Question about Nikon N80 35mm SLR Camera
Nikon N80 film door replacement instructions (Focus area selector)
The latch tips broke off. Purchased new door. Moved all the old parts from the old door to the new one and attached new door to camera body. The only part I cannot get on is the "Focus Area Selector". It is so frustrating because it looks like it should snap right on, but it doesn't. Please Please Please Help! There are no instructions, videos or otherwise available anywhere on the WEB!
    Novelist:
  • Nikon Expert
  • 357 Answers
It does snap on. If it doesn't then you probably broke it trying to get it off the old door.
Posted on May 14, 2014
5 Suggested Answers
cammedic
  • 667 Answers
SOURCE: Nikon N65 Film Camera Broken latch
You have to replace the whole door. There is one on eBay, but you won't like the price. Find it here: eBay
Posted on Mar 15, 2008
Obertelli
  • 3006 Answers
SOURCE: the door latch on my nikon n75 film camera is broken.
Parts are scarce unless you get them from a scrap camera. If the broken bit is on the body then it's not worth bothering. If it's on the door then it's fairly easy to swap the door from a donor camera.
But as you can buy an n75/F75 in virtually as new condition for under £50 on auction websites you have to decide whether a repair is cost effective.
Posted on Jul 06, 2009
  • 302 Answers
SOURCE: camera film door will not latch. The door latch
Can it be repaired? It needs a new latch piece. Maybe a new door, if its all one piece.
I do not own one so not sure about that model. Look at the door hinge. If a small lever sticks out of the hinge, it may be easily removed and replaced with a new door. otherwise you need to remove the bottom plate of the camera to replace the door. Be very careful doing so as things could pop out when you open it.
You could also send it in to a repair shop, where they will also clean, lubricate and adjust it before returning.
Is it worth it? Only you can answer that. You might be able to pickup a used one on Ebay, so you have a source of parts.
If you have no reason to keep that particular camera, replace it with a newer Nikon, so you can keep using your flash and lenses.
Posted on Oct 11, 2009
emissionwiz
  • 76109 Answers
SOURCE: Who can repair the film door latch?
Any camera shop can send this out for repair or to get an estimate. It may not be repairable due to parts not being available.
Posted on Feb 01, 2012
When i look through, the target is above center. how do i get it to focus on the center of the image I'm trying to shoot? also, with having used it only about 5 times in 2 years, becasue of that
First, make sure the lock lever around the cursor pad is in the unlocked position (make sure the "L" is covered up). Then you can use the cursor buttons to move the focus area, or press the center of the cursor pad to center the focus area.
As for the battery issue, have you tried a fresh set of batteries? Does the LCD panel on the top light up with new batteries?
Oct 20, 2012 | Nikon F80 (n80) Qd 35mm Slr Film Camera +2...
Feb 01, 2012 | Nikon N75 35mm SLR Camera
Loss oft focus area selector button cover on nikon f80.
You can order the part from
http://uscamera.com/1k208-250.htm
Jan 09, 2011 | Nikon F80 (n80) Qd 35mm Slr Film Camera +2...
Broken latch on film door
Usually on this level Nikon it was a plastic "hook", part of the door moulding, that was retained by the latch mechanism in the body. The broken part may still be in there - if it is trip the latch and recover it with a tiny screwdriver or even a needle. If you can't find a replacement back door you can try welding the hook back in place with a low-temperature soldering iron - with the tip perfectly clean and a very steady hand - as long as the door is thermoplastic and not thermosetting. If that doesn't work bend a paperclip or similar to exactly the right shape with the free ends (roughened) long enough to extend into the plastic of the door by 4-5mm., heat the wire and push slowly into the edge of the door. There are many variations of this technique that I've used, all require extremely careful work! Best tip: spend more time thinking than doing. Good luck.
Nov 28, 2009 | Nikon N70 35mm SLR Camera
Camera film door will not latch. The door latch
Oct 04, 2009 | Nikon N6006 35mm SLR Camera
Broken latch on camera back
An authorized Nikon dealer should be able to order the back for you. If there's no dealer in your area, Nikon's service center info is on their web site. There's currently one new back on eBay for US $98..95 from a Canadian seller with good feedback. My only other suggestion is the old joke about pros. How can you tell if a photographer is a real pro? His camera has gaff instead of duct tape.
Apr 12, 2009 | Nikon F100 35mm SLR Camera
Latch for the Film door broke
This is so tedious a job that I would not try it myself unless I was adept in doing this right.Unless the camera costs a lot to start with, I would just get another SLR. I believe the cost in repairing it depending on model and the size, will be about $200. I say this because from experience, I had a $250 camera 20 years ago and the latch broke on mine and he said it would not be worth it to fix it. Unfortunately, it was way out of warranty.
Jan 16, 2009 | Nikon F80 35mm Film Camera
Mar 15, 2008 | Nikon N65 35mm SLR Camera
How to remove the CF door latch
I too am interested in the correct procedure for this . I have an old camera for spares so can easily get the door but am concerned about springs shooting accross the table etc. Has anyone supplied a resolution for this yet please?
May 28, 2006 | Canon PowerShot S400 / IXUS 400 Digital...
Nikon N80 35mm SLR Camera Logo
253 people viewed this question
Top Nikon Photography Experts
Ric Donato
Bart Pulverman
Are you a Nikon Photography Expert? Answer questions, earn points and help others
