder (or drone) the most: 1. 8"x4"x14" straight through centre inline pipe with perforated holes 2. 8"x4"x14" inlet/outlet centre inline pipe with perforated holes and a...
The shortest distance from point A to point B. No. 1 would most likely be louder; no. 2 would most likely sound huskier. Better to just buy a performance muffler made specifically for the Alfa.
Feb 13, 2010 | 1984 Alfa Romeo GTV6
I am seeking a template for re-installing my 2 year old microwave. Jenn-aire has none of the templates in stock and can't send me a pdf or file so I can print the template myself. I have tried 2 parts...
Since you can't get a paper template for remounting your microwave, I can offer you my tips for doing this, as I've had to reinstall many of my customers microwaves, after they've done a kitchen remodel.
You can use the metal mounting bracket as your "new" template. Just unmount the micro and remove the metal bracket and you can then position it on the wall or under the cabinet where you are looking to mount the microwave. However, before you remove it from the wall, simply measure the distance from the edges at the top and both sides of the bracket, where it is presently mounted and you'll be able to easily remount it in a new location.
If you've already removed it from the wall, not to worry, simply place it on the back of the microwave and measure the distance from the edges of the bracket to the top and both sides of the microwave's canbinet edges. Allow for 3/16" additional distance and you should be able to then remount the bracket at the new location with ease.
Please remember that you want to get the bracket secured into a wall stud so it can hold the weight of the microwave once it's installed and fastened to the bracket. I also recommend that you use wall anchors at the side edges at both the top and bottom corners to help secure the bracket IF there are no wall studs behind the predrilled holes for mounting the bracket to the wall.
If you have trouble using the metal mounting bracket, you can always trace the entire bracket onto a piece of heavy paper or cardboard, but frankly, I find this unecessary and time consuming, since you've already got the mounting bracket right there with all the holes and such.
Also, don't forget to measure the location of the power cord at the top or back of the microwave and remember you'll need to drill a hole in order to be able to pass the cord thru the cabinet. If your microwave has screws at the top front edge that help secure it to the cabinent above it, again, simply measure the distance of these mounting locations from the sides and back of the microwave cabinet and drill holes thru the cabinet, using a drill bit that is twice the diameter of the mounting bolts. You should add washers to these bolts to help prevent the bolts from pulling thru the cabinet bottom.
Mounting a microwave is best done with at least two people, as holding it in place while someone else puts the bolts in it isn't easy to do by yourself. Also, it is much easier to do, when installing it over an existing range, if you move the range out of the way first, so you can stand under the microwave, instead of having to lean over the range while trying to install it. Not to mention the fact that should you drop the microwave, you'll not only damage it, but could destroy your range at the same time.
Hope you find this Very Helpful and best regards!
Oct 23, 2009 | Jenn-Air JMC9158AAS Convection/Microwave...
Dont know what size bolts to use for fixing brackets to tv to wall mount a 26 inch wharfdale l26ta6a
you should use minimum of 1/4" lag bolts by 2'" long.
Find a wall stud, and drive the bolts(one above the other into the wall through the mounting bracket holes.
Mar 04, 2008 | Televison & Video
Gatco Charlotte,Glass Shelf,Chrome Logo
208 people viewed this question
Top Gatco Furniture Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Gatco Furniture Expert? Answer questions, earn points and help others
